Brand New Tires Bulging Warranty?
Discussion in 'Wheels & Tires' started by NateG, Jan 9, 2021.
  1. Jan 9, 2021 at 1:43 PM
    NateG
    NateG [OP] New Member
    Nate
    2015 SR5 Double Cab
    315/70/17 general grabber atx (~35x12.5x17) mounted on rock warrior wheels. Woke up this morning to find one of them is bulging quite badly. Tire is at 42psi.
    I bought them used a few weeks ago but they are basically new with a 2719 date code.
    I’ve still got to make the drive home so not sure what I’m going to do yet.
    Hopefully general will replace the tire free of charge.
  2. Jan 9, 2021 at 1:47 PM
    Pine Tree State
    Pine Tree State New Member
    2021 SR5 TRD Sport CM
    Buying used would be my concern. If they were new/first owner i think you’d have no problem. They may not honor warranty on second hand
    BravoDeltaRomeo likes this.
  3. Jan 9, 2021 at 1:48 PM
    CCLJ03
    CCLJ03 Tundra forever
    Craig
    2018 TRD Off-Road - Cement
    Trying to save money can be expensive.
  4. Jan 9, 2021 at 1:54 PM
    NateG
    Nate
    2015 SR5 Double Cab
    Yea the previous owner only had them on for a few weeks before he decided he wanted m/t’s. Tread was at 15.5/32nds (16 is new) so I wasn’t concerned about making the purchase. Anyways we’ll see if general will help me out or not.
    I’ve got a 2.5 hour drive home tomorrow so I’m going to take the chance and air down a bit and drive slowly.
  5. Jan 9, 2021 at 2:11 PM
    Definitely bulgy...like a moose. General should warranty, or where you purchased the tires.
    And some light super troopers comedy...
    Saltyhero13 likes this.
  6. Jan 11, 2021 at 11:10 AM
    pearlpower
    pearlpower New Member
    2014 CrewMax in Radiant Red
    If you had them reinstalled on wheels they may blame the tire shop. I did have a tire shop cut the inside of one my tires long ago, and it created a bulge like that. They would likely require a tire shop inspection for obvious damage, first.
  7. Jan 11, 2021 at 11:14 AM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    Used from a shop, you may have some sort of warranty from them.
    Used from Kijiji, you are out of luck.
    Where did you purchase them?
    Title is misleading as they are clearly NOT "Brand new", they are USED. That will be a huge factor in warranty for a shop or mfg.
  8. Jan 11, 2021 at 11:31 AM
    blackoutt
    blackoutt YEAH BUDDY!
    NWA
    07 DC Long Bed - Old Man Tan
    OEM+
    General tire has no obligation to you as a second hand purchaser. Maybe try the tire shop that installed them, although they usually have a waiver to install used tires as well.
    http://generaltire.custhelp.com/app/answers/detail/a_id/661/~/replacement-tire-warranty
    1. ELIGIBILITY This Limited Warranty and Adjustment Policy (“Limited Warranty”) applies to the original owner of new General Tire brand passenger and light truck (LT) tires that are (a) new replacement market tires bearing the General Tire brand name and D.O.T. Tire Identification Number, (b) operated in normal service, (c) used on the same vehicle on which they were originally installed according to the vehicle manufacturer’s recommendations, and (d) purchased from an authorized General Tire brand tire dealer
    6. OWNER’S OBLIGATIONS To make an eligible claim under this Limited Warranty, the owner must present a claim as instructed herein, with the tire to an authorized General Tire brand tire dealer. For the nearest authorized General Tire brand tire dealer, consult the General Tire brand internet address(es), or the 800 telephone number(s) shown on the back of this Limited Warranty and Adjustment Policy. Owner must present an original tire sales receipt and proof-of-purchase indicating the date of purchase
  9. Jan 11, 2021 at 11:34 AM
    Blueknights75
    Ron
    Clayton, NC
    Hopefully OP made it to his destination safe! No way in hell would I be driving on a tire bulged out like that.
  10. Jan 11, 2021 at 12:20 PM
    Kanobi13
    Kanobi13 New Member
    Looks like seperation personally i would put spare on so you do not damage those sweet wheels
  11. Jan 11, 2021 at 12:29 PM
    timsp8
    NY
    No way I’d drive on that and put people at risk. Especially 2.5 hours.
  12. Jan 11, 2021 at 2:14 PM
    NateG
    Nate
    2015 SR5 Double Cab
    Drop the tire pressure down and took the back roads home yesterday taking it easy on the speed. Swapped my toyos back on right away.
    When I bought the rw wheels, one of the bead rings was seized on so we mounted the tire with the ring on. The bulged tire was the culprit. Probably stretched the cords causing this. Lesson learned. Will be buying another atx to throw on soon and will make sure I get that ring off before hand.
    TheBeast likes this.
  13. Jan 11, 2021 at 2:59 PM
    Tundra-dude
    Tundra-dude New Member
    2020 Tundra SR5 CrewMax
    I've seen sidewall bulges like that before on low profile tires on sport cars and some other more typical tires. The tire shops will almost always say it is the result of you hitting a major obstruction like a pot hole. I do think the sidewall tire construction varies a lot and some are more robust than others to impacts. My son had some Goodyear tires on his car and 3 out of 4 had bulging sidewalls and he was guilty of hitting some major potholes. With some Michelin tires he's still guilty of hitting major pot holes and has never had a sidewall issue. Hard to tell from your picture but its something to consider. PS- even though you are not the original owner, you could file a safety issue report with NHTSA if you know the condition was not due to a road condition. (pot hole, curb, etc...) This will often drive a response from the manufacturer. That's a dangerous condition since it can result in a rapid loss of air. Good luck.
    NateG[OP] likes this.
