Converting Transfer Case to Manual Controls
Discussion in '2nd Gen Tundras (2007-2013)' started by smiffy6four, Jan 9, 2021.
  1. Jan 9, 2021 at 2:06 PM
    smiffy6four
    smiffy6four [OP] New Member
    Pete
    Rebuilt rear diff, added Auburn limited slip Replaced transfer case bearings ECGS left front Diff bushing
  2. Jan 9, 2021 at 2:22 PM
    audiowize
    audiowize New Member
    Paul B.
    2008 Tundra SR-5 4x4 5.7
    DO IT! Subscribed!
    Silverghost and snivilous like this.
  3. Jan 9, 2021 at 2:28 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    God that'd be so nice. I hate electronic tcases. Personally I wouldn't buy that one you linked because probably nothing will convert over. The tcase side accommodations wont work, the cab side wont work, and it's triple sticks which at most you probably need twin sticks (4wd, and what range). So I think you'd throw out most of that $300, and end up just keeping two cables and two sticks which you could buy or make for way less.
  4. Jan 10, 2021 at 8:27 AM
    smiffy6four
    Pete
    I’m considering the 3 stick version, as it would give one for 2wd/4wd, one for hi/lo, and one for the front axle. I believe the cab end would work, with a small opening in the floor, for the cables and a grommet. The one I am looking at mounts on the floor, rather than in the floor.
    I’m also considering just making my own, as I would have to modify the TC connections anyway.
    Another possible vendor: https://www.northwestfab.com/Transfer-Case-Cable-Shifters_c_69.html
    Saltyhero13 likes this.
  5. Apr 21, 2021 at 7:09 PM
    AggiePhil
    College Station, TX
    Did you get this done?
  6. Apr 22, 2021 at 4:38 AM
    Dr_Al
    Dr_Al New Member
    Al
    I can only guess at what it would cost. Both the T-case and the front diff would need to be converted to accept cables. I think a cheaper solution would be to replace the T-case actuator with something more robust yet still electric. Something like two sealed linear actuators. Then bypass the computer. Nothing like the good old days when you had one lever and manual locking hubs though. Simple is often best.
    Silverhorse, equin and Silverghost like this.
  7. Apr 22, 2021 at 5:27 AM
    jbrnigan
    jbrnigan New Member
    Midwest
    2007, 5.7L, 4x4, Crewmax,
    If the electronic / electric 4WD controls are a source of "continuing" / problematic shifting issues, then a manual solution is probably worth the cost and conversion aggravation. Also, if your 4WD usage could be classified as extreme or severe, manual controls, locking hubs and levers might be more reliable when "wheeling". Otherwise, the Toyota electronic system is VERY reliable and robust. I remember the "good old days", and looking back, they weren't so good compared to todays fully automatic 4WD systems.....(ever forget to lock in your hubs?)
  8. Apr 22, 2021 at 9:06 AM
    audiowize
    Paul B.
    I sure do miss pulling over in the snow on some of the super narrow highways around here to get out to lock the hubs with traffic whizzing by.
    Danny3737 likes this.
  9. Apr 22, 2021 at 9:30 AM
    Danny3737
    Danny3737 New Member
    2012 Tundra Limited Platinum
    I remember those days
  10. Apr 22, 2021 at 1:42 PM
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
    1991 White Xtra-cab SR5 4X4 V6 5 speed 148K
    Never. When the first snow hit, I'd lock the hubs and keep them locked until the last threat of snow. I prefer a t-case with a manual shift. I don't trust an electric one with a light telling me it's engaged or not. Not a perfect analogy but would you trust an idiot light for oil pressure or if it's about to overheat? There's no doubt it's in 4WD when you throw a lever into gear.
    snivilous and Silverghost like this.
  11. Apr 22, 2021 at 2:39 PM
    jbrnigan
    jbrnigan New Member
    Midwest
    then, converting to levers and cables and manual hubs is just for guys like you.....mechanically oriented craftsmen can make it happen (whether they can buy a conversion or craft their own, see post #1)....for the rest of the MILLIONS of us, turning a dial or pushing a button will suffice. Or buy something else.
  12. Apr 22, 2021 at 5:13 PM
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
    I don't mind the auto locking hubs. I've had two 4X4's like that. I don't like turning a knob and hoping it engages. I've read plenty of threads about the electric actuator problems on Tundras. I've never had an issue with a manual transfer case.
    snivilous likes this.
  13. Apr 22, 2021 at 6:21 PM
    jbrnigan
    jbrnigan New Member
    Midwest
    because....the "hubs" on your Tundra, Tacoma, and many other makes, don't auto lock or unlock! They are mechanically connected to the axle shafts and engaged by Toyota's ADD in the differential at the same time the ADD shifts the transfer case. Only on earlier model Toyota's w/o ADD could you have free wheeling hubs.
    Ford (some models - Super Duty's) has an interesting twist to their electronic 4WD.... their hubs can be manually locked, or they will lock via vacuum actuator, but still use electric actuators to control their transfer case and differential disconnects.
  14. Apr 22, 2021 at 6:49 PM
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
    My last Chevy and Dodge 4X4's both had actuators to lock or unlock the hubs. The Dud was vacuum and the Chev was electric. They both had manually shifted t-cases. My last Ford was manual everything in the drive line. My two previous Toyota 4X4's were both with manual hubs and t-cases
    Just saying what my preference is all.
  15. Apr 22, 2021 at 7:15 PM
    snivilous
    SW UT
    I would be totally happy with the front diff permanently engaged and manual controls on the tcase, saving a fraction of a mpg is not of a concern to me. I've had multiple times now where the abs line got ripped, or there was a cut in the abs line sheathing and corrosion destroyed the wire, etc. I've never had issues with the actuators themselves, besides being painfully slow at times, it's the utterly stupid computer logic that disables 4wd or shifting in/out of low range that I hate.
    bleach likes this.
  16. Apr 23, 2021 at 5:51 AM
    smiffy6four
    Pete
    I did get it done. It works great!
    I’ll put together some pictures and do a write-up soon.
    joseph_womack, equin and jtwags like this.
  17. Apr 24, 2021 at 10:03 AM
    Dr_Al
    Dr_Al New Member
    Al
    What back when the auto hubs would lock in when you shifted into 4wd and the axle inside the hub started to spin. The problem was it would unlock then lock back in if you shifted into reverse and you couldn't shift in and out of 4wd while on the highway. Those old manual hubs just required some planning ahead. If driving down the interstate at 55 with them unlocked and your rear tires started to spin 4wd wasn't going to save you. At the same time if you did have them locked in all you needed to do was grab that lever and pull it. No delay while waiting for a computer to decide. Also if the rear wheels are spinning the front diff may not fully engage on the new style where as on the old trucks you just pulled harder. Finding a lever right next to the sifter (back when sticks were common) is much easier than finding a knob on the dash to turn when in a panic.
  18. Apr 24, 2021 at 10:09 AM
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
    That's why I kept them locked all through winter, sometimes even a little before and after. It never hurt anything to drive that way.
  19. Apr 24, 2021 at 10:14 AM
    joseph_womack
    joseph_womack @ 4x4bound
    Joe
    Louisiana
    2007 RCLB, 4WD, 4.7L V8
    What about trying to take the manual shifter from the new 4runner and swapping iin those components, that could potentially fit better or maybe paired with the 4Runner TC and it might be plug and play?
  20. Apr 24, 2021 at 10:15 AM
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    Looking forward to pictures and your write-up! I once did a manual conversion on a '93 Ford full-size Bronco. That was easy, though, because while some Broncos came with an electric t-case, others came with a manual. So it was just a matter of finding a manual t-case, linkages and shifter from a salvage yard and slapping it all together. Curious to hear about your project!
  21. Apr 24, 2021 at 10:46 AM
    NueveTundra
    NueveTundra Mod list in Bio
    Planet Earth
    07, Black Tundra SR5 CrewMax
    Exterior: Toytec ultimate 3" lift level, Total Chaos Uniball UCA's, Total Chaos Cam Tab Gusset kit, AcanII smoked headlights, AcanII smoke Tail lights (2.5 gen style), DV8 front winch bumper , Badlands 12k winch with Apex Synthetic, White AUTMATCH Shackles 3/4" D Ring Shackle, Apex Winch shackle, Trail Ridge mirrors ,Icon Rebound Pro 17"x8.5" +25, Cooper Discovery STT Pro 285/70R17, PowerStop drilled n slotted rotors W/Carbon pads, Rigid flood flush mounts rear bumper , WeatherTec rain guards , OEM black side badges , Rigid Amber Radiance Pods. Energy Suspension Red Rack and Pinion Bushings, EAG front mesh Grille, RCI HighLift bed mounts. Rough Country DS2 Steps, A.R.E OverLand Canopy with Ascend basket, Stickers: ToyTec lifts windshield banner, Red Strange Music window sticker(back cab), White Strange Music sticker(back canopy), White Rigid sticker x2 (canopy sides), white Official BigFoot Research Team (Back Canopy) Interior: Alpine double din touch iLX-650 , JL C5-653's (front) JL C1-650x (rear) , JL JX400 4 channel amp , JL JX500 mono amp , 2 JL 12" subs , WeatherTec floor mats, Kenwood F/R Dash Cams, Black steering wheel emblem overlay, Tekonsha P3 Brake controller, ToyTec "Fresh" Scent coilover air freshener, Under the Hood: Koyo all aluminum radiator, Mishimoto red silicon hoses , XS Power 3000 amp battery , LAlectric 300 amp Alternator , K&N replacement filter. Online LED store accessories Fuse/relay box. (Identified) Dirty Deeds 8" Cat back exhaust with DD resonator delete/axel over converted into dump. Coming soon:
    Didn't the FJ's have levers? Wonder what all FJ parts might come in handy or could be adapted for the lever system.
    I'll definitely watch this forum thread. :)
  22. Apr 24, 2021 at 11:26 AM
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
    My last Ford 4X4, a 94, was all manual, even the hubs. It came with a Mazda built 5 speed from the factory which a seriously weak link in the driveline, especially behind a 5.0L V8. It was already on it's second one and failing again when I got it. I swapped in a 5 speed from a 3/4 ton, a ZF and it was an easy bolt in. The, internal to the bellhousing, concentric clutch slave was another horrible thing I ended up dealing with later. I got rid of that POS truck before it completely failed.
    equin[QUOTED] and joseph_womack like this.
  23. Apr 25, 2021 at 12:56 PM
    equin
    Ed
    DFW, TX
    I had a love/hate relationship with mine. It was great - when it would start and run without breaking down. It was perfect for hauling the kids and dog around, camping and off-roading with its short wheelbase and great turning radius. But before my BIL bent the frame and totaled it, mine went through two transmissions - the E4OD. The piece of junk transmissions Ford would put in their trucks is almost criminal. I replaced them myself in my driveway with salvaged ones as I cursed Ford not only for their poor quality trans but also for how difficult they made it to work on. Jeep and Toyota were far better at allowing access to parts and bolts than Ford was. I don’t know how Ford is now, but sadly my Tundra is a bit harder to work on than my old 92 4Runner and 1st gen Tacomas. But I guess that’s how things are now with newer computerized tech a fuel/mileage/emissions requirements.
    bleach[QUOTED] likes this.
  24. Apr 25, 2021 at 1:18 PM
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
    The '94 was mostly very easy to work on when you didn't break three more items that were in the way to the one you were fixing.. The transmission/transfer case bolts were easily accessible but very awkward and heavy to lift back into place.
    equin likes this.
  25. Dec 27, 2022 at 8:59 PM
    OneEarTim
    OneEarTim New Member
    2007 Tundra TRD
    @smiffy6four
    Any news on this? Looking to do it myself as my 2007 stop switching on a snow trip. It really put us in a pickle. One hour drive in took four hours and a lot of winching to get back out.
    I'm not too concerned with the hardware side of things. But, mostly interested in how the electrical system possible problems and how you overcame them. Thanks
