Factory Head Unit but new speakers?
Discussion in 'Audio & Video' started by Canoworms in Cali, Dec 24, 2020.
  1. Dec 24, 2020 at 2:33 PM
    Canoworms in Cali
    Canoworms in Cali [OP] New Member
    2018 Crewmax TRD Sport
    Hey Guys, Have a 18 CM. Possible to keep the stock head unit but upgrade speakers in doors and dash and still have pretty good results on sound quality? Thanks
  2. Dec 24, 2020 at 2:39 PM
    NoRcptn
    NorCal
    2017 Platinum
    Sound quality improvement would be marginal. The amp and head unit process shit weird. You’ll probably end up adding to it. But if you’re going to do it in stages , you could always start with upgraded speakers.
    Saltyhero13 likes this.
  3. Dec 24, 2020 at 4:45 PM
    skylinekin
    skylinekin New Member
    Michigan
    2021 Tundra DC TRD PRO (Current), 2014 Tundra SR5 DC TRD OR (Sold)
    Wallygator likes this.
  4. Dec 24, 2020 at 5:54 PM
    The stock head unit only puts out about 10 watts per channel. As mentioned the speakers would most likely marginal but its a start.
  5. Dec 24, 2020 at 7:14 PM
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    I kept the stock unit, added a better amplifier, a pancake sub and replaced all speakers. Very happy with the sound and quality......I wanted to keep the head unit stock so this is the way I went.
  6. Dec 24, 2020 at 8:32 PM
    Elduder
    Elduder New Member
    To the tweeters and center channel yes. The doors are amplified, I havent measured them but Im sure theyre in the 20-40W range. Two best things Ive come across for the stock system so far is to simply seal the doors with something like noico. I dont mean cover them panels, I mean to actually remove the plastic moisture barrier and seal the opening with the dampener. Mid bass was quite noticeably improved by that. Other than that I just tossed in the Infinity 3032 CFX 3.5"s in the dash corners, not bad at all. Very clearly more accurate than the stock tweeters, Infinity makes sensitive speakers so they didnt lose any noticeable volume either. The main 3.5" mid woofer brings a touch of percussion higher up, some people might like that.
    Obviously having done a lot of stereo work in the past, the stock system is really better off completely replaced. But for those truly budget minded, that would be my recommendation.
  7. Dec 25, 2020 at 3:41 AM
    shawn474
    MoCo, Maryland
    You want to make sure you get 2 ohm speakers as well. There are quite a few choices if you look hard enough but most people who complain about the sound after changing out speakers don’t pay attention to that small detail. Also, use 6x9 components in the front - better bass response in my opinion.
  8. Jan 1, 2021 at 7:06 AM
    Rocko9999
    Rocko9999 New Member
    How did you get the 3.5's to fit? Aren't the stock tweets 2" or so?
  9. Jan 1, 2021 at 7:10 AM
    sunnysideTRD
    sunnysideTRD New Member
    Sunny
    2019 Tundra TRD Pro Voodoo Blue
    Standard 2019 TRD Pro but will be a project car and add as I go
    I did the same and very happy with my upgrade.
  10. Jan 1, 2021 at 7:14 AM
    Rocko9999
    What speakers did you replace stock with? Did you keep center channel?
  11. Jan 1, 2021 at 7:15 AM
    shawn474
    MoCo, Maryland
    make sure they’re 2 ohm (or closest to it). I used Memphis 6x9’s audio for the fronts and jbl gto components for the rear
  12. Jan 1, 2021 at 7:16 AM
    Nothing like a Ferrari powered by a Honda engine as someone else said...lol. The stock head unit is about 10 watts a channel, so alot of potential and sound quality is lost by keeping it and replacing everything else.
    BTBAKER likes this.
  13. Jan 1, 2021 at 7:47 AM
    Elduder
    Elduder New Member
    They fit but dont line up with the screw holes. I attached one side with the stock screw and the other with a self taping screw into the plastic.
    Rocko9999[QUOTED] likes this.
  14. Jan 1, 2021 at 8:02 AM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    I kept the stock head unit and speakers and installed this under the passenger seat for a 100 bucks. It gave it more punch and I'm satisfied.
  15. Jan 1, 2021 at 8:04 AM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    If you want to really improve sound quality you have to replace the HU.
    Man, I hope Toyota addresses the weak ass sound system with the redesign.
  16. Jan 1, 2021 at 6:21 PM
    Rocko9999
    Nice. Any issues with the cover not fitting or bulging?
  17. Jan 1, 2021 at 6:22 PM
    Rocko9999
    That amp looks sweet and very small. Where did you mount it?
  18. Jan 1, 2021 at 6:53 PM
    Midnite72
    Midnite72 Anything DIRT !!
    Northern MD
    18 SR 5.7 4x4
    2” level P&P sliders
    Is this amp plug and play with a stock non- JBL System ??
    What speakers does it power? Can u add a sub ?
    Have 18’ SR and on a tight budget but really need more stereo !
    THX
  19. Jan 1, 2021 at 7:33 PM
    jeremyd
    NV
    2014 SR5 CM 4X4
    Definitely not plug and play, I researched the wiring online then sat at my desk with a soldering iron. Lol
    It's driving all of my door speakers.
    Not sure on your sub question, I'm not really a stereo person.
    Midnite72[QUOTED] likes this.
  20. Jan 1, 2021 at 7:37 PM
    jeremyd
    NV
    2014 SR5 CM 4X4
    it slid in tight under the oem amp located under the passenger seat.
  21. Jan 1, 2021 at 7:45 PM
    jeremyd
    NV
    2014 SR5 CM 4X4
    If you decide to do it, you need these two plugs to make it plug and play. If you can't find it online, Let me know and I'll send you this one.
  22. Jan 3, 2021 at 6:04 PM
    Rocko9999
    With these plugs I don't need to run power from the battery?
  23. Jan 4, 2021 at 5:02 AM
    jeremyd
    NV
    2014 SR5 CM 4X4
    no. the power is already there. Although you cannot go much bigger then the amp I showed you..
  24. Jan 4, 2021 at 5:13 AM
    purplenova
    purplenova Not a new member
    Tom
    Ohio
    2016 Tundra Crewmax SR5
    I kept the stock head unit in my 2016 CM, but did replace the dash speakers, new amp and LOC and added a sub.
    Needed the previously mentioned plugs from Autoharness House, other than that it, was plug and play.
    James Randy Taylor at Tech12volts can help you out as well.
  25. Jan 4, 2021 at 10:29 AM
    sunnysideTRD
    Sunny
    Kept the OEM center. Just replaced the speakers with Infinity's both front and back and got a pioneer 6 ch amp in case I needed to add a sub. But so far the speakers give me just enough bass that I like.
    Infinity Reference REF-6532ex
    Pioneer GM-A6704
    4-channel car amplifier — 60 watts RMS x 4
  26. Jan 4, 2021 at 11:51 AM
    PlatinumPro
    PlatinumPro New Member
    2015 PlatinumPro Crewmax
    Bilstein 6112+5100s, Rigid Lighting, Fuel 20x9 Bronze Blitz
    i assume all of this information is unusable for those of us that have the JBL? i've been interested in an upgrade since 2015 lol.
