  1. Jan 2, 2021 at 11:14 AM
    NUDRAT
    NUDRAT [OP] 6 lug life
    SW CT
    Between 'Ridgelines'
    What I notice about the 8 is when I come to a hill the truck just keeps on keeping on. So different from the hybrid.
    abcinv and Tundra2 like this.
  2. Jan 2, 2021 at 11:46 AM
    Cummins3500
    Logan
  3. Jan 2, 2021 at 2:05 PM
    NUDRAT
    SW CT
  4. Jan 2, 2021 at 2:20 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Visitors...
    "Unprofessional" mechanical advantage.
    jpink, NUDRAT[OP] and GODZILLA like this.
  5. Jan 2, 2021 at 2:33 PM
    NUDRAT
    SW CT
    you know they're shopping for shiny parts. Now we know...
    Tundra2[QUOTED] likes this.
  6. Jan 2, 2021 at 2:52 PM
    jpink
    jpink Aspiring Shade Tree Mechanic
    Knoxville
    05 Black V8 DC SR5 (RWD)
    @Tundra2 4 legged mechanics are the best mechanics.
    NUDRAT[OP], Tundra2 and GODZILLA like this.
  7. Jan 2, 2021 at 4:22 PM
    Professional Hand Model
    Fred
    Hand Protectors
    Any diagram reading Sparkys out there that can confirm that adding an extra 3amps bulbs is safe to this 10amp circuit?
    Back up circuit looks to be 10amp connected with 15amp ACC circuit. The back up circuit also ties into the Tow Package which has its own 30amp circuit with relays etc.
    Osram bulbs will consume 6amps (factory consumes 3amps) on a 10amp total circuit. Seems like extra wiggle room on the 10amp circuit. Anyone see the same? Looks like a diode and reverse instrument panel bulb take up some amps in the 10amp circuit.
    NUDRAT[OP] likes this.
  8. Jan 2, 2021 at 4:26 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Wait.. what exactly are you trying to add?
    CodyP and Tundra2 like this.
  9. Jan 2, 2021 at 4:34 PM
    Fred
    Hand Protectors
    Two of these reverse bulbs (in rear assys) take up 6amps to replace Factory bulbs that take up 3amps. In essence, a 3amp over the factory draw. Total circuit is 10amps. I see nothing else on the circuit drawing any Amps other than a diode (basically nothing) and the instrument panel reverse bulb.
    Seems like there is 4amps wiggle room. (10amp circuit - 6amp Osram bulbs = 4amps).
  10. Jan 2, 2021 at 4:39 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Quick question for the suspension Maxx sway link people.
    I know @FirstGenVol has a set, but I'm not sure about anyone else.
    Did you torque to OEM spec on the sway bar mount, or follow the directions from Suspension Maxx? Those are two very different torques from what I'm finding.
  11. Jan 2, 2021 at 4:42 PM
    I have no memory of what I did. I'd go with the suspension maxx recommendation.
    CodyP and Tundra2[QUOTED] like this.
  12. Jan 2, 2021 at 4:44 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Alright then. Maybe this will jog your memory...
    Do you remember being pissed off that they used a 9/16 nut for the through bolt on the link, and a 19 mm for the mount on the lower arm?
    That irked me.
    CodyP and NUDRAT[OP] like this.
  13. Jan 2, 2021 at 4:44 PM
    empty_lord
    05 rollover special
    It’s documented on tacomaworld about using landscaping HIR bulbs in the reverse lights. Chances are, this would be fine too
    https://www.tacomaworld.com/threads/gy6-35-hir-921-reverse-light-upgrade-vs-high-power-leds.474996/
  14. Jan 2, 2021 at 4:46 PM
    NUDRAT
    SW CT
    Well does double the amps = double the thermal units?
    Because you'll also have to worry about melting your housing &/or lens - like the 3rd brake light tends to do.
  15. Jan 2, 2021 at 4:52 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    This is why I replaced my 3rd brake light. The housing was melted through on the top, and bottom of the reflector.
    LEDS in that application are at least twice as bright as the same LEDS were before.
  16. Jan 2, 2021 at 4:59 PM
    jpink
    Knoxville
    Is this empty black plug under passenger seat for something cool?
  17. Jan 2, 2021 at 4:59 PM
  18. Jan 2, 2021 at 5:00 PM
    Fred
    Hand Protectors
    Yeah. My Cargo Assy has the holes burnt into them which I taped up with Silver Metal HVAC Tape found on the street corner. Works! I put LED’s in them years ago and upgraded to newer LED Sylvania 2 years ago.
    Back to the reverse assy: Only reason I am going for it is that the circuit seems to allow the extra Amps. Also, the Reverse Bulbs won’t be firing for more than a few seconds. I’ve had the Cargos on for long times at night in the past and that assy is tight leading to the burned holes. The Reverse Light Assy Chamber is larger and bulb will be on for little at a time. Those are my reasoning factors.
  19. Jan 2, 2021 at 5:02 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Dew it.
  20. Jan 2, 2021 at 5:11 PM
    NUDRAT
    SW CT
    optional lumbar massage. :anonymous:
  21. Jan 2, 2021 at 5:20 PM
    Fred
    Hand Protectors
    Zzzzztttt!!!
  22. Jan 2, 2021 at 5:30 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Its all buttoned up minus the skid plate.
    Passenger's side toe is a little off. Can correct tomorrow.
    Victoria time.
  23. Jan 2, 2021 at 5:46 PM
    NUDRAT
    SW CT
    Now you're inside & warm, start screwing some drywall. :rofl:
  24. Jan 2, 2021 at 5:49 PM
    Outbound
    Aaron
    Northern Alberta
    Is...is that a seatbelt belt?
  25. Jan 2, 2021 at 5:55 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Thats pop's project. I handle all the outside things. He handles most of the inside things. :rofl:
    Yes, it is. You like?
  26. Jan 2, 2021 at 5:57 PM
    Outbound
    Aaron
    Northern Alberta
    I've never seen such a thing. It makes so much sense though and is so obviously practical. You sir, win Redneck Of The Week.
    chrisb, Darkness, NUDRAT[OP] and 2 others like this.
  27. Jan 2, 2021 at 6:08 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    :bananadance: This calls for another beer. Lol :cheers:
  28. Jan 2, 2021 at 6:12 PM
    Outbound
    Aaron
    Northern Alberta
    OMG, and it's got Stitch on it. I'm done. I'm fucking done. :rofl::rofl::rofl:
    CodyP, Darkness, GODZILLA and 5 others like this.
  29. Jan 2, 2021 at 6:24 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  30. Jan 2, 2021 at 6:43 PM
    Stuck in the '00s
    Stuck in the '00s Experienced member
    Mikey
    SE Wisconsin
    2004 Phantom Gray DC 4X4 Limited Tundra
    Western plow, custom bed
    Peeps be jelly.
    GODZILLA and Tundra2 like this.
