Tundra jammed lock on tundra safe
Discussion in '2.5 Gen Tundras (2014-2021)' started by Sakana65, Apr 21, 2019.
  1. Apr 21, 2019 at 8:56 PM
    Sakana65
    Sakana65 [OP] New Member
    Gary
    2017 Pearl blue trundra
    Has anyone encountered any issues with the combination lock being jammed. My lock is jammed, I can’t clear the combination nor turn the lock even with the key in. Any suggestion, I left a message with the manufacturer.
  2. Apr 22, 2019 at 12:23 AM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    is it possible something is putting upward pressure on the top that might be binding the lock mechanism?
  3. Apr 22, 2019 at 5:18 AM
    Sakana65
    Gary
    Unfortunately I did not clarify it is jammed in the open position.
  4. Dec 3, 2020 at 11:24 AM
    Ncreator74
    Ncreator74 New Member
    2018 White XP Tundra
    Hi Sakana65
    Did you get the problem fixed? This might be related to my issue. My issue is with the door closed.
    I recently bought my truck used. I didn't cross my mind to open during the test drive. The seller is an hour away from home, so I wanted to try myself first to be sure is not something simple.
    I don't know the combination. The key works and is able to turn the lock. If you do it slowly, you can even feel when the cam is engaging and disengaging. However, the door is shut, there is no movement at all.
    I wonder if your solution may help.
    Thanks.
  5. Jan 9, 2021 at 6:42 AM
    34ford
    34ford New Member
    2018 sky silver DC 5300 miles
    none yet
    You need to turn to the open position w/ knob . Put a small screw driver between front of lid of vault and trim in front of lid. Pry up easy as you pull up on finger tab. Lid is just stuck shut. Had same problem and this was the fix! 34ford
