Make my 2020 SR5 able to pull a 5th wheel
Discussion in 'New Member Introductions' started by DrNorthCool, Jan 4, 2021.
  1. Jan 5, 2021 at 6:42 PM
    koditten
    Kirk
    Midland of the Mitten
    I drag a 8500lbs 5er with my double cab. I have no idea what the pin weight or my total load is. It does it fine. I'm not in a hurry. The bed is not squaring.
    I see lots of bigger 5ers being hauled with Ecoboost .
    My next truck will be a crewmax with a slider hitch.
    Until you have actually hauled bumper pulls and 5ers and compared them, you will have no issue being a little over with a 5thwheel.
    The brakes comments don't wash. The trailer has its own brakes. A 1 ton dragging a small 5er with no brakes on the trailer is going to be a very bad situation.
    In my experience, the main weak link in the Tundra is the rear wheel bearings. I've replaced mine. I don't know if it's the trailer hauling, but just looking at them, they are not heavy duty bearings.
    In addition, I'm pretty sure Toyota knows we are gonna over load the truck bed. Why else would they have given us adjustable headlight angle from the cab?
  2. Jan 5, 2021 at 6:44 PM
    knoxville36
    knoxville36 New Member
    Knoxville, TN
    2024 GMC Sierra 1500 Elevation w/3.0 Duramax
    Depends.... The issue is that once you get into a tandem axle travel trailer, they are usually larger to begin with and for the most part weigh more.
  3. Jan 5, 2021 at 6:50 PM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Yeah, I was just thinking if you looked at two trailers that were identical other than the number of axles. My parents in law have a ~17 foot (if I recall correctly) Forest River with two axles.
  4. Jan 5, 2021 at 6:53 PM
    knoxville36
    Knoxville, TN
    Yeah not sure. Would be interesting to see two exact same trailers. 1 axle then 2, more importantly I think it would depend on where exactly that single or double axle were placed on the trailer. Would be tough to tell for sure.
  5. Jan 5, 2021 at 6:57 PM
    glowblue
    glowblue From time to time
    VA
    I really don’t care what anyone says, if I had some serious towing needs I’d go with a 3/4 or 1 ton, nothing against the Tundra, this would apply to any 1/2 ton. The Tundra in my opinion is the best 1/2 ton on the market!
  6. Jan 6, 2021 at 5:12 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    Yep, look at single axle trailers they are pretty small. My current boat with duals weighs in at 5000 lbs. My Ranger with a single axle was 3200. I have not checked the hitch weight but 2 people would struggle to lift the hitch. At one time I could lift the hitch on my Ranger. Easy way to settle this is to go check some specs on TTs.
  7. Jan 6, 2021 at 1:14 PM
    Catmann1972
    Catmann1972 New Member
    Greg
    Rhode Island
    2020 TRD Sport
    So what you are telling us is that you tow a 5th wheel TT with your Tundra. Interesting, any chance you have a pic of the set up. If you don't want to post it, due to the possible back lash, could you send me a PM with the pic. I am interested and perplexed at the same time, due to the Tundra weight numbers they have. I tow a 28' TT with my tundra and the wife wants to upgrade to a 5er, but I ran the numbers and they don't work out for the Tundra. I just bought my Tundra 6 months ago, i have no interest in getting a 3/4 ton truck anytime soon. My truck currently sits in the driveway 80% of the year and we only use it to go camping 5-6 times a year.
  8. Jan 6, 2021 at 1:16 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    Yes.
    If you want to tow a 5th wheel, sell the Tundra and get a bigger HD truck.
    Cpl_Punishment likes this.
  9. Jan 6, 2021 at 1:42 PM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Exactly this. There's a reason that none of the truck manufacturers offer a gooseneck hitch package for their 1500/150 trucks.
  10. Jan 6, 2021 at 1:58 PM
    GreatBigAbyss
    GreatBigAbyss New Member
    2018 Tundra CrewMAX SR5 TRD Off-Road
    What I'm hearing is a guy who is towing a too-big trailer for his truck, who has zero idea what his real weights are. This is the kind of guy who will end up like this guy one day:
    https://www.youtube.com/watch?v=SfEFAVF1CGQ
    GODZILLA and BravoDeltaRomeo like this.
  11. Jan 6, 2021 at 2:06 PM
    Catmann1972
    Greg
    Rhode Island
    2020 TRD Sport
    Here is the problem with this video...the 1/2 ton pick up truck in the video is a FORD. The 5er is WAY to big for that truck in the first place. They make 5ers in a resonable size
  12. Jan 6, 2021 at 2:09 PM
    GreatBigAbyss
    It's a 3/4 ton...
    And look up just how big an 8500lb fifth wheel actually is. They're not small.
  13. Jan 6, 2021 at 2:12 PM
    Catmann1972
    Greg
    Rhode Island
    2020 TRD Sport
    Are you sure...looks like a 1/2 ton, tough to tell on its sider though. I'm sure there has to be a reason why this happened, other than the fact that it's a 5er and a possibly wrong size truck. Guess anything can happen when towing, no matter what you are towing. from a fifth wheel to a row boat.
  14. Jan 6, 2021 at 2:16 PM
    GreatBigAbyss
    Definitely a Super duty.
  15. Jan 6, 2021 at 2:17 PM
    PlatinumPro
    PlatinumPro New Member
    2015 PlatinumPro Crewmax
    Bilstein 6112+5100s, Rigid Lighting, Fuel 20x9 Bronze Blitz
    agreed. not to mention, i'm pretty certain the parameters set by Toyota are based on stock everything. OP mentioned that his intention was to add bags which would beef up the capacity that much more.
  16. Jan 6, 2021 at 2:18 PM
    Catmann1972
    Greg
    Rhode Island
    2020 TRD Sport
    Guess it's NOT so Super after all
  17. Jan 6, 2021 at 2:20 PM
    Catmann1972
    Greg
    Rhode Island
    2020 TRD Sport
    Actually air bags will NOT increase any capacity of the truck. They will just help level the truck after the trailer is on the truck.
  18. Jan 6, 2021 at 2:27 PM
    PlatinumPro
    that makes sense. i appreciate the info!
  19. Jan 6, 2021 at 2:30 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    99/100 times, if you have to ask if you are towing or hauling too much...you are towing or hauling too much
    It's not just about keeping yourself safe, it's about keeping everyone else on the road safe too. Just because it can tow or haul a bit over the limit, doesn't make it right and doesn't mean you should.
    Don't do it.
  20. Jan 6, 2021 at 6:54 PM
    #50
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    The towing isn’t an issue. The stopping is
  21. Jan 7, 2021 at 7:49 AM
    #51
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    Yep, could gave been a big gust of wind. Looks like maybe Ca so Santa Anna's can be a real problem. In Colorado they have strict laws on transporting mobile homes in high winds for a reason. Last year I saw a large motor home bus on it's side. It slid a 100 yards down the highway and left a trail of metal. Either a wind gust or evasive maneuver or both.
    BravoDeltaRomeo likes this.
  22. Jan 7, 2021 at 7:51 AM
    #52
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    Yep, look at tailgate latch
