JBL system amp upgrade help
Discussion in 'Audio & Video' started by skip1980, Jan 4, 2021.
  1. Jan 4, 2021 at 8:42 AM
    skip1980
    skip1980 [OP] New Member
    Columbia, Missouri
    I am want to start with installing an aftermarket amp and maybe install some component sets later. The main 2 options I can see is the
    Kenwood Excelon P-XR600-6DSP with maestro ar or using the Dsr1 with aftermarket amp of choice. Any pro and cons to either? It looks like the stock JBL amp is 8 channel. How are you guys wiring the 5 channel or Xr600 6 channel amps? Are you putting multiple speakers on a channel or not using all the speakers? Thanks for any help I can't take this crappy JBL much longer.
  2. Jan 5, 2021 at 5:22 AM
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    Im running a 5 ch amp on my jbl sequoia. The front speaker are component with external crossover. So i run channel 1 and 2 for front, combine all the rear left speakers to channel 3 and all right speakers to channel 4. Channel 5 is running the subwoofer (12inch infinity REF1200S downfiring enclosure).
    Center speaker is disconnected. Corner speakers are replaced with the tweeter from the component set.
