Firewall Problems - 42” Lightbar (Diode Dynamics)
Discussion in '2.5 Gen Tundras (2014-2021)' started by Silv333, Dec 30, 2020.
  1. Dec 30, 2020 at 7:30 PM
    Silv333
    Silv333 [OP] Patriot
    NJ-NC-MD-NC
    2018 Cement Crewmax TRD Off Road
    Whelp, what a shit day. First, mounting the 42” lightbar by diode dynamics isn’t an easy job. The video the guy says “all you need is basic hand tools”. This is true. HOWEVER, there’s hardly any clearance between the nuts you have to remove on the bumper mount and all the other shit behind the scenes.
    I ended up saying fuck it and mounted the bracket to the excess thread hanging out from the bumper mount to the frame. I hope this isn’t a bad thing. See pics.
    Now for the bigger issue, how the fuck do I run this cable through the firewall? The whole nipple removal on the rubber grommet didn’t do shit. If I sound frustrated and pissed off, it’s because I am.
    Any pointers?
  2. Dec 30, 2020 at 8:03 PM
    APalmTree
    APalmTree Sometimes helpful
    Brandon
    SW Washington
    A few... Definitely more than 2
    When I ran cables through my firewall, I used a roll of 14-ga baling wire that I had around that was stiff enough to be pushed through the firewall. Once that is through I taped my wires to it and pulled the whole thing back through. It is not fun I won't lie to you. The firewall also has 2 layers so any hole you make has to line up in the engine bay as well as in the cab.
  3. Dec 30, 2020 at 8:15 PM
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    I used a metal coat hanger and Vaseline......not as head as it seems. But you have to be some kind of contortionist or have very small hands to do it with ease
    toyofan87 and Tundyfundy like this.
  4. Dec 30, 2020 at 8:25 PM
    Silv333
    NJ-NC-MD-NC
    Did you have the video on YouTube about cutting the nipple? This has been a major pain in the balls, not gonna lie. It took me two hours to get one nut off that bumper/frame mount. There was enough thread hanging out I said fuck it and just used that to hang the light bracket from.
  5. Dec 30, 2020 at 8:26 PM
    Silv333
    NJ-NC-MD-NC
    What hole did you go through?
    APalmTree[QUOTED] likes this.
  6. Dec 30, 2020 at 8:32 PM
    CDC4U3TRD
    CDC4U3TRD New Member
    2016 4U3 Tundra TRD
    Leveled, front bumper, LED headlight conversion. Soon - S&B Cold Air, Bilstein 6112/5160's, 35's.
    Sorry you're having such a bad time man. The suggestions above are spot on. Use a coat hanger or bailing wire. There isn't really an easy way to push wires through the grommet any way you look at it. I avoided having to push the large connectors on my new truck by going to a Switch Pro system. On another note, you're going to love the Diode bar. I have the same one on my truck along with SS3 Pro fogs and ditch lights. I am also running SSC2's in the back for area flood lights. They make fantastic products.
  7. Dec 30, 2020 at 8:40 PM
    chaddydubbs
    chaddydubbs New Member
    Chad
    Omaha, NE
    2017 MGM Tundra SR5 Crewmax
    Tyger running boards, black badge overlays, stubby antenna, TRD Pro grille, window tint, LED interior lights
    When I was wiring my LED headlights I had to go through the nipple. I used an ice pick from inside the truck under the dash (you can see the nipple of the firewall) and pushed it out until I broke through. Then I straightened a wire coat hanger and shoved it through the hole I just made. I grabbed the end inside the engine compartment and taped my wire to it. Then I went back into the cab under the dash and slowly pulled it through. Easy peasy. I then just used silicone around the nipple to seal the area around the wire. I hope this helps my friend!
  8. Dec 30, 2020 at 8:59 PM
    APalmTree
    Brandon
    SW Washington
    I have multiple holes. The nipple hole I filled with an 8 gauge subwoofer cable. I then cut some smaller holes for a three-position switch for aux backup lights and I decided I did not want to do that anymore so I added an underhood control box and switch system and ran those through the firewall. If you have an extra set of eyes that can watch the opposite side while you are trying to push something through it is helpful to guide you into the other side of the hole that you are trying to thread through. Unfortunately I'm going to do it again here before too long because I will be wiring up a front camera to my new headunit so we will see where that ends up.
    1lowlife likes this.
  9. Dec 30, 2020 at 9:07 PM
    Silv333
    NJ-NC-MD-NC
    Thanks man. Where in the hell on the inside of the truck does that grommet with the wire and nipple come through? I had a bright ass light shining right into the grommet/nipple area from under the hood and inside I didn’t see any sign of light. Thanks again!
  10. Dec 30, 2020 at 9:10 PM
    CDC4U3TRD
    2016 4U3 Tundra TRD
    No problem man! The first time I tried shoving a wire through that damn thing it took me at least an hour. Haha. It comes through the fire wall kinda in line with the brake pedal and above it. You have to channel your inner contortionist to see it. Plus the grommet is double walled so unless you have a big ass hole through both walls you probably won’t see light coming through it.
  11. Dec 30, 2020 at 10:30 PM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Slit the grommet, tape (electrical tape) an HVAC 3 foot zip tie to your wire, spray it with silicone spray, and pull it through from the engine compartment to the cab.
    Or even a smaller long zipties for smaller wires..
    I've pulled many a wire thru that grommet.
    Including a 0ga amp power wire..
    8a47udpx_zpsqbtdzyfv_96373ae435c4ebb9d550bdfed78c776c46ef5aaf.jpg o0tt5klg_7c3a503bb2fe582082d582eb48d67d597806cb0d.jpg vaoay96r_zpsohb16fvb_bea7c2c4d8c31b119f7ab4bed1a4428ab4f4449e.jpg
    Tundyfundy likes this.
  12. Dec 30, 2020 at 10:48 PM
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    Once you cut the nipple ur able to use something like this( I actually used this) and then pull from the inside. Add some lube because if not ur going to end up pulling off the whole grommet lol. Also if it has a plug I would remove the plug and then re install it once it’s on the other side of the firewall
  13. Dec 30, 2020 at 10:48 PM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
  14. Dec 31, 2020 at 1:21 AM
    glowblue
    glowblue From time to time
    VA
    This is exactly what I did. I just installed a front camera yesterday and pulled the wire through (twice, that’s another story). I taped my wire to my “fishing device”. The trick is to use lubricant - lots of it! The wire isn’t so bad but “bulky” objects like cable connectors can really make it hard to pull through. Use the tape to streamline the pull.
    It may seem like you are using a lot of force but stick with it. I had to get on a step ladder and twist my arm like a pretzel to pull through from the engine bay behind the brake line manifold. The video others mentioned is what helped me.
  15. Dec 31, 2020 at 1:24 AM
    glowblue
    VA
    This is what I mean. Plugs or connectors on the end of wires are a PITA. Straight cable is easy. I had to pull a small video with with an RCA plug. I strategically taped up my wire and fishing tool. If you can, remove any plugs or connectors.
  16. Dec 31, 2020 at 3:39 AM
    Genuine Cooling Systems
    Genuine Cooling Systems New Member Vendor
    I didn't go "through" the firewall grommet, I went around it so I didn't have to put a hole in it. I just took a plastic tool and worked it on the outside of the grommet until I got it through then turned it so it so it left a space to run the cable. Once the cable was through, I removed the tool and the cable rested on the outside of the firewall grommet.
  17. Dec 31, 2020 at 6:26 AM
    clarkritchie
    clarkritchie New Member
    I second most of the above -- a wire hanger is all you need (are these becoming hard to find? I had to ask 3 neighbors to find one!), along with some tape -- lose the connector if you can, even if you have to go somewhere to have them crimp a new one on (tape it up super well if you cannot) -- lube helps and use a step ladder really get down in there. I've only done this on the passenger side, but the wire pulled through fairly easily. I would also recommend maybe pulling a different/donor wire through first (in case you damage it), and then using that to pull your actual wire back through.
  18. Dec 31, 2020 at 9:18 AM
    773_eddie
    773_eddie Trd Pro
    Eddie
    Chicago
    Tundra Trd Pro
    12volt remote start, weathertec accessories, Trd Pro decals, Toyota console safe,VLEDS Puddle Lights,Frac Harness,TRD PRO front and Rear Sway Bar,NSV Hood Light Bar,ESP long box,AJT accessories,Thinkware U1000 dashcam, coachbuilder 1/3 Lift, HR LED’s,Pro comp Traction bars, JL complete System wit 2 10” subs, Kenwood DDX9907XR HU
    I have the same light bar those bumper nuts are pretty tight and have a little loctite on them so they don’t come off easy but I used a 14mm ratchet wrench on them and was able to do the install in about 30min I was able to stab and pass the wire thru the grommet with my 24 inch snap on Phillip head screw driver I used electrical tape to secure the wire to my screwdriver and a little silicone lube I think I had the complete job done in about an hour
    CDC4U3TRD and ElNopal like this.
  19. Dec 31, 2020 at 10:01 AM
    TheBeast
    TheBeast The Beach
    CDC4U3TRD likes this.
  20. Dec 31, 2020 at 10:07 AM
    ElNopal
    Willis TX
    19 Cavalry Blue CM
    In addition to all the great suggestions, I went ahead and de-pinned the little harness. This allows for a way easier time to bundle and pull through.
    I went ahead and pulled the bumper support nuts off and installed the bracket that way. I reinstalled, with a little loc-tite, as to maybe “deter” others with “basic hand tools” to be discouraged in a quick attempt to thieve my new light bar.
    Best and cheers :cheers:
  21. Dec 31, 2020 at 10:45 AM
    glowblue
    VA
    Good ideas. I saw in one YouTube video the guy cut an “X” in the small hole in the grommet that helped open it up a bit. I did this from the cab side which helped a little - but the grommet is double walled so still had to pull pretty hard to get the wire through.
  22. Dec 31, 2020 at 12:28 PM
    Mallcrl
    Mallcrl New Member
    Anand
    Maryland
    '25 Limited TRD-OR
    Looks like the interior of my 5th gen 4Runner from 2 months ago, the Tundra will look like this in about a month when it gets all the electrics run through it and the sound deadening treatment.
    As for the grommet, no experience on a Tundra, but from running plenty of large (2AWG or larger) cables into 5th gen 4Runners for rear power distribution, yes, the grommet is absolutely the hardest part of any wiring related job. Make a little cut, use a HVAC zip tie (or similar), and spray silicone lube as stated earlier.
    Tundyfundy[QUOTED] likes this.
  23. Dec 31, 2020 at 1:42 PM
    preacher35
    preacher35 RIGHTEOUS MEMBER
    2018 MGM Platinum Crewmax 4x4
    I do not see what the big deal is. I've run several wires through my firewall (0/1 gauge for my amps, 5 different 14 guage wires for my LED lighting, and at least 3 16 gauge wires for aux USB ports). All I did, was use an Xacto blade to cut a "T" on the medial side of the driver side big rubber grommet, taped whatever wire I needed to push through, to a long flat-head screwdriver and pushed the bitch through and grabbed it on the other side. No problem!
    Silv333[OP] and ElNopal like this.
  24. Dec 31, 2020 at 2:18 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Ratcheting wrenches are a must to get the bumper off. Same for putting on skid plates.
  25. Jan 3, 2021 at 2:00 PM
    Silv333
    NJ-NC-MD-NC
    You the man!
  26. Jul 18, 2021 at 6:55 PM
    BigDawg_Trd
    BigDawg_Trd New Member
    2020 Tundra TRD Sport
    -3/1 Level Kit -33’s & 20’s -19 -Full interior LED swap -LED taillights
    What’s up all?
    Im new to this site.
    So I’m looking for an answer that I didnt see posted.
    I just received this light bar, and the only concern i have is, how far will the bar mounting brackets stick out since my bumper is shimmed?? Im thinking I’ll have to remove my spacers because I barely have any meat left on the studs…. But i could be wrong…
  27. Jul 18, 2021 at 6:59 PM
    Mallcrl
    Mallcrl New Member
    Anand
    Maryland
    '25 Limited TRD-OR
    If the bumper is shimmed, it would depend on the size of the shims; just from looking at the studs, I think if you had 1/2" bumper shims (I think the Toytec shims in my garage are 1/2"?) you wouldn't be able to use the lightbar brackets at all, or maybe 1-2 threads?
    I'll be pulling my lightbar (and bumper) off tomorrow or Tuesday as I install my ARB Bumper and will try to remember to measure the length of remaining threads on the studs
  28. Jul 18, 2021 at 7:12 PM
    infidel
    infidel New Member
    Jesse
    SE Wisconsin
    2016 Silver SR5 Crewmax
    Procomp 3/1 Method 307 18x9 +25 Falken Wildpeak AT3W 295/70r18
    Side note, how did you order the bar with yellow and white, unless I'm blind and don't see something on the website
  29. Jul 18, 2021 at 7:38 PM
    Mallcrl
    Mallcrl New Member
    Anand
    Maryland
    '25 Limited TRD-OR
    You can order replacement lenses in either clear or amber, and change the beam pattern or color of each module
  30. Jul 18, 2021 at 9:04 PM
    BigDawg_Trd
    Ok cool. Keep me posted.
    I have eight 3/8 washers per stud. That measures out to 1/2 inch.
