Garage Dooer Opener/Trouble
Discussion in '2.5 Gen Tundras (2014-2021)' started by intr3nsic, Jan 12, 2021.
  1. Jan 12, 2021 at 8:17 AM
    intr3nsic
    intr3nsic [OP] New Member
    I've read the manual and the truck doesn't seem to want to take the garage door when I try to pair them. Any suggestions or anyone experience anything else like this and got a fix? I'm not sure if they all do, but my truck has the buttons on the rearview mirror. 2016 Tundra SR5 (Canadian truck; I read somewhere we had different options than USA).
  2. Jan 12, 2021 at 8:40 AM
    I_Am_Thee_Walrus
    I_Am_Thee_Walrus New Member
    ‘21 Tundra TRD Off-Road
    Mine has it but haven’t tried to pair them yet. I’m sure someone here has.
  3. Jan 12, 2021 at 8:48 AM
    matictundra
    matictundra New Member
    Franco
    AZ
    2017 Red Tundra SR5 4x4 CM
    3"/1.5" Lift (Fox 2.5 DSC all around, JBA UCA's and Toytec Shackles at 1.5") Front and Rear TRD Sway Bars Nitto Ridge Grappler 37x12.5R18 w/ Brz 18x9 +25mm Methods MR701 Wheels AFE Dry Filter with TRD Flow Acc Dirty Deed No Muffler Exhaust Nitro 5.29 Gears RCI Engine, Trany/Trans-Case and Fuel Skid Plates Relocated Rear Diff Breather | Rear Brake Line Extension Jomax ABS Sensor Armor Colored Matched Front Bulge and TRD Pro Grill Assy Modded ADD Stealth Fighter Front Bumper Custom High Clearance Rear Bumper with Modded Tow Receiver Behind Plate and Chopped Rear Fender Custom Bed Stiffeners 2019 TRD PRO LED Headlights w/ Ihacker Harness | BD 40" ARC AMB/WHT DC OnX6 BD 10" Onx6 in the Grill (2X) Rago Low-Profile Ditch and Extended Brkt with Daul BD Squadron Pros - AMB & WHT AMB LED Chase Light (Cargo) | Dual BD Squadron Sports in Rear Bumper Prinsu Roof Rack with a Pair of BD S1 For the Sides and Rear Mictunning C2 Rock Lights, 2 per wheel, and Toyota style switch 2X 55" Quick Light Whips with Toyota style switch Switch Pros SP-9100 with Custom Switch Mount, Custom Engine and Roof Terminal Junction Boxes 12K Lbs Smittybilt Winch with wireless remote and Factor 55 FlatLink E Amp Power Step EVO-One Remote Start Limo Tint (All Around) | De-Badged LED Interior lights with Front / Rear Interior Footwell LED Blue LED Lit Lock/Window Switch Mod AJT Full Chrome Delete Kit w/ 3R3 Painted SHCS Toyota LED Bed Lights Leather Perforated Wrapped Steering Wheel Black TRD Shift Knob ESP Long Box BakFlip MX4 Bed Cover Thinkware Q800Pro Dashcam (Front & Rear) Rago Dashmount w/ Ram Phone Holder
    I think Toyota uses homelink. I ended up following the homelink website instructions. Go to their website and follow their instructions for the correct model of garage opener.
    Wallygator and GianLaGatta like this.
  4. Jan 12, 2021 at 9:43 AM
    P-Factor
    P-Factor New Member
    2018 Tundra Limited Double Cab
    TRD Sway Bar, TRD Exhaust, TRD Cold Air Intake
    I had the same issue a few years back and had to replace my opener. My original (Wayne Dalton) garage opener was "Home link" compatible originally but due to it being fifteen years old it was no longer compatible with newer Home link devices. Once opener was replaced I had no further problems and all work as designed.
  5. Jan 12, 2021 at 10:10 AM
    GianLaGatta
    GianLaGatta New Member
    Gian
    2019 white tundra sr5
    3in lift
    I have this app called MyQ, its all on my phone I'm not even sure if I have a garage button in my truck.
  6. Jan 12, 2021 at 10:11 AM
    heyacker
    heyacker New Member
    I think it’s something like this, going off memory here so it may not be exact
    1. Push and hold outer two homelink buttons until led blinking changes, slow to fast or fast to slow I don’t remember (this erases all learner codes on the truck)
    2. Get your current garage door opener remote and hold about 3 inches away from mirror. Push opener remote button and the button on mirror you want to open garage. Hold them both until led blinking changes.
    3. press the “learn” button on your actual garage door opener. This is usually behind the light lens near the wire hook ups. You have about 30 seconds to run to your truck and push the mirror button you programmed. You may have to push it multiple times. I usually do 1-2 second pushes with a 1-2 second pause in between. This usually gets it done.
    If not like other poster said it may be your garage door opener isn’t compatible or you may need another interface like my wife’s Infiniti. Her vehicle needed a separate module that I had to program to the garage and then program that to the car.
    Good luck.
    KillaahCam likes this.
  7. Jan 12, 2021 at 10:30 AM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
  8. Jan 12, 2021 at 10:35 AM
    Part_time
    Part_time Not a new member
    Oregon
    2017 MICA BRONZE SR5
    Where is that button? what model do you guys have?
  9. Jan 12, 2021 at 12:43 PM
    Part_time
    Oregon
    Yeah I don’t have that
  10. Jan 13, 2021 at 6:34 AM
    nodak67
    nodak67 New Member
    JR
    this will be the 99% rule for all garage door manufacturers. this is the procedure i use on a door system that is from the late 90's. the homelink instructions are vague on this process (in the tundra manual and on the homelink website). it kinda tells you to do either step 2 or step 3 above, but in reality you have to do BOTH step 2 and 3 in that order
    and on step 3, do the push sequence in short bursts as stated or if that doesnt work, just hold it down. on my 2014 4runner i had to hold it down, on the 2018 tundra i had to do short bursts.
  11. Jan 13, 2021 at 7:47 AM
    clarkritchie
    clarkritchie New Member
    In my experience, Home Link is very hit or miss. I've had 4 vehicles with it along with 3 different houses using recent model garage doors (from the years 2010, 2012, and 2015), and my Tundra is the first and only vehicle I've ever been able to pair with Home Link. All I can recommend is to follow the instructions to a T, start over if you mess up, but don't make yourself crazy over it because I think the system is flakey overall.
    I will say, if you are successful, the range is really good. My door opens from much further away than with the clicker, even with a fresh battery.
    Good luck!
    NewImprovedRon and Wallygator like this.
  12. Sep 12, 2021 at 7:59 AM
    Topo
    Topo New Member
    Tony
    2014 SR5
    When pushing the “learn” button on the garage door opener, does that add the homelink code and Not delete my remote unit’s functionality? In other words, I want both my remote unit and the truck’s mirror/homelink to work. Thanks
  13. Sep 12, 2021 at 8:01 AM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Depends on the model, but usually yes, you add remotes without affecting the old ones that were already programmed. Just don’t clear all learned devices when you do it and you should be fine.
  14. Sep 12, 2021 at 8:05 AM
    Topo
    Topo New Member
    Tony
    2014 SR5
    It’s a very old opener. I’ll have to see if i can find a manual to make sure it won’t clear the memory.
  15. Sep 12, 2021 at 8:35 AM
    Kfrog
    Kfrog New Member
    2016 Tundra SR-5
    I got the 2016 Tundra, as well and have set several openers with it. I was going to tell you about the learn mode on opener but someone already has and could tell you how to program it but there are so many different models out there it would be a waste. I would suggest viewing your opener's instructions and pairing with however the truck tells you. I drove my truck in front of opener to be closer.
    Good Luck,
