2016 trd pro headlight problem
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by 4rekk, Dec 29, 2020.
  1. Dec 29, 2020 at 8:25 PM
    4rekk
    4rekk [OP] New Member
    Arek
    Indianapolis
    2016 tundra sr5 crewmax
    Hello everybody.
    I am totally new regarding pick ups and tundras. I went to do state inspection test today and my tundra failed because of passenger headlight. I don’t even know how to name the problem. I need to fix it so I was googling it for last few hours with no effect. The passenger side led strip is not working. Don’t know if it’s fixable. I attached some pictures to make it easier to understand.
    Have any of you guys had this kind of a problem? Do you know how can I fix by myself?
  2. Dec 29, 2020 at 9:39 PM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Problem is those are aftermarket headlights...:mad:
    There is nothing stock about them for a 2016, or any Tundra year model for that matter...:confused:
    I'd pull the bad one, check all the connectors, and see if you can find a name of the company that made them on it..
    Otherwise there are a few members here selling their halogen headlights (what you had stock) and perhaps you could buy them..
    Also your Tundra is not an TRD Pro.
    It looks more like an SR5, maybe with a TRD package.
    Not that there is anything wrong with that.
    But it is NOT a TRD Pro.
    TRD Pros do not have chrome bumper ends and SR5 chrome grilles and hood bulges.
    If you had a white 2016 TRD Pro, it would look like this, down to the bedside STAMPED TRD Pro..
    I'm pretty sure you have a 2016 SR5.
    And welcome to the forum..
    Hang around and participate after you get this resolved..:thumbsup:
  3. Dec 30, 2020 at 3:14 AM
    Bad Cow
    Bad Cow GOD Bless The USA
    Georgia USA
    2019 TRD PRO - SUPER WHITE
    Leather Steering Wheel, +1.5" Shackles
    Check the wiring. If that's good then you just have bad LED's. Nothing to do except replace it, or both.
  4. Dec 30, 2020 at 9:23 AM
    4rekk
    Arek
    Indianapolis
    thanks 1lowlife for your answer. I checked my headlights and they are recon 264294. I also checked connectors and everything is looking good. I checked voltage with a meter and there is no voltage at all on the passenger side ‍♂️ Even when headlights are on. I tried to get inside of the headlight but I’m afraid I will brake silicon looking sealing around the front plastic.
  5. Dec 30, 2020 at 9:25 AM
    andnyleswillriot
    andnyleswillriot Not Remote Working
    Breckenridge, CO
    2016 DC w/ Black Topo Topper
    Toytec 3" w/2.5 Coilovers. SPC UCA's. Method Roost Bronze Wheels. 35" BFG KO2's. SPC Upper Control Arms. 2019+ TRD Pro Grill. LED headlight bulbs. 2020 OEM LED Fog lights. Tech12volts Remote Start. MobArmor Magnetic Phone Mount. Topo Topper.
    Someone shoulda told ya to stay away from Spyder brand stuff.
    1lowlife likes this.
  6. Dec 30, 2020 at 9:34 AM
    4rekk
    Arek
    Indianapolis
    The thing is I bought the truck like this 6 months ago. I’m not familiar with pickups cause I’m from Europe. Just trying to find some help on this forum. I’m not even sure which wires are for the LED strip :/
  7. Dec 30, 2020 at 9:43 AM
    NoRcptn
    NorCal
    2017 Platinum
    You might be spinning your wheels, so to speak. Saw these on Tundras marketplace. You could have your problem solved in about 15 minutes.
    https://www.tundras.com/threads/2016-led-drl-headlights.80423/
    4rekk[QUOTED][OP] and 1lowlife like this.
  8. Dec 31, 2020 at 8:12 AM
    NoRcptn
    NorCal
    2017 Platinum
    @4rekk Oof. I read this too fast. I just realized these are LED upgraded bulbs. I cannot advise you to use those in that housing and I cannot say whether or not they will even pass your state's vehicle inspection.
    I just checked on Facebook Marketplace and found quite a few. Price seems to be between 80-150 for a set of stock OEM's. The only issue is you'll probably need to find someone selling local so you can plug it in an guarantee they work prior to purchase.
    Here's an example.
  9. Dec 31, 2020 at 10:37 AM
    4rekk
    Arek
    Indianapolis
    I bought Oem headlights off 2018 tundra and they have different wiring. I don’t have enough connectors in the truck to hook up the headlight.
    Is it possible to replace the led strip inside of the headlight?
  10. Dec 31, 2020 at 10:43 AM
    NoRcptn
    NorCal
    2017 Platinum
    Not that I’m aware of. However @iHacker can probably hook you up with with information or wiring harness for your 2016.
  11. Dec 31, 2020 at 11:23 AM
    iHacker
    iHacker SW TRD PRO
    Mario
    TRD PRO Super White CM
    2019 TRD PRO LED Headlights, 2019 TRD PRO Rigid LED Fog lights, All LED Interior, LED Cargo Lights, Bed LED Lights, Undercover Flex, Husky Weather beater floormats, FORTIN EVO ONE remote start, TDR Cold Air Intake, Tundra tail gate inserts, Pop & Lock...
    Check this video my friend minute 1:45 I remember in this headlights the LED strip is spliced to the side marker bulbs so isn’t a true DRL and actually works as parking lights only
    https://youtu.be/GGspzq4SnO4
    Make sure the bare wires in the harness are ok I think is a green and black wires using bullet connector plug covered in a clear rubber cover
    NoRcptn and 4rekk[OP] like this.
  12. Jan 16, 2021 at 7:01 AM
    4rekk
    Arek
    Indianapolis
    Hi again guys.
    So I replaced my old recons to original 2018 tundra headlight. After I did it now my turn signal lights are flashing faster than before...
    Does anybody has idea what it happens? What could be the reason and how to fix it?
  13. Jan 16, 2021 at 7:11 AM
    blanchard7684
    blanchard7684 New Member
    fast blinkers usually means the bulbs for blinker are failed.
  14. Jan 16, 2021 at 7:31 AM
    4rekk
    Arek
    Indianapolis
    All bulbs are working
  15. Jan 16, 2021 at 7:33 AM
    blanchard7684
    Then there is a voltage drop to the headlight unit affecting their performance. Or there is a mismatch between the bulb type and the blinker relay.
  16. Jan 16, 2021 at 7:34 AM
    AZBoatHauler
    So.Arizona
    Hyperflash can occur when using LED bulbs on a setup designed for incandescent. You can swap your amber bulbs to incandescent or add resistors to the LEDs to get rid of the hyperflash.
  17. Jan 16, 2021 at 8:16 AM
    4rekk
    Arek
    Indianapolis
    AZBoatHauler
    should I replace all four bulbs? Front and rear?
  18. Jan 16, 2021 at 8:22 AM
    AZBoatHauler
    So.Arizona
    Just changing one or the other on each side might be enough to get rid of the hyperflash.
