  1. Jan 7, 2021 at 5:27 PM
    TrashcanBand
    TrashcanBand New Member
    CenTex
    Tundra
    100% agreed. Just yankin your chain. :thumbsup:
    JerryH[QUOTED] likes this.
  2. Jan 7, 2021 at 5:58 PM
    War_Wagon312
    War_Wagon312 Puddle Dodger
    Rich
    2016 Pro MGM CM
    Toyo MT 285/70/R18, led's all around, Baja Design squadron sport fogs, spider trax 1.5 spacers, led foot well lighting, interior chrome delete, kc hilites 40inch light bar grill mounted, 20%tint all around, color lugs black lugnut caps, 2019 pro head lights, led lights all around, spyder co tail lights, DMX1057xr, super crew box with kicker 10” sub,jbl door speakers, factory amp bypass trd air flow accelerator with drop in filter, x3 battery, Toyota bed cover, swing case,
  3. Jan 7, 2021 at 6:01 PM
    War_Wagon312
    Rich
    2016 Pro MGM CM
    Friendly FYI. Be careful when you are tightening them down. The tabs aren’t as robust as stock and they snap/crack. Self correcting mistake.
    KingsAustin[QUOTED] and ElNopal like this.
  4. Jan 7, 2021 at 6:09 PM
    jtulo85
    jtulo85 New Member
    J
    2020 Toyota Tundra XSP
    Bilstein 6112s up the front leveled setting and 5118s in the rear CaliRaised LED switch panel custom mounted in a case under hood S&B Cold Air Intake ARB Diff Breather Interior Chrome delete by AJT Design Lightbar custom mounted in the hood bulge RC 2'pods mounted CalirasedLED hood low profile brackets
    BuckeyeChuck likes this.
  5. Jan 7, 2021 at 6:12 PM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Pro suspension, sways
    I can 2nd this recommendation. Bill and his team are tops in customer service and satisfaction.
    I worked with him through the Waterbury location, you too?
    pvn.beluga[QUOTED] likes this.
  6. Jan 7, 2021 at 6:18 PM
    jtulo85
    jtulo85 New Member
    J
    Looks great... I am looking at grabbing one for my Tundra just waiting to see if they do color match soon.
  7. Jan 7, 2021 at 6:24 PM
    Pillslinger
    Pillslinger New Member
    Rollin
    SWMO
    2018 Cement TRD CrewMax
    Bed light kit Jerry can mount Badge overlays (removed 2021) Pin stripe / TRD decal / pillar vinyl removal Raised tailgate lettering Center console badge/tray/divider Interior/exterior LED upgrade VLED footwells TVD Vinyl TRD Offroad wheels Icon 17x8 rebound titanium Bubbas Garage grab handles WeatherTech floor mats (Eagle Klaw added) Rough country front shackles (removed 2021) DD SS3 yellow fogs MESO map light replacement Softopper MESO Chrome delete
    This. A buddy had his new ram pickup (5yrs ago) start into this kind of weird electrical stuff. Dash lights, wipers, turn signals, radio. Then it would vanish and everything be perfect for a month. Difficult to diagnose "cause the dealership couldn't reproduce it. Eventually the dealership bought it back from him.
  8. Jan 7, 2021 at 6:40 PM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    I have the TRD BBK and they are an excellent upgrade for the towing. I towed my mini excavator (7500# machine and 1500# tip trailer ~ 9000# total) with and without the BBK and it is noticeably better with more powerful brakes. It is less pedal effort to get the same result of braking with normal driving, but when towing and you push hard on the brakes, the BBK doesn't get overwhelmed, it puts down the hammer, and stops the truck with confidence and control. Before (no BBK) I felt like the trailer would push the truck past my anticipated stopping distance, where as the BBK allows a much more predictable distance with much better control.
    I have aftermarket wheels and even though they are 20" I still needed a 3/16" spacer to clear the calipers. Not a big deal but definitely something to consider. It is best to pick up a 20" spare too. If not, you'll have to move a rear wheel up and put the spare on the rear to make it home. Also, consideration of balancing the tires needs to be thought out because balancing weights placed towards the outside of the inner wheel can interfere with the calipers too. I have oem Platinum wheels that clear with no problem, it's just aftermarket wheels that have some offset/clearance issues.
    The pros far outweigh any small issues I had getting aftermarket wheels to fit, and I would strongly recommend. I was fortunate to get my TRD BBK when Toyota did their 40%off TRD products in 2019 for about $1600. I think 17' was the last year TRDs were available for, but Stoptech built the TRDs for Toyota, so I would definitely look at those for your 2020
    No complaint with pads so far... only 20K on the kit and they are still like new, but they will wear faster the more towing you do.
  9. Jan 7, 2021 at 7:02 PM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    Yup! Waterbury location. Was glad when I found out there was a Line-X shop right by Terryville/Bristol.
    Rica25 and Toyotoholic[QUOTED] like this.
  10. Jan 7, 2021 at 7:42 PM
    Kdogg77
    Kdogg77 If it ain't broke, it will be...
    Ken
    Central Cali
    2017 Tundra Crewmax
    6" RC suspension lift, 18" Pro Comp wheels, 35x12.5x18 tires, RC front/rear bumpers, RC Grill insert, Spider No Drill Roof Rack, Lighting by RC and Cali Raised. Interior mods include AJT Designs, Pioneer, and Rockford Fosgate.
    I hit the same mileage Monday. Forgot to take a pic though...lol.
    Fotnot[QUOTED] and Rica25 like this.
  11. Jan 7, 2021 at 7:54 PM
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    :facepalm:
  12. Jan 7, 2021 at 8:33 PM
    TomC843
    TomC843 The wheel weaves as the wheel wills.
    Tom
    Charleston, SC
    16, 4X4, 4U3, Katzkins, Flowmaster, ARE MX, Swing cases, TRD skid plate, Volant CAI....
    Can we get a quick run down on the install.
    biebs96, yodanadane and Rica25 like this.
  13. Jan 7, 2021 at 9:12 PM
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
  14. Jan 7, 2021 at 9:37 PM
    Flanny2789
    Flanny2789 New Member
    2019 Cement Gray Crewmax
    Black badge overlays, TRD Exhaust
    Gonna put my new TRD Pro Grill on tomorrow. Three months of waiting and it’s finally here!
  15. Jan 7, 2021 at 9:39 PM
    RobertD
    Robert
    DFW, Texas
    Rica25 and saybng[QUOTED] like this.
  16. Jan 7, 2021 at 11:37 PM
    Part_time
    Part_time Not a new member
    Oregon
    2017 MICA BRONZE SR5
    Were did you get it.
    Rica25 likes this.
  17. Jan 7, 2021 at 11:38 PM
    Part_time
    Oregon
    Where did you get it and what options web site looks impressive
    Rica25 likes this.
  18. Jan 7, 2021 at 11:54 PM
    BamaMan44
    BamaMan44 Roll Tide Roll! Bama Fan till I die! & Go 'Hawks!
    Andre
    Tucson
    Trailbreaker - 2017 Black CrewMax SR5 4x4
    Not sure. I'll let you know when I get out of quarantine and can go check out the bars.
    Rica25 and NewImprovedRon like this.
  19. Jan 7, 2021 at 11:55 PM
    BamaMan44
    Andre
    Tucson
    Thanks Jim!
  20. Jan 7, 2021 at 11:56 PM
    BamaMan44
    Andre
    Tucson
    Thanks! My pleasure!
  21. Jan 8, 2021 at 5:33 AM
    JerryH
    JerryH Gravy Boatin, I don’t park I dock.
    SOMD
    2020 Crewmax Limited Cement
    Did you go with Sparks or have it painted yourself? Love that color!
    Rica25 likes this.
  22. Jan 8, 2021 at 6:01 AM
    Doccountry69
    Doccountry69 New Member
    Mark
    Little Elm
    2020 Tundra Voodoo Blue
    Rica25 likes this.
  23. Jan 8, 2021 at 6:18 AM
    James07
    James07 New Member
    James
    Maryland
    2017 CM Platinum in Super White
    Ready Lift 3/2 General Grabbers ATX 35x12.5x17 Icon Alloys Rebounds 17 Window Tint Line-X Bed 32" Rigid Light bar in Bumper Stubby Antenna VLED under dash lights A-Pillar Grab handle Blacked out exhaust tip Shovel/Axe bed mounts
    @JerryH - I bought from McGregory Toyota out of TN because they had the best price and Roman shop was still closed for out of state buys.
    Rica25 and JerryH like this.
  24. Jan 8, 2021 at 6:32 AM
    Doccountry69
    Mark
    Little Elm
    First mod for a slow build...I don't have the funds most of these guys have...lol
    WFD473, GAknight, Wallygator and 8 others like this.
  25. Jan 8, 2021 at 6:40 AM
    TNTundra16
    TNTundra16 YOU BIG DUMMY!
    Cam
    Amish Country, TN
    2016 CM SR5 4x4 SSM
    New grille?
    Rica25 likes this.
  26. Jan 8, 2021 at 6:42 AM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    You do you man. Is that a grill?
    Blue Thunder and Rica25 like this.
  27. Jan 8, 2021 at 6:46 AM
    Doccountry69
    Mark
    Little Elm
    Yup, color match grille surround and hood bulge
  28. Jan 8, 2021 at 6:52 AM
    TNTundra16
    Cam
    Amish Country, TN
    2016 CM SR5 4x4 SSM
    Jcmf52 and Rica25 like this.
  29. Jan 8, 2021 at 7:03 AM
    JerryH
    SOMD
  30. Jan 8, 2021 at 7:06 AM
    BlueRibbon4x4
    Geno
    2015 Blue Ribbon 4x4
    Man, I really don’t ever get tired of that Voodoo.
    Vuducrumax, Bama, TNTundra16 and 3 others like this.
