Best suspension components??? no budget
Discussion in 'Suspension' started by rdiaz, Jan 1, 2021.
  1. Jan 1, 2021 at 1:33 PM
    rdiaz
    rdiaz [OP] New Member
    Roy
    2012 Toyota Tunda TRD
    Let me be more specific, i've got a stock 2012 Tundra TRD Limited. Its turning into the designated hunting truck but i'd like a softer ride with maybe a couple of inches of lift. not pulling trailers with it and not loading heavy loads in the back. Truck see's mostly oil field dirt roads which are full of pot holes. toytec CO seem like a good start, but i honestly don't have the knowledge or experience in this subject. I'd like to know what those of you who have the vast experience with tundras and suspension think. I said no budget but realistically looking to spend somewhere between 3-5K
    Saltyhero13 likes this.
  2. Jan 1, 2021 at 2:23 PM
    Bilstein 6112 front, 5160 rear
  3. Jan 1, 2021 at 4:23 PM
    Kanobi13
    Kanobi13 New Member
    Bilstein 5100s how much hunting you do?
  4. Jan 1, 2021 at 4:35 PM
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    For 3-5K you can get a nice set up, plus some MT'S:thumbsup: X2 on the 6112's/ 5160
    JokerGlide09 and Saltyhero13 like this.
  5. Jan 1, 2021 at 4:48 PM
    BlueRibbon4x4
    Geno
    2015 Blue Ribbon 4x4
    I got excited just seeing “suspension” and “no budget” in the same sentence.
    tinman10101, ForceV4, pvmike and 11 others like this.
  6. Jan 1, 2021 at 4:51 PM
    TundraLaw
    TundraLaw New Member
    Northern Nevada
    24 GMC Sierra At4x AEV
    I’d agree with the other posters here, they might not have that flash, but you can’t go wrong with 6112/5160. They run forever, and perform well.
  7. Jan 1, 2021 at 5:07 PM
    Zero One Actual
    Bilstein 6112/5160. Set 6112 to top setting. Should be around $800-$1000
    285/75R17 Toyo AT III or MTs depending on your use and want between an all terrain or mud terrain. Around $1000.
    Icon 17 inch wheels. Method 17 inch wheels. (Saves weight, more rubber). You will want a +18 or +25 offset wheel on a 5x150 bolt pattern. Around $1000.
    Decked two drawer system for stowing all your gear but still having your truck bed to use also. Around $1000.
    That’s four grand and you have new wheels/tires, a three inch lift and some bomb proof storage for your gear.
    The last $1000 can be used for new upper control arms UCAs and floor mats and extra ditch lights or something.
    Done.
    BGoodiE, recomr, ForceV4 and 8 others like this.
  8. Jan 3, 2021 at 9:09 PM
    rustytoys
    rustytoys New Member
    You can make improvements with the Eibach coils on the 6112's as everyone has rightly suggested, but the real issue with the Tundra is the rear leaf springs - it will never have as good of a ride as a rear coil spring Toyota like a Landcruiser or 4Runner.
  9. Jan 4, 2021 at 10:47 AM
    rdiaz
    Roy
    Can’t thank you guys enough for the feedback! My hunting in the Tundra is mostly predator hunting making stand after stand so its lots of driving down dirt roads and slightly off road. As far as tires, I’m leaning more towards the Toyo’s Zero One Actual mentioned or just some BFG All terrains. I’ll plan on doing the Bilstiens 6112/5150’s with new upper control arms. Any specific brand i should go with on the UCA’s? Yea, I searched for advice on suspension on the forum and ran into lots of “budget suspensions”, which is cool, but I’m trying to cry once kinda thing. I’m a firm believer in the mantra, you get what you pay for. But again, thanks for the advice. Worth the money to do the Eibach coils upgrade also?
    Thanks!
  10. Jan 4, 2021 at 11:28 AM
    TundraLaw
    Northern Nevada
    Icon Delta Joint UCA. The best you can get IMO. I would just stick with the 6112/5160 combo. It's an excellent setup, and most of the reason why the Fox ones are more, are for the name.
  11. Jan 4, 2021 at 11:37 AM
    Saltyhero13
    Saltyhero13 Throbbing Member
  12. Jan 4, 2021 at 3:25 PM
    AccuTune Offroad
    AccuTune Offroad New Member Vendor
    El Cajon, CA
    Fox and King being more expensive has a lot more to do with how they are made, not just a brand name. Similar reason as to why Bilstein shocks are so affordable.
  13. Jan 4, 2021 at 5:15 PM
    First World Problems
    First World Problems New Member
    2021 Tundra TDR Pro - Lunar Rock
    I’m suprised to see Bilstein mentioned in a post about “no budget” suspension mods. I’ve owned Bilsteins, Fox, Toytec, Kings and ADS and I would not put Bilstein in the same tier as King/ASD. They work for what they are which is a cheap upgrade.
    if it was me I would order a set of ADS Remote Resi’s w/ adjusters, a set of solid ball joint UCA’s (I’m gonna go with JBA or Dirt King), some new rear leaf springs, and a set of Durobump front and rear bump stops from SDHQ.
    I decided to go with CB lifts for my stock Pro suspension or I’d be adding and other set of ADS’ in a heartbeat.
  14. Jan 4, 2021 at 5:22 PM
    rustytoys
    On UCA's I'd just watch out that they don't have too much Caster built in if you want a more comfortable driving experience - the more caster the more you will have to "muscle" and fight the steering wheel in corners. Some moderate caster UCA's are JBA - more aggressive would be like Camburg. For me I think the sweet spot would be around 3.5-4 Caster, that would give you better stability and improve cornering precision - but shouldn't have to fight the wheel too much (stock is 2-2.5'ish on most Tundra's).
    Definitely replace the coil springs, that is the main thing that will improve you're actual ride. Shocks dampen the coils, the coils are mostly what determines if the ride is harsh or not.
  15. Jan 4, 2021 at 5:51 PM
    TundraLaw
    Northern Nevada
    Ehhh.
    I personally know some of the higher ups in fox, and they all say, unless you’re really sending it, it’s not much different.
  16. Jan 5, 2021 at 7:51 AM
    AccuTune Offroad
    El Cajon, CA
    :confused: The higher ups you know at Fox are telling you their product is not much different than other shocks on the market? Thats pretty funny.
    Terndrerrr, joonbug, Pbed85 and 2 others like this.
  17. Jan 5, 2021 at 8:18 AM
    TundraLaw
    Northern Nevada
    As I said, if you’re not running whoops, you don’t need it, as my friends said, who are C level Fox. Doesn’t matter to them if I buy fox shocks.
  18. Jan 5, 2021 at 8:27 AM
    AccuTune Offroad
    El Cajon, CA
    :thumbsup: Full sends only!
    JLS in WA likes this.
  19. Jan 5, 2021 at 9:03 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    I know of at least 3 people that have been unable to get proper alignment #s with Icon tubular UCAs, I'm one of 'em. I checked their UCAs by both, measuring and placing MCM UCAs directly on top of the Icon's. The Icon's are a good 3/8" too short which caused way too much negative camber. They also don't allow for much caster. These were the worst purchase and biggest waste of money of any of the mods I've done to my truck. So, what did Icon have to say about it? "Cut the inner tie rods shorter." WTF??
    joonbug, GodlessPro and Saltyhero13 like this.
  20. Jan 5, 2021 at 9:05 AM
    Saltyhero13
    That is disappointing to hear.
  21. Jan 5, 2021 at 9:13 AM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Fortunately, less disappointing to hear than to experience financially.:rofl:
    It's not all about wasting money either. There was a lot of time wasted trying to resolve an irreparable issue and finally swapping in proper (MCM) UCAs and 3 or 4 visits to the alignment shop.
    In all fairness, the Delta Joint is cool but it can be installed in Total Chaos UCAs. Then you'd have the joint with some UCAs that have proper geometry.
  22. Jan 5, 2021 at 9:48 AM
    TundraLaw
    Northern Nevada
    This is the first I've ever heard about Icon UCA's having an issue. But to be fair, it did take my shop a few tries to get my alignment correct. It's all good now though.
    831Tun[QUOTED] likes this.
  23. Jan 5, 2021 at 10:01 AM
    MTRock
    MTRock 1889
    Montana
    2024 Tacoma TRD Off Road
    Katzkin Leather seats, JRI shocks, Rival aluminum skids, 285/70/17 outpost nat, Berger catch can, icon rear +.5 springs, gator trifold bed cover, Perry parts bump stops, switchback turn signals,
    No budget!
  24. Jan 5, 2021 at 10:06 AM
    Kanobi13
    Kanobi13 New Member
    :deadhorse:
  25. Jan 5, 2021 at 11:01 AM
    Mill72
    Mill72 New Member
    California
    2021 Tundra DC 4x4 TRD
    snivilous and MTRock like this.
  26. Jan 5, 2021 at 11:41 AM
    HingleMcringleberry
    HingleMcringleberry New Member
    Portland, OR
    2019 Tundra Dbl Cab SR5 Offroad
    BP51 Shocks, Dakar Leafs, Icon Delta Joint UCA's, Falken WP 315/70 R17 w/ Method 703's.
    Second this. I have the BP-51's + Dakar leafs and although not cheap, they are worth the money. They also look fantastic in the wheel well of the truck on all four corners.
    Hightide and MTRock[QUOTED] like this.
  27. Jan 5, 2021 at 3:28 PM
    TundraLaw
    Northern Nevada
    Not sure what this means.
  28. Jan 5, 2021 at 5:42 PM
    eick
    eick New Member
    2020 CrewMax TRD Off Road
    I read somewhere you are supposed to cut the tie rods by 1/4" with those Icon UCA's.
  29. Jan 5, 2021 at 6:23 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Disappointed by the lack of LT/SAS and links in this thread.
    superdenk, 831Tun and Elduder like this.
  30. Jan 5, 2021 at 6:25 PM
    Elduder
    Elduder New Member
    Pencil pushers lol.
    My stock billies feel much worse than the stock Fox set up I had on my last pro. The Pro floated over any imperfection, I could say the opposite of the stock 4600s. At times I wish I hadnt had the Pro, simply because if you havent experienced a higher standard you simply dont know what youre missing.
    Terndrerrr and Gunship Guy like this.
