Toyo AT3s
Discussion in 'Wheels & Tires' started by Walleye1875, Jan 8, 2021.
  1. Jan 8, 2021 at 6:03 PM
    Walleye1875
    Walleye1875 [OP] New Member
    16 Limited Crewmax Midnight Black
    I have a 2016 Toyota limited crewmax that is completely stock. I don’t want to do a lift or level and want to keep the stock tire size. Will the toyo open country AT3s look a bit much if I keep the stock size? I don’t want it to look overkill or to aggressive if that makes sense. Does anybody have these on their trucks in the 275 65 18 size? Thanks
  2. Jan 9, 2021 at 8:51 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    No they will not look too aggressive. Search- there are plenty of pictures of trucks with those installed on this site.
  3. Jan 9, 2021 at 8:52 AM
    Walleye1875
    I did, couldn’t find any stock size 275 65 18. Almost everybody goes up a size which I don’t want to do.
  4. Jan 9, 2021 at 9:01 AM
    frichco228
    Frank
    Virginia
    Well they will look identical, just slightly smaller
    Same size here, slightly different Toyo tire but will give you an ideas of how that size looks on a Tundra- https://www.off-road.com/blog/products/toyo-open-country-c-t-review/
    and here is a pic from tundras.com site with 275/65s
  5. Jan 12, 2021 at 8:55 PM
    Walleye1875
    White truck is very helpful. Thanks
  6. Jan 12, 2021 at 9:21 PM
    jalam321
    jalam321 New Member
    2018 Tundra CM Platinum 4x4 and Sequoia Platinum 4x4
    I think it will look fine. Go for it
