2020 suspension air bag set up
Discussion in 'Suspension' started by Beagletundra, Jan 7, 2021.
  1. Jan 7, 2021 at 12:26 PM
    Beagletundra
    Beagletundra [OP] New Member
    2020 white tundra
    Hello,
    I am looking for the best set up for my 2020 Tundra. What little I know I was thinking a leveling suspension kit 1.5 front 2.5 rear with airbags to assist with loads. I wanted the lift primarily for looks. I don’t do any off road. I do pull trailers and want some help for the rear. Any suggestions on setups would be appreciated.
    thank you
    Oey12 likes this.
  2. Jan 7, 2021 at 2:23 PM
    Oey12
    Oey12 New Member
    Joey
    New York
    2020 SR5 TRD OFFROAD
    I had airbags on a 2012 Tacoma...I understand that’s it’s a different truck but I believe the biggest con will be the same. The ride quality when empty. Even at 5 psi the ride was jarring. I would look at Timbren SES system or the Sumosprings for the occasional towing. The Timbrens were set and forget it but they did have a kickback to them on the larger potholes. I heard the airbags with cradles are better but I don’t have any experience with them.
    In all honestly if you want to lift it do it equally meaning same front and back (due to towing and let the truck sag REASONABLY). All of these systems have drawbacks so chose wisely...
    I forget to mention that airbags work great under load. The ride was more controlled and sure footed.
