RAGO DASH MOUNT
Discussion in '2.5 Gen Tundras (2014-2021)' started by kyle112006, Jan 11, 2021.
  1. Jan 11, 2021 at 11:42 AM
    kyle112006
    kyle112006 [OP] New Member
    Kyle
    Really considering the Rago Dash mount. What other options are out there besides ICS.... If I go with the Rago and the ICS mount plate I'm already 150 dollars in.....talk me in or out of it haha
    2point5seconds likes this.
  2. Jan 11, 2021 at 11:43 AM
    YotaBro
    YotaBro This forum will make me broke
    Calvin
    FL
    2017 Cement Grey Tundra TRD PRO
    Lots of shenanigans.
    I have an ICS and love it, I agree that the Rago looks more finished but was happy to save some extra money. I believe that the Rago has blemished items and if I did it again, I would go that route with an ICS mount plate.
    Hightide likes this.
  3. Jan 11, 2021 at 12:38 PM
    preacher35
    preacher35 RIGHTEOUS MEMBER
    2018 MGM Platinum Crewmax 4x4
    Go with the Rago. You are going to have to look at it every single time you drive. So spend the extra money and get it. That being said, I got my Rago for $100.00 with a coupon code. And, in lieu of the ICS back plate, I cut a piece of carbon fiber to use for my back plate. Just as rigid and cost me nothing.
  4. Jan 11, 2021 at 12:45 PM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    I've got the Rago and ICS mount plate but in all honesty plywood would work just as well to stabilize the Rago. The mount just needs to have a big footprint.
  5. Jan 11, 2021 at 1:01 PM
    Hightide
    chadington von banks
    Abalama
    Magic School Bus
    Go with Rago.
    It’s more intuitive.
    You have to get your fingers under the ICS mount to tighten accessories.
    The Rago is pre-threaded and just works better.
    Plus it looks badass.
    Go with the ICS under plate, though.
    The ICS mounts and such are nice too.
    Sign up for Rago’s email.
    They’ll send about three a day.
    Eventually, you’ll get the coupon you want.
  6. Jan 11, 2021 at 1:31 PM
    Black
    2014 Tundra Limited CrewMax
    The ICS is much more versatile in mounting options. As you are not limited to where the tapped holes are.
    ICS’ design is a bit of a pain but just buy longer mounting bolts and install them from the bottom instead of the top and put a clip washer on the mounting bolts and you can remove the top mount and not have to take out the stereo as it will hold the bolts and mounting plate in place while you have the top mount removed to tighten your nuts without having to try to get your fingers underneath.
    I think I gave $114 for the ICS mount, plate, and, dual USB power outlet.
    Gabrielo93 likes this.
  7. Jan 11, 2021 at 2:17 PM
    2point5seconds
    2point5seconds Wish I didn't have so much money
    Sensei
    Nor Cal
    2019 Tundra SR5 TRD 4WD Double Cab
    Icon Stage 9 lift, 700 pound rated Eibach spring, Sumo Springs (rear), RCI engine skid plate. RCI Lower Control Arm Skid Plates, RCI Transmission Skid Plate, RCI Cat Guards, Rago dash plate. RAM phone holder. Bed rails. Tint. 17x8 Icon Rebound wheels. 315/70/r17 Falken Wildpeaks. AAC Trigger 6 Shooter, midland MTX-115 radio, Chassis Unlimited front bumper, OLB Bar light and ditch lights, Baja Fog lights, Smittybilt winch, Husky floor liners, bed rail, Cali Raised Bed Stiffeners, driver's side grab handle, Wheeler's Offroad front bump stops, Decked Tool Box
    Just installed my Rago and ICS plate yesterday. Took about 3 to 4 hours but I like the look of the Rago with my dash cover. It took me forever to figure out what I wanted, but eventually just went for it. Good luck with your set up!
    https://www.tundras.com/threads/rago-dash-plate.69985/page-2#post-2056445
  8. Jan 11, 2021 at 3:47 PM
    Hightide
    Abalama
    Magic School Bus
    How so?
    Actually, you’re not limited to the the holes in the Rago.
    You just have to use the slots like ICS recommends... “install your mounts before installing mounting plate.” Um.
    Just buy longer bolts? Ok.
    If you can’t mount enough accessories in the Rago, you’re not doing right.
    ICS ball mounts and accessories are top notch.
    However, the mounting platform or table is not well thought out and cumbersome, IMO.
    I’ve owned both.
    YotaBro likes this.
  9. Jan 11, 2021 at 5:23 PM
    eick
    eick New Member
    2020 CrewMax TRD Off Road
    I think I am going to go this route but use some sheet metal or aluminum plate cut to fit inside the opening
  10. Jan 11, 2021 at 5:47 PM
    Tundraofnv
    Tundraofnv New Member
    2020 Cement Crew
    Is a Group Buy an option with the MFG? If so, I’m in.
