Tallest tires compatible with stock 20 inch wheels
Discussion in 'Wheels & Tires' started by alextrg42, Jun 3, 2020.
  1. Jun 3, 2020 at 3:21 PM
    alextrg42
    alextrg42 [OP] New Member
    Alexander
    2017 1794 edition Toyota Tundra, 1.5 inch spacer levelling kit
    1.5 inch levelling kit Cat back exhaust
    Hi
    I've been searching for answers with no luck....would greatly appreciate your help.
    I have a 2017 Toyota Tundra with a 1.5 inch ready lift levelling kitt.
    My stock tires and wheels are 275 55r20.
    I wish to run 285 60 r20 tires. With stock wheels. Is this possible? I do not mind any kind of trimming if needed.
    I have read for every inch of lift you gain one inch of height. My current tires are 31.9 inches tall.
    And I believe I would only be adding 0.7 inches in width by going from current tires to 285 60r20s.
    Thanks in advance
  2. Jun 3, 2020 at 6:55 PM
    somecrazyguy
    somecrazyguy New Member
    Steven
    New Braunfels TX
    2020 Limited 4x4 Crewmax Silver Sky
    Size change would be from 31.9 to 33.5 according to tiresize.com/calculator. I have read the mud flaps have to be removed or pushed out of the way for the changes you are considering. Best of luck!
  3. Jun 3, 2020 at 7:12 PM
    alextrg42
    Alexander
    Thank you .. that is all I needed to know before emptying my wallet to purchase the tires.
  4. Jun 3, 2020 at 8:45 PM
    BRP479
    BRP479 New Member
    Ricky
    Rogers,AR
    I am on stock suspension. Had 285 55R20 from dealer and now have 275 60R20. No rubbing on either. Can’t tell the difference really between the two tires
  5. Jun 3, 2020 at 9:06 PM
    alextrg42
    Alexander
    275 60 R20 is 33 inches tall and has a width of 10.83 inches. Do you think you could possibly go up to 33.5 inch tall tire with a width of 11.5 inches?
    And how about if you kept the width at 11.5 inches and bumped up the diameter to 34.5 inches...
    I know lots of people will say get a suspension lift, but currently I can not afford that sadly.....but hoping to one day get the bds 7 inch lift installed
    So what do you think.....what is tallest tire I could go with? Appreciate your input
    Thank you
  6. Jun 3, 2020 at 9:39 PM
    linwozzle
    linwozzle New Member
    Linden
    2014 SW Tundra Platinum 4x4 CM
  7. Jun 3, 2020 at 9:43 PM
    alextrg42
    Alexander
    Thank you that sure shed some light on my confusion....
  8. Jun 5, 2020 at 5:35 PM
    BassBlaster
    BassBlaster New Member
    Jay
    2016 silver 1794
    Bilsteins front and rear
    somecrazyguy likes this.
  9. Jun 17, 2020 at 2:05 PM
    calebd94
    calebd94 New Member
    Caleb
    Charlotte, NC
    '19 Tundra Crew Max 4x4
    I just got 275/60r20 Ridge Grapplers yesterday. Sitting on what I think is a 2" leveling kit that was installed prior to me owning the truck and rubbed what I think to be the skid plate pulling out of the vet's office earlier (ultimate mall crawling action). It wasn't a super weird transition to the parking lot to the road so i was a little confused but I guess I'll see if it keeps happening and address it if so. I haven't rubbed going in and out of my driveway and the approach angle pulling out of it is super steep.
  10. Jan 5, 2021 at 4:19 PM
    Solace_In_My_Tundra
    Solace_In_My_Tundra New Member
    Out there somewhere
    2020 MGM CrewMax
    Tonneau Cover TRD Pro Grille Bumper Shells Color matched Bulge Bilstein 5100 Ceramic Tint Black Tundra Inlay
    how are these going? Are these the E-rated LT tires or the P-rated XL? Thanks
  11. Jan 5, 2021 at 8:30 PM
    Team4M
    Team4M New Member
    Anthony
    2016 - Tundra - 1794 - Black
    Bilstein 6112 / 5160 lift
    You should be ok with a chance you’ll need to bend up the corners of the skid plate and possibly push the front liners forward.
    Super easy to do and gives plenty of room.
    I went with 285/65/20 but had some room to play with since I went with billstein 6112s up front. I hope this helps!
  12. Jan 7, 2021 at 11:13 AM
    calebd94
    calebd94 New Member
    Caleb
    Charlotte, NC
    I still love them, I ended up dropping the skid and cutting it because I live in an Urban area and navigating parking garages with only 75% of my turning radius without rubbing wasn't working out well. But that took care of the problem and I still love the setup. They are the XL rated as I don't think you can go larger without running an E-rated tire. I'm contemplating going larger on the next set but not 100% sure I want to deal with the roughness of the E-rated tire. I came from a duramax and the standard load tires make a world of difference in ride comfort...
