Potential 03 purchase
Discussion in '1st Gen Tundras (2000-2006)' started by kidked888, Jan 8, 2021.
  1. Jan 8, 2021 at 3:04 PM
    kidked888
    kidked888 [OP] New Member
    Kansas
    2004 Tundra Double Cab 2WD
    More feedback again please on the rust frame and paint of the door. To me rust just looks surface from pictures I was sent. And dealer said when the car was detailed the paint on for was burnt in and he got it as good as he could. Any remedies other than re-painting? 171k on it currently, dealership is wanting 8k
  2. Jan 8, 2021 at 3:45 PM
    Not bad at all. You could easily wire brush the surface rust and cover in POR-15 or just regularly coat in in fluid film yearly.
    Check out the condition of the pickup bed floor and it’s underside to make sure the rust isn’t getting through and it’s not in bad shape.
    Hbjeff and N84434 like this.
  3. Jan 8, 2021 at 4:47 PM
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
    Pretty clean, overall. That paint graphics on the doors would be a task, but not impossible to fix..
  4. Jan 8, 2021 at 4:50 PM
    ezdog
    ezdog New Member
    Gateway To The West
    2001 RCLB V8,4WD 2015 RCLB 5.7,4WD
    You could always start a company with the same name too?
    Darkness, FirstGenVol, N84434 and 4 others like this.
  5. Jan 8, 2021 at 4:54 PM
    04DCTundraMan
    04DCTundraMan Crimedog McGriff
    2004 Salsa Red Tundra Limited DC
    Sony Head Unit, Pioneer Speakers, Back up camera, Blacked out Emblems, SPC Control Arms, OME 2.5" front lift, 1.5" rear spacer, Flowmaster Super 44 muffler, LineX bedliner
    I think this would be the best option.
  6. Jan 8, 2021 at 5:21 PM
    PenderBen
    PenderBen Forum lurker…
    Gulf Islands, BC Canada
    2003 Tundra AC 4x4
    The rust doesn’t look too bad to me, but in need of remediation, which to do right is a fair amount of work, and a certain amount of expense.
    If you check it out, give the diff cover a close look to make sure it’s not rusting through.
    Parking brake cable looks like it needs to be adjusted, but should be a big deal (I’ve never done it, but looks easy reading about it)
    I don’t know that it has any significance, but the leaf springs look oddly splayed to me, maybe just the angle?
    Doesn’t look too bad from here overall, but see if you can talk them down to because of the rust and paint.
  7. Jan 8, 2021 at 9:15 PM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    You can always wrap the top half of the truck in black and offer the dealer 7K. Check when the water pump and timing belt was done. Good chance you will have to replace once purchased. Should be a sticker on the air box.
  8. Jan 9, 2021 at 6:44 AM
    Good looking rig, rust looks surface, but poke around in the trouble zones for sure. If all else seems up to snuff with the truck maintenance wise, I would be down for $6500-$7500. Need to inspect that lift and make sure it's solid and not in need of re-do or re-engineering. I just don't understand why the windows are dirty on the truck.
    Darkness likes this.
  9. Jan 10, 2021 at 3:14 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    Check the frame visible from the front wheel wells. That's where I found my problem.image3.jpg
    Darkness and kidked888[OP] like this.
