Would this make you mad?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Yota707, Dec 31, 2020.
  1. Dec 31, 2020 at 10:00 AM
    Yota707
    Yota707 [OP] New Member
    Bay Area
    2015 Tundra TRD
    Auto detail, vinyl wrap specialist. Truck has a 300gal fresh water tank for spot free water while detailing and a Honda pressure washer
    A few weeks ago I noticed my tailgate would slam down when opening it. I made an appointment with Toyota to look into the issue. They said the soft open and close was not working and they needed to change the tailgate hinge assembly. I authorized the work and they ordered the parts “2 weeks this took”.
    Went to pick up truck yesterday tailgate still slams down and now the hinges on the tailgate are exposed metal and not white like they came from the factory. See pictures below.
    Went back to toyota and now they are saying they need to replace the tailgate strut assembly witch is inside the bed that allows the tailgate to open softly.
    My question is would you be ok with these tailgate hinges? Are they going to rust out faster? I know it’s a small issue but I think they look bad exposed metal. Also should I have to pay for the tailgate hinges if that was not the issue and they replaced them anyways.
  2. Dec 31, 2020 at 10:19 AM
    crewmaxlmt
    crewmaxlmt How dare you!
    scott
    2020 Crewmax Limited
    I would not be OK with that. I would also be surprised that they did not know that the tailgate damper is located behind the drivers side taillight and that the damper is responsible for slowing down the tailgate, not the hinges.
  3. Dec 31, 2020 at 10:21 AM
    Nomoredomestics
    Nomoredomestics New Member
    GA
    2023 TRD Sport 4x4
    If I'm looking at the pic right, they don't look bare. Painted would look better but they appear to have a zinc coating or something similar. I wouldn't think rust would be a major issue. As far as paying for a fix that didn't fix anything. . . I'd have a hard time doing that. . .
  4. Dec 31, 2020 at 10:29 AM
    TTund16
    TTund16 New Member
    Since they didn't fix the problem I would be. You should not pay if they didn't fix it.
    1lowlife and Yota707[OP] like this.
  5. Dec 31, 2020 at 10:30 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    I was also thinking they look like they're stainless or coated with something so I wouldn't be concerned with rust.
    I'd be on the fence about getting Toyota to replace with painted ones. On the one hand, you can't see them when the tailgate is closed so who really cares? On the other hand, they're taking your tailgate off again to fix the soft close anyway so why not get them to replace those with matching parts? If they weren't going to be doing more work on it, I'd probably be willing to live with it rather than letting them touch my truck again.
  6. Dec 31, 2020 at 10:33 AM
    JLS in WA
    JLS in WA New Member
    2008 White DC Limited 4x4
    Drahthaar Transport Unit
    If you paid for white hinges, they should give you white hinges. Personally, I'd contest them replacing the hinges when they should realize they have nothing to do with how fast the tailgate comes down. I'd tell them I wanted my money and my original hinges back, and then I'd order the strut and install it myself.
  7. Dec 31, 2020 at 10:59 AM
    Kanobi13
    Kanobi13 New Member
    Since you paid for them did they give you the old ones?
    Yota707[OP] likes this.
  8. Dec 31, 2020 at 11:44 AM
    rockmup
    rockmup New Member
    Todd
    Greenwell Springs LA.
    Kings, 5:29's, E-lockers on 37's
    I'd go back and insist on color matched hinges and that they fix the problem if it was done under warranty. Did you have to pay for this repair ? If so, I'd want a refund and I'd take my truck somewhere else.
  9. Dec 31, 2020 at 11:50 AM
    Zero One Actual
    Straight garbage. Walk them out to the lot and show them the matching colored hinges. Have them return yours to what is was and then actually fix the issue which is not the hinges at all.
  10. Dec 31, 2020 at 11:57 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    Well, considering I am not a toyota tech, and I still knew a soft open malfunction would be caused by the damper and not the hinge...I would be upset at this misdiagnosis and change out of the matched painted parts. You should not have to pay for their mistake, so the payment for the hinges and labor $ should come back to you.
  11. Dec 31, 2020 at 12:26 PM
    Yota707
    Bay Area
    2015 Tundra TRD
    Thanks for all the great responses. I left the truck there and they stated they will resolve the issue. They also said they threw out the old hinges. I insisted they put color hinges back on the vehicle. They want me to pay $280 for the first repair on the wrong item.
    glowblue likes this.
  12. Dec 31, 2020 at 12:36 PM
    crewmaxlmt
    scott
    I would start a conversation with Toyota. This is borderline criminal but definitely incompetent.
  13. Dec 31, 2020 at 12:46 PM
    Dealer Name???
  14. Dec 31, 2020 at 3:15 PM
    Yota707
    Bay Area
    2015 Tundra TRD
    Freeman Toyota in Northern California. I’ve had great experiences with them before this has been the first time having issues.
  15. Dec 31, 2020 at 3:21 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    Escalate it to a manager
    I've gotten $650 in parts/service credits (offered to me, not asked for) by talking calming, emailing and documenting and explaining time wasted and exposing shennigans during my signing and first service.
    Stand firm and don't let them sweet talk you or accept just an apology. They screwed up and threw out your parts. At minimum, ask for an extra set of parts that they claimed they threw out. Time is money, we are in a Pandemic so visiting dealers for their mistakes is not acceptable.
  16. Dec 31, 2020 at 3:22 PM
    Mill72
    Mill72 New Member
    California
    2021 Tundra DC 4x4 TRD
    That’s where I purchased my ‘21 from. Seems like squared away dealership. It’s better than the one in Petaluma.
    Yeah it looks shotty with the work they did on your truck. That dealership has its own collision and paint shop on site.
  17. Dec 31, 2020 at 3:22 PM
    Jbehredt
    Jbehredt Burgeoning member
    Westminster, CO
    2020 TRD Pro DC White
    That is some hack work. You owe them nothing. They threw away your perfectly good painted hinge and gave you an unpainted hinge that didn’t solve any problems. They need to paint that hinge just to get back to $0. Then you can start talking about the cost of the actual repair.
  18. Dec 31, 2020 at 3:25 PM
    Randy Morton
    Randy
    Deepinahearta, Texas
    Escalate this to at least the regional, if not national office. No one at the dealer is competent enough to resolve the issue. When they offer a resolution, take it to a different dealer. You don't need them doing something to your truck as an act of retribution for causing them problems.
    Yota707[OP] and BravoDeltaRomeo like this.
  19. Dec 31, 2020 at 3:47 PM
    I would have them comp the bed hinges. Their mistake, misdiagnosis. If they don’t take care of you....
    Next step, replace the shock damper. It's very easy to do. Trust me David, you can do this.
    Finally, I would repaint the hinges myself if you have a garage. White is the fastest drying paint, and the reasoning behind the fastest color.
    Seriously though. Go to a paint store that supplies auto paint supplies. Have them put in your paint code (should be super fast white) in an aerosol spray can. Then buy some self etching primer, clear coat, and clean hinges. Two coats of primer, and wait until the next day. Spray two coats of base. Let dry. Spray final coat and then 30 min later spray clear coat. Let dry. Spray clear again.
    Install on tailgate and be happy.
    I did this very thing after destroying my tailgate due to vandalism and 9k lbs of trailer/Jeep. I found plenty of tailgates without the assist. So I got rid of it.
    BBE415CF-01A5-4DF3-B27D-ECAD80D8A570.jpg F0199835-72A9-4D42-A304-FF80A87B3FCF.jpg
  20. Dec 31, 2020 at 4:50 PM
    Zero One Actual
    Sales and parts are two totally different groups of people as are the mechanics. The OP needs to go straight to the manager or owner or whoever. Walk them to the Tundras on the lot and say show me these garbage ass hinges on any other truck on your lot from the port? And there is no way you are paying that money for a problem they caused. That’s like me charging you for the hinges while I fixed the tail lights.
    Cjames17 likes this.
  21. Dec 31, 2020 at 4:52 PM
    Zero One Actual
    All true. But this dealership is so wrong we are at the level of them admitting and resolving the issue. If he doesn’t do it then the next person gets the same treatment etc etc.
  22. Dec 31, 2020 at 5:23 PM
    Mill72
    Mill72 New Member
    California
    I never said pay for thier mistake and aware sales and parts dept are different. The dealer could have taken the hinge part to thier own paint shop to match the OEM white paint code.
  23. Dec 31, 2020 at 5:27 PM
    Zero One Actual
    Yes I see that sir. I apologize for my poor wording as a response to your comment. They could have done that and they didn’t. Either way you and I both agree that place is trying to screw him over and with an inferior part. Sorry about that.
  24. Dec 31, 2020 at 5:55 PM
    Mill72
    Mill72 New Member
    California
    No worrries, all good!
  25. Dec 31, 2020 at 7:10 PM
    Very valid point. Totally agree. My suggestion is if he gets left outside in a Speedo in a snow storm. :D
  26. Dec 31, 2020 at 11:28 PM
    Yota707
    Bay Area
    2015 Tundra TRD
    Yeah I was thinking about doing this. Yours turned out great!
  27. Dec 31, 2020 at 11:30 PM
    Yota707
    Bay Area
    2015 Tundra TRD
    Totally agree with this
  28. Dec 31, 2020 at 11:32 PM
    Yota707
    Bay Area
    2015 Tundra TRD
    Yes it’s better then the one in Petaluma agree. I’ve never had a issue with them until now.
  29. Dec 31, 2020 at 11:36 PM
    Yota707
    Bay Area
    2015 Tundra TRD
    Well loving all the feed back on this post. They said the truck will be ready on Monday so I will let you guys know what happens. I asked them to paint these and to fix the actual issue that was originally broken. Have you guys heard of these hinges going bad? When I pick my truck up I want to know why the technician thought these needed to be replaced and I’m surprised he didn’t know that the issue was the strut.
  30. Jan 1, 2021 at 12:10 AM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    As a former tech myself i can tell you that jobs like this are always assigned to the lowest techs on the totem pole. This simple problem was obvious and misdiagnosed from the beginning, and you should ask them how replacing hinges has anything to do with how fast or slow the tailgate drops considering it has a strut to accomplish this. I bet the service manager will be unable to answer this question if he's honest about it.
    ColoradoTJ and Tyman like this.
