Sequential turn signal headlights
Discussion in 'Lighting' started by Guhner123, Nov 19, 2018.
  1. Nov 19, 2018 at 1:23 PM
    Guhner123
    Guhner123 [OP] New Member
    Gunner
    2017 Tundra SR5 MGM
    Toytec/Eibach 3/1 lift kit 295/70/18 TOYO AT 18 Inch Method NVs
    Hello everyone,
    Was just wondering if anyone has come across a set of headlights with sequential turn signals that they have liked. So far I have only come across one for tundras with 3 arrows in the front headlight but I’m looking for soemthing more like this. These are for Tacoma’s though.
  2. Jan 6, 2021 at 7:04 AM
    Rockin 2nd Gen
    Rockin 2nd Gen New Member
    Jay
    Ohio
    2010 Tundra
    5" lift 20x12 fuel with 35" nitto ridge graplers. Full led and secaine 9" android head unit.
    Just a note. These units have sealed housings. Meaning the Led's are soldered onto a board and can not be replaced. So before you drop $400-$1000 bucks on a set just know when they burn out you will be buying new housings. I have been tackling this dilemma for the last week. So far i have only found the AlphaRex Pro give you the option to change out the low beam which by the way changes from the stock H-11 to an H-7. The High beam is still a sealed bulb and can not be replaced.
  3. Jan 6, 2021 at 7:12 AM
    Morimoto XB's.
    rockmup likes this.
  4. Jan 6, 2021 at 7:30 AM
    alwzdfiant
    alwzdfiant New Member
    2013 Tundra Crew Max
    X2
  5. Jan 6, 2021 at 7:39 AM
    Rockin 2nd Gen
    Jay
    Ohio
    2010 Tundra
