Mirror cap struggling to clip in
Discussion in '2.5 Gen Tundras (2014-2021)' started by greg8765, Jan 2, 2021.
  1. Jan 2, 2021 at 4:04 PM
    greg8765
    greg8765 [OP] New Member
    Grant
    Utah
    2021 Cement Tundra
    I installed these about a month ago and the driver side keeps popping out like this and I'm afraid it's going to fly off on the freeway.
    I can't get it to sit right for more than a few days. has anyone else had a similar program & solution?
  2. Jan 2, 2021 at 4:26 PM
    cpc0812
    cpc0812 New Member
    Cory
    2018 Cement 4 X 4 CM
    Angle the actual mirror down towards the ground. Then use a flashlight if needed to look inside and see what clip is not cooperating. You may need a regular screwdriver to manipulate the clip. Hope this helps.
    MentalBill likes this.
  3. Jan 3, 2021 at 10:45 AM
    greg8765
    Grant
    Utah
    2021 Cement Tundra
    Brilliant! Thank you
