Bilstein 5100’s + spacers
Discussion in 'Suspension' started by teedubbya, Dec 31, 2020.
  1. Dec 31, 2020 at 1:21 PM
    teedubbya
    teedubbya [OP] I like fat booty
    Austin TX
    2019 trd pro voodoo 4runner
    BIL has a leveling kit on his 2012 tundra - he wants to install 5100’s.
    Should we remove the front spacers and put the 5100’s on highest setting? Just want to make sure it’s level with rear
  2. Dec 31, 2020 at 2:00 PM
    Tundraman479
    Tundraman479 New Member
    2024 Tundra Crewmax TRD Sport Lunar Rock
    TRD Pro Suspension 275/60r20 Wildpeaks
    If it was me I would remove the spacer and install the 5100's on the top setting. I think I have read somewhere that spacers plus 5100's on top setting is not a good combo. Plus if the rear is stock height the 5100's at middle or top setting should make the truck level.
  3. Dec 31, 2020 at 2:06 PM
    jalam321
    jalam321 New Member
    2018 Tundra CM Platinum 4x4 and Sequoia Platinum 4x4
    Yes, I would remove the spacer. Is the rear stock or does it have lift
    YardBird likes this.
  4. Dec 31, 2020 at 2:22 PM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    Have to remove the spacers to install a lifted/adjustable coil over. You don't want to run a 2 inch spacer lift and lifted coil overs.
    The 5100s have 3 settings, about an inch, 1.9 and 2.5 lift. 1.9 will be about level, the 2.5 just a hair nose high but plenty run them like that. Just a note- 2.5 and up lifts can sometimes need UCAs to bring back correct alignment. 1.9 should be no problem with stock UCA.
    If you check out the suspension forum here there are a ton of pics and spec info on the 5100 and 6112 lifts- either of them have the same 3 adjustable levels of lifts, the 6112s are just beefier, larger diameter shock and cost more since they are sold with new coil springs. The 5100s, you just use your stock coil springs.
  5. Dec 31, 2020 at 2:24 PM
    frichco228
    Frank
    Virginia
  6. Dec 31, 2020 at 2:34 PM
    teedubbya
    Austin TX
    The rear has whatever leveling kit was installed from shop
  7. Dec 31, 2020 at 3:52 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    I had 6112s installed.
    With the setting and CB shim I used ended up with 2.5" of lift.
    With the rear stock, it sat pretty level.
    It looks a little nose high, but measured level.
    763B91DF-899D-4443-A7EC-B9CE39DA5452_zps_40bc24ad3f26a52479708d1be3d2d728905eb2e0.jpg
    I ended up installing Toytec rear shackles on the 1" setting to get a little rake back...
    942B7FE5-470C-4383-9C30-59887BC9D6D9_zps_606f21455805f4ad53d67b1b8905b09d6269bebc.jpg
    gkelm likes this.
  8. Jan 25, 2021 at 1:48 PM
    AlexJet
    AlexJet New Member
    2021 TRD Offroad CrewMax
    What is the ride on the 5100 vs OEM shocks? I feel like OEM is too soft and bouncy
    gkelm likes this.
