  1. Jan 2, 2021 at 1:27 PM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    Leaks or play. I had quite a bit of play in the wheel, and had already replaced both inner and outer tie rod ends, leaving the rack as the culprit.
    the ball joint inside the boot is part of the inner tie rod end.
    Tundra2[QUOTED] likes this.
  2. Jan 2, 2021 at 1:31 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Okay, thanks. I've never replaced anything on the rack.
    OEM for the inner, and outer tie rods for long term use?
  3. Jan 2, 2021 at 1:41 PM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    I went with Detroit Axle for mine. Inners come with a reman rack, and I ordered new outers to match.
    NUDRAT and Tundra2[QUOTED] like this.
  4. Jan 2, 2021 at 1:41 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    Moog is fine for inner & outers.
    If the inner has play it's time to replace. If just a bit rusty but no play and not pitted/damaged, you can just grease them.
    For the jam nut hit it with a MAPP gas torch (propane may work too, just takes way longer) and then liquid wrench, pb blaster or other penetrating fluid at the threads a couple times (when hot). The heat then cooling effect may break it free.
  5. Jan 2, 2021 at 1:53 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    :thumbsup: Thank you.
    Heres what I did. Free hand cordless grinder with a cutting wheel. I tried a map gas torch, and penetrant. No love there.
    I can smell the finish line...
  6. Jan 2, 2021 at 1:58 PM
    Professional Hand Model
    Fred
    Hand Protectors
    Nice Hand Touch on the Precision Cut! Takes skills and proper tools/technique for that without mangling threads.
    Tundra2[QUOTED] and NUDRAT like this.
  7. Jan 2, 2021 at 2:04 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Thanks.
    She's an unruly girl one handed, but I made it happen.
    Now if only I could get this new jamb nut on past the rust...
  8. Jan 2, 2021 at 2:19 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    maybe some of this?
  9. Jan 2, 2021 at 2:22 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I'll have to try some of that on the kitchen sink one day.
    For now... my co-workers call me Brutus for good reason. Large man, with abnormal strength for my size.
    NUDRAT[QUOTED] likes this.
  10. Jan 2, 2021 at 4:11 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    After some tomfoolery on my part... a little ass sniffing, and head scratching... I figured out I put my sway bar mount brackets on backwards, and sides reversed.
    Corrected.
    Pass side outer tie rod is on. As per the norm, the passengers side went much better.
    Has anyone else ever noticed that its 90% the drivers side that gives them the most trouble?
    Edit: Also, I figured out that my lugs are much closer to a 13/16 than a 22. Mine are slightly rounded from the goof offs at Raben Tarrrrr
    jpink and lsaami like this.
  11. Jan 2, 2021 at 5:42 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC
    Toyota lugs are often 21mm, 13/16" is very close to it.
    Had some epoxy out for another project, so I used a bit of the excess to see if it'll repair my original visor mount. I did rough up the surface with sand paper before application. Then used a file to level it out after curing overnight.
    It may just break loose as soon as I rotate the visor. I'll try it out another day.
  12. Jan 2, 2021 at 10:38 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    torch is how we get them free at work.. its not uncommon to have to get the nut red hot
  13. Jan 2, 2021 at 10:39 PM
    empty_lord
    05 rollover special
    sounds like its time for new lugs. theyre suppose to be 21mm. but as they get older and swell its not uncommon to have to go up a size
  14. Jan 3, 2021 at 7:08 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I was spraying some penetrant on, and letting her rip with the good blades. Couldn't find a decent price on any good quantity of cutting fluid locally.
    Full send with the carbide toofs.
  15. Jan 3, 2021 at 2:11 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC
    Ah. Using oil or lubricants makes cutting worse. It's better to use water of all things. Or take breaks so the cutting edge doesn't get too hot and deteriorate.
    Cutting fluid doesn't actually lubricate, it cools.
    NUDRAT, Darkness, Siebler and 2 others like this.
  16. Jan 3, 2021 at 2:12 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Neat. Didn't know that.
  17. Jan 3, 2021 at 2:30 PM
    Siebler
    Siebler Taco Tow Vehicle
    CJ
    Eastern Oregon
    01 AC 4x4,07 Sequoia 4x4, 99 Tacoma Long Travel
    Monstaliner, Kings and Camburg UCA, projector retros, DD injectors, homebuilt bumper/ sliders
    I use a Water based fluid in a spray bottle. Makes using it super easy and being water based cleanup is null.
    A slower speed and cutting fluid you shouldnt burn those blades out as fast. I just made a dozen cuts with the same Milwaukee blade through .120 wall 2" tube and the blade still cuts as new.
    NUDRAT and Tundra2 like this.
  18. Jan 3, 2021 at 2:43 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Just went for a little drive. To the end of the driveway, something is hitting at full lock.
    Sounds like the dust shield if I had to guess based on sound. Pulls a little towards to drivers side.
    Think I have too much camber inwards.
    Tired of wallerin around in the cold. :rofl:
    NUDRAT likes this.
  19. Jan 3, 2021 at 3:20 PM
    empty_lord
    05 rollover special
    cutting fluid is the key. Tap magic is what i use
  20. Jan 3, 2021 at 4:12 PM
    Siebler
    CJ
    Eastern Oregon
    I use this CRC stuff, works well for cutting, holesaws, etc. Runs out a spray bottle into a fairly light mist for easy application.
    NUDRAT likes this.
  21. Jan 3, 2021 at 4:39 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Blades are disposable. No lube, full speed, lean in.
  22. Jan 3, 2021 at 8:23 PM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    Disassembled my rear brakes today and pulled the axles. Excited to get this project started now that all the parts are here.
    Oil-soaked drum vs passengers.
    I've never drained the rear diff oil over 155K miles until now. Drain plug wasn't too bad and only some minor metal shavings.
    My driver's side is the side that failed. The ABS sensor had a chunk of metal sticking to it. This definitely explains a few things.
    Everything went smoothly except for a getting a gash on my head - that warranted an extra beer. I'm going to have a shop remove the backing plates and press the new bearings etc. this week. The union for my diff breather mod came early too, stoked about that.
    Voss, Thrussn, NUDRAT and 3 others like this.
  23. Jan 3, 2021 at 11:59 PM
    Kongap
    Kongap New Member
    2004 SR5 DC
    Nice work!
    I’ve been mulling about ideas on how to setup my pullout stove since I've picked it up from FB several weeks ago. I have yet to make the plunge (cut) since it's cold outside. But I'm sure it'll all come together quickly once I make a box and figure a way to secure it to the bed.
    I'd like to try and model it after the setup on https://pullkitchen.com/ ($4300 is a lotta money!).
    So much work needs to be done, but laziness has a hold of me. Plus it doesn't help with the weather and kids lol
    NUDRAT and Jerry311SD[QUOTED] like this.
  24. Jan 4, 2021 at 5:57 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    That must have made a noise...
    NUDRAT, des2mtn and Darkness like this.
  25. Jan 4, 2021 at 6:16 AM
    des2mtn
    SW
    Tonto cover
    I didn't hear any grinding noises and wasn't expecting this. I pulled over and had the truck towed home as soon as I saw hot oil seeping out and barely moved it after that. With everything apart it definitely makes noise when you turn it by hand.
  26. Jan 4, 2021 at 9:00 AM
    That metal piece is part of the rear brake assembly I take it? Did you have an overt brake failure at some point? Parking brake failure?
  27. Jan 4, 2021 at 9:22 AM
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    Well I lurked the junk out of this one. I think I made it through the whole thread over the last couple months.
    @Thrussn
    Excellent work on the 4x4. That was a killer project.
    @theblurry1
    That sucks so bad. The used truck tax can be brutal sometimes. I hope the second job is going ok.
    @empty_lord
    Mandatory compliments on the Reg Cab. I came from a reg cab taco with shell and really miss it some days.
    @Professional Hand Model
    The drawings are great.
    @Tundra2
    Keep on keeping on. I know you talked about letting this set for a while but it looks like you have kept up with the work and are back on the road now? The average new car payment in this country is over $600 a month. Keep that in mind. I know it is probably tough to be 2wd and the 3.4 but it sounds like with the miles you drive this is the right setup for you. 4x4 and a v8 add functionality but do you need it right now? I am also a huge fan of the second car. Skipping most of the snow days in that truck will probably keep that thing on the road as long as you want to drive it. Being at home with the folks should give you the opportunity to get your life infrastructure all squared away for many years to come.
    Here is some inspiration for you:
    https://www.youtube.com/c/TheHomelessFirefighter/videos
  28. Jan 4, 2021 at 9:38 AM
    des2mtn
    SW
    Tonto cover
    Brakes were fine. The metal pieces in the picture and that I found on my ABS sensor are part of the bearing cage and shield. I can move the balls on the bearing freely one by one.
  29. Jan 4, 2021 at 9:40 AM
  30. Jan 4, 2021 at 10:41 AM
    MrDirtjumper
    MrDirtjumper Ol’ dickhead
    Josh
    Slam Angelo, Texas
    06 DC TRD, 2wd to 4wd Conv.
    Yeah that’s an insane amount of money for what you get. But, I think those mall crawler Taco guys are their target market and if you make it Tacti-cool enough, they’ll buy anything.
    I started laying mine out in Cad over the weekend and was likely going to buy plywood sometime this week.
    Darkness and Kongap[QUOTED] like this.
