33s on my 2nd gen?
Discussion in 'Wheels & Tires' started by 305TUNDRA, Jan 5, 2021.
  1. Jan 5, 2021 at 7:30 AM
    305TUNDRA
    305TUNDRA [OP] New Member
    2012 Crewmax XSP
    Hey all, I have a 2012 Crewmax 4x4 with no lift. I currently have the BBS 20x9 with +50 offset running 304/50r20 street tires. I can fit a fingers width between upper control arm and the tire right now. I am looking to put 33x12.5x20 on it and can’t find any information. Does anyone have any experience with this? I currently have 1” wheel spacers and a 2” level kit (front only) on order just in case. Any information would be appreciated
  2. Jan 5, 2021 at 10:45 AM
    MTRock
    MTRock 1889
    Montana
    2024 Tacoma TRD Off Road
    Katzkin Leather seats, JRI shocks, Rival aluminum skids, 285/70/17 outpost nat, Berger catch can, icon rear +.5 springs, gator trifold bed cover, Perry parts bump stops, switchback turn signals,
    Probably get a little rub on the skid plate? Easy fix. I’d say go for it!
  3. Jan 5, 2021 at 3:59 PM
    Half Assed
    Half Assed me ne frego
    Heartland Florida
    10 crewmax, 07 reg cab
    I think it will depend on the specific tire. A lot of the newer tire designs have tread on the edges of the sidewall which will rub the UCA. And of course measurements vary by manufacturer.
    Most people run spacers with 12.50s, but I have seen a few without.
    You might be able to get away with it with the +50 offset, since most OEM wheels are +60.
  4. Jan 5, 2021 at 4:01 PM
    MTRock
    MTRock 1889
    Montana
    +50 works gives you about 5/8 of an inch.
  5. Jan 6, 2021 at 5:06 PM
    leeross_76
    leeross_76 New Member
    Lee
    2010 Toyota Tundra Limited Crewmax 4x4
    Stock at the moment
    Yeah, I gotta a 2010 Crewmax with stock 18's. I have 20" wheels I'm switching to soon and probably going with 33x12.5 20 with a 3/2 readylift. Will I be good or is there anything else I need? The tires while probably be Firestone Destination M/Ts.
    I know very little about this stuff, I prefer stock, but setting it up for my son to have and doesn't want alot of lift.
  6. Jan 8, 2021 at 6:53 PM
    305TUNDRA
    2012 Crewmax XSP
    ***UPDATE***
    I added 1” spacers with no level kit installed and put 33x12.5 Venom Terra Hunter XT. I have 1.5” of wheel clearance to UCA and no rubbing anywhere. Not on skid plate or fender well. I did remove the forward and aft mud flaps but have 1” clearance when turned so not so necessary. Tires were road force balanced but truck has a severe shake at 50mph. It did have a weird shimmy before that was never figured out by Toyota dealerships so I will just look past it. May try and remove wheel spacers for sh*ts and giggles.
  7. Jan 9, 2021 at 3:57 PM
    Half Assed
    Heartland Florida
    check the lugs on the spacers again to make sure they are tight
    post pics of the 33x12.50s
  8. Jan 9, 2021 at 4:14 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    You need hub centric spacers, if you got lug centric they notoriously wont balance.
