How to determine if my 06’ DC has DRL?
Discussion in '1st Gen Tundras (2000-2006)' started by halfbid, Dec 30, 2020.
  1. Dec 30, 2020 at 12:41 PM
    halfbid
    halfbid [OP] New Member
    2006 DC Tundra
    I’m trying to determine if my 06 DC has daytime running lights. I’ve searched the forum, but haven’t been able to find anything specific to my particular situation.
    The owners manual states the DRL is the main headlamp operating at reduced power and that it comes on when the parking brake is released. The manual doesn’t seem to indicate whether DRL comes as a standard feature or if it’s an option. I’d be surprised if DRL is an option since it is a safety feature and wouldn’t appear to cost much to include, but it certainly seems possible. The truck is a limited and I’d find it even stranger if it wasn’t standard on that package, but it still seems possible. A vin search at the Toyota spec website does not list DRL as one of the trucks features, but it isn’t 100% accurate in some other respects either.
    I checked and the DRL do not come on when the parking brake is released even with the engine running and in gear. I looked for the plug between the battery and the fender well which others have posted about here and it doesn’t seem to be there. Does anyone know if this plug could be in a different location or omitted on an 06’ DC? Or does it’s absence suggest I don’t have the DRL feature?
    I've gotten as far as I can on my own with my admittedly limited understanding of vehicle electrical systems. Any ideas on where to go from here?
  2. Dec 30, 2020 at 12:46 PM
    2006Tundra
    2006Tundra Financially Irresponsible
    Lou
    Long Beach, CA
    2006 Toyota Tundra Double Cab SR5, 4.7L V8
    I'm pretty sure it was an option. You either have it or you don't, my 06 doesn't have DRL. Not sure how to "active it", I never cared about DRL but If you google how to, other forums might help you.
    halfbid[OP] likes this.
  3. Dec 30, 2020 at 1:04 PM
    SouthPaw
    SouthPaw The headlight guy
    2000 Limited 4x4 AC
    Post a picture of your headlights. If I’m not mistaken, the DRL light is a 194 bulb in the bottom corner of each light. On the older trucks. I circled them with red in this picture:
  4. Dec 30, 2020 at 1:25 PM
    halfbid
    2006 DC Tundra
    @SouthPaw....Thank you. I do have the housing you posted and I originally thought the second bulb was the DRL too, but the manual indicates otherwise in two ways. The first I already mentioned and under the section on bulb replacement in the manual the second light is referred to as a parking light and it does come on as expected with the parking light switch.
    @2006Tundra....So it may indeed be an option. Thanks!
  5. Dec 30, 2020 at 3:19 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    Easy way, park at night facing a wall, garage door or windows. Turn headlights off while foot on brake,.do the headlights dim? Yes = DRL, No = no headlights.
    HBTundra and halfbid[OP] like this.
  6. Dec 31, 2020 at 8:53 AM
    halfbid
    2006 DC Tundra
    Thanks for the tip @assassin10000. I did a version of this yesterday, but instead of using darkness to do it alone I had my wife look while I released the parking brake. I checked with the engine off and on, in park, drive and reverse. Nada. At this point I think I can say two things. I either don't have DRL or they have been disabled or are otherwise not working. I looked for the plug I've seen mentioned between the battery and the fender well and there isn't one on this truck. It seems like most of the posts I've seen mentioning this plug were on pre double cabs, so I'm not sure if not seeing the plug in that location translates into I don't have DRL or not. I know there are at least some differences between the DC housings and the earlier access cab housings. It seems possible there could be other changes like deleting the plug or putting it in a different location.
    I'm leaning towards concluding I do not have them. I think if someone with an 06' DC who has working DRL checked and found they do have the plug by the battery I would be pretty confident I do not have them. But without more info I think either possibility could still be true. This question could probably be answered by looking at the wiring diagrams, but when it comes to that I might as well be trying to read an ancient Sanskrit text.
    HBTundra likes this.
  7. Dec 31, 2020 at 9:10 AM
    Professional Hand Model
    Fred
    Hand Protectors
    Try doing a VIN lookup on Toyota dot coms and see if it is on your Spec List.
    halfbid[QUOTED][OP] likes this.
  8. Dec 31, 2020 at 9:19 AM
    halfbid
    2006 DC Tundra
    Thanks @Professional Hand Model, I did try that. It isn't listed as an option there, but not everything is 100% accurate either.
  9. Dec 31, 2020 at 10:22 AM
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    I am in the same boat. I have no indication that I have DRL.
  10. Dec 31, 2020 at 10:45 AM
    Fred
    Hand Protectors
    Ok. I went back up and read that. I’m supposing you do not have them then.
    My VIN lookup says I have them on the 2002 and I do indeed. I have disabled them at the plugger next to battery.
  11. Dec 31, 2020 at 10:47 AM
    HBTundra
    HBTundra New Member
    2006 DC 2wd
    Good info here, thanks to everyone who replied.
    I have a 2006 DC . . . I'm going to check mine.
    I don't think mine has DRL's.
    I did a VIN check . . . nothing on there.
  12. Dec 31, 2020 at 10:52 AM
    Casper421
    In the woods
    06 DC
    I will check when I get home but here are a few pics of my 06 DC with drl’s:
    DRL’s only(middle setting on switch):
    DRL’s and fogs:
    Everything:
  13. Dec 31, 2020 at 10:54 AM
    weadjust
    weadjust New Member
    Tupelo, MS
    2006 Tundra Limited DC
    I have a 06 DC Limited and looking at my specifications on Toyota Owners site DTR Lights is listed
    PORT OR FACTORY INSTALLED EQUIPMENT
    • CK All Weather Guard Package
    • Factory
    • EJ JBL AM/FM/Cass With 6 Disc Changer & 8 Speakers In 6 Locations
    • Factory
    • FE 50 State Emissions
    • Factory
    • HY Rear Audio System w/Wired Headphone Capability
    • Factory
    • JC Overhead Console w/Compass, Outside Temp Gauge & HomeLink Universal Transceiver
    • Factory
    • LD Limited Slip Differential
    • Factory
    • RL Daytime Running Lights
    • Factory
  14. Dec 31, 2020 at 11:04 AM
    halfbid
    2006 DC Tundra
    @Casper421, Unless I'm misreading the owners manual I think the second bulb in the housing are the parking lights. I think DRL - if you have them - use the headlamps with reduced power. If I correctly understand it, DRL should be on even when the light switch is in the off position. According to the manual it is activated when the parking brake is disengaged rather than at the switch on the column. If they only come when the parking lights are switched on then I think they are probably parking lights.
  15. Dec 31, 2020 at 11:12 AM
    halfbid
    2006 DC Tundra
    @weadjust and @Professional Hand Model Thank you both for going to the trouble of checking. I appreciate it.
    @weadjust, I'm not in any sort of rush, but would you mind checking if you have the plug between the battery and the fender well when you have time? I'd like to confirm you have the plug there. I'm feeling 99% sure I don't have DRL from all the extra info you guys provided. Thanks for all the help!
  16. Dec 31, 2020 at 11:13 AM
    Casper421
    In the woods
    06 DC
    What’s so important about these drl’s?
  17. Dec 31, 2020 at 11:15 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    This is how my 2005 DC was.
    The little useless light bulb was part of the parking lights.
    DRL was a reduced power headlight.
    I kept unplugging the plug next to the battery since I didn't want them on..
    Every time I took it in for service, they would plug it back in.
    Said they were required by law to do it..:eek:
    I'd guess if you don't have that plug, you probably don't have DRLs.
  18. Dec 31, 2020 at 11:32 AM
    halfbid
    2006 DC Tundra
    @Casper421, I'm going to get a headlamp harness and this detail has something to do with how it's configured according to the fella who is making it. I couldn't tell you why it matters because I know next to nothing when it comes to electrical stuff. One thing I do know is I need better lights and installing a power-switched harness will give me the most available options to increase headlamp performance.
    @1lowlife, Thank you! At this point I'm 99.9% sure I do not have them.
    It seems like both the plug and Toyota specs are a reliable way to make this determination.
    Thanks everybody!
  19. Dec 31, 2020 at 11:40 AM
    Casper421
    In the woods
    06 DC
    Fair enough, good luck!
  20. Dec 31, 2020 at 11:49 AM
    halfbid
    2006 DC Tundra
    Thanks @Casper421, I'll need it! Also I really like the lights you installed. Did @SouthPaw do the housings for you? I saw his thread and those look like the best option I have seen so far. I don't know if I can go the LED route though because I need heat at the housings for snow and ice. I'm gonna start with a harness and new bulbs to see if that helps.
  21. Dec 31, 2020 at 11:59 AM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC
    ^ this.
    Just an extra parking light on the later model headlights. My 05 AC has them too. They'd still be there DRL or not.
  22. Dec 31, 2020 at 12:20 PM
    HBTundra
    HBTundra New Member
    2006 DC 2wd
    That thing looks bad-ass all murdered-out.
    Casper421[QUOTED] likes this.
  23. Dec 31, 2020 at 12:49 PM
    Casper421
    In the woods
    06 DC
    No, I did those housings a couple years ago. Not bad for my first retrofit.
  24. Dec 31, 2020 at 12:51 PM
    Casper421
    In the woods
    06 DC
    Thanks. That’s back when she was all shiny and short.
    HBTundra[QUOTED] likes this.
  25. Dec 31, 2020 at 3:44 PM
    weadjust
    weadjust New Member
    Tupelo, MS
  26. Dec 31, 2020 at 4:14 PM
    halfbid
    2006 DC Tundra
  27. Dec 31, 2020 at 4:22 PM
    Baller
    Baller New Member
    '05 Tundra SR5 DC
    I believe this to be the case.
