Hellwig Setting Recommendation
Discussion in '2.5 Gen Tundras (2014-2021)' started by Zed, Dec 1, 2020.
  1. Stiff
    3 vote(s)
    60.0%
  2. Middle
    3 vote(s)
    60.0%
  3. softest
    1 vote(s)
    20.0%
Multiple votes are allowed.
  1. Dec 1, 2020 at 1:50 PM
    Zed
    Zed [OP] New Member
    Houston Texas
    2017 Brown 1794 Tundra
    I recently brough the hellwig rear sway bar, there are 3 settings on the bar "farthest away is the softest and closest to the bar is stiffer". I brought the bar for handling and better turning, I usually just drive on the highway. Any recommendation for which setting I should have it at?
  2. Dec 1, 2020 at 1:57 PM
    Saltyhero13
    Saltyhero13 Throbbing Member
    You want it stiff but test to see if you can handle it.
    HulkSmurf14 likes this.
  3. Dec 1, 2020 at 2:38 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    How much will you be towing? If you're maxing out, go with the most stiff setting...otherwise I'd stick with medium. I don't own one but this is merely a speculative assumption.
    yoshi82 and Saltyhero13 like this.
  4. Dec 1, 2020 at 2:46 PM
    19crewmaxTRD
    19crewmaxTRD Tundra Enthusiast
    Seth
    2019 white tundra crewmax
    I have mine set on the middle setting, it feels good enough that I haven’t tried any of the other positions.
  5. Dec 1, 2020 at 2:47 PM
    Saltyhero13
    If you have aftermarket shocks you may be better off on a lower setting but you can always reconfigure since its adjustable.
  6. Dec 1, 2020 at 2:54 PM
    Try it out at all three settings then stay with the setting you like best.
    tttrdpro and HulkSmurf14 like this.
  7. Jan 9, 2021 at 3:31 PM
    HaveFun
    HaveFun Happy to be here
    Fair Oaks Ranch, Texas
    2019 Black Tundra CM SR5
    Just bit the bullet on this sway bar. Which setting did you go with? How do you like it?
  8. Jan 9, 2021 at 5:30 PM
    Zed
    Zed [OP] New Member
    Houston Texas
    I have it on the middle setting and she handles way better. Turn almost like a sport car haha
    HaveFun[QUOTED] and Saltyhero13 like this.
  9. Jan 9, 2021 at 5:36 PM
    Yegcustoms
    Yegcustoms New Member
    E Town
    2018 SR5 turned TRD Sport
    2018 Tundra Sr5. TRD Exhaust, TRD Pro Suspension front and back. TRD Sport/ Pro hood scoop and bulge. TRD Pro black out badges. Katzkin Heated 2 tone seats. Fuel Rippers rims /32'' BFRH KO2.
    How do these affect towing a car trailer or Holiday trailer ?
  10. Jan 9, 2021 at 5:42 PM
    Zed
    Zed [OP] New Member
    Houston Texas
    I havent tow with it yet but I heard it helps a lot from what I read on here and other sites.
