Regear For 35s?
Discussion in 'Performance and Tuning' started by rodl12, Dec 28, 2020.
  1. Dec 28, 2020 at 4:41 PM
    rodl12
    rodl12 [OP] New Member
    Rod
    South Jersey
    2017 Tundra SR5 Double Cab
    I've been reading some threads on regearing and it's hard to find any definitive answers. I'm guessing the gear ratio I would go to from the stock 4.30 would be to 4.56 to accommodate 295/70 (34.3") tires. That doesn't seem to be that much of a difference. I would like to recoup some of the fuel and performance lost due to a larger tire size especially when I'm towing my TT. Will that make enough of a difference to regear?
  2. Dec 28, 2020 at 5:51 PM
    Zero One Actual
    If you run the math on how much it costs you to fuel up your truck and how many MPGs you get versus $3000-$4000 dollars that will answer your question on re gearing for 35’s. I run 285/75R18s and get 12mpg on avg. I do not think re gearing would make it worth it for me for a potential 1-3 mile per gallon gain.
  3. Dec 29, 2020 at 3:16 AM
    rodl12
    Rod
    South Jersey
    Actually the math at 3 mpg given 12,000 miles a year would save you $450. I would think the install would be closer to $2,000 or maybe less. And then there's the performance gain with less strain on the drive train. This is my DD as well as my tow vehicle.
  4. Dec 29, 2020 at 3:39 AM
    Zero One Actual
    Then let’s do this thing. There’s your answer sir.
    Elduder likes this.
  5. Dec 29, 2020 at 3:41 AM
    TXTundra2722
    2015 Black Tundra
    Also.... you only have two choices anyways for our trucks and gears and that's 4.88 and 5.29.
    Zero One Actual likes this.
  6. Dec 29, 2020 at 4:26 AM
    rodl12
    Rod
    South Jersey
    I've been looking at the 4.56 ratio, that's what my calculation comes to. Are you saying the 4.56 gear set isn't available for the Tundra?
  7. Dec 29, 2020 at 4:58 AM
    TXTundra2722
    2015 Black Tundra
    Yes, we only have 4.88 and 5.29 for our trucks..... they don't make any other sizes for us
    Flyinryank and Zero One Actual like this.
  8. Dec 29, 2020 at 5:51 AM
    Johnders2586
    Johnders2586 New Member
    2017 Tundra SR5 W/TRD pkg
    Toytec Performance Aluma 3" Lift- Toytec rear shackle, Fuel Vector Wheels, Toyo Open Country C/T 295/70/18 Tires
    I towed my TT with lift and 295/70 never felt it was under geared or underpowered.. My gas milage went down probably roughly 1-2 mpg overall.. When I first bought the truck best I got was 15 ish when I traded it, best I got was 13ish.. Not towing . Averaged about 10 towing.. Unless your set that you have to re gear, personally I wouldn't bother . I will say the truck did downshift more on long grades ect.. But overall drivability was just fine ...Regear is mucho $$$ for the average person to justify IMO..
    Bigboitundra and Zero One Actual like this.
  9. Dec 29, 2020 at 5:57 AM
    RollTide82
    RollTide82 New Member
    Michael
    2019 Tundra 4x4
    Just get a supercharger
  10. Dec 29, 2020 at 12:02 PM
    dirtydeeds
    Keith
    USA
    more than I can list here
    Give Keith Carty of Dirty Deeds Industries a call at 760-877-4234. He knows everything about regearing and other things you can do to better upgrade your truck. Plus, we have the best pricing on gears!!!
    Thanks, Shawna
  11. Dec 29, 2020 at 12:08 PM
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
    THIS ^^^^^
    DjSamthrax and Zero One Actual like this.
  12. Dec 29, 2020 at 8:05 PM
    Fspmdt
    Fspmdt New Member
    2016 tundra 1794
    Bam 8 exhaust 285/70 18 ridges 4:88 gears, auburn lsd 6112s SPC UCA
    I have 4:88s with 34s improved mpg and no more gear hunting. The truck is much happier. Its worth the money
  13. Dec 30, 2020 at 4:57 AM
    rodl12
    Rod
    South Jersey
    I did talk to Keith at Dirty Deeds and he recommended the 5.29 gear set. I'd like to do some more research, 4.88s do seem to be the the logical choice but 5.29s may be a better option.
  14. Dec 30, 2020 at 6:21 AM
    coTony
    Tony
    Montrose, CO
    I have been running 35’s with 5.29 gears for over a year now. I would not go back
  15. Dec 30, 2020 at 6:24 AM
    Fspmdt
    Fspmdt New Member
    2016 tundra 1794
    35+ run 5:29s there is only 100 rpm difference at 70mph between 4:88 and 5:29.
  16. Dec 30, 2020 at 6:29 AM
    Ckatz53
    Ckatz53 Newish
    MD
    www.fouroneodetailing.com
    I did the math. If I remember correctly, you'd have to fill up 297 times with a 38 gal (32) tank to break even.
    Necessary? Is it necessary to drink my own urine? No, but it's sterile and I like the taste.
    -Patches
    Patches agrees, JUST DO IT. Im on 35s and 2k miles into 5.29s with a rear PowerTrax Grip Pro. Best money spent in a while.
  17. Dec 30, 2020 at 6:39 AM
    Cfincke
    Cfincke Mall Crawler but capable
    San Antonio
    2014 Tundra 1794 CM 5.7 4x4 sunset bronze
    5.29s, Auburn LSD, 37x12.50R18, Icon coilovers and shocks, SPC UCA's, Tech 12 Volts sound system, Enve Grill
    I haven been running 5.29s since Feburary with 295/70R18 (34.3"x11.5) tires. My MPG is 0.3mpg lower than before gearing, but the power and acceleration is worth it. I plan to go up to 35s next and 37s eventually.
    Towing is so much easier and trans temps stay under 200 98% of the time. We did a 2200 mile trip to Florida back in June towing our 26 ft camper, truck had no issues at 70mph.
    Before gears, pulling the camper thru the Texas hillcountry the truck would constantly downshift to 3rd and sometimes 2nd gear while going 45-55mph trying to maintain speed. Now the truck stays in 4th gear and will only drop down to 3rd if I push the pedal down.
    I daily drive my truck 12-15k miles a year and enjoy my truck more now after gears.
  18. Dec 30, 2020 at 7:54 AM
    coTony
    Tony
    Montrose, CO
    yeppers and with all the additional weight from armor, tires, etc. it works
    The Speedo has been corrected so the actual speed and RPM are accurate
    TRDFerguson and Hightide like this.
  19. Dec 30, 2020 at 9:58 AM
    TXTundra2722
    2015 Black Tundra
    Haha! This is just slightly faster than the posted speed limit right?
  20. Dec 30, 2020 at 10:33 AM
    coTony
    Tony
    Montrose, CO
    I forgot to mention that I have my Speedo corrected and it is right on. The posted speed limit is 75, the GPS from 2018 is slightly off on when it starts and stops the speed change location
  21. Dec 31, 2020 at 7:37 AM
    rodl12
    Rod
    South Jersey
    Thanks guys, that's what I was looking for!
    Can you tell me what your cost was and the maker of the gear set?
    AstroDude likes this.
  22. Dec 31, 2020 at 9:45 AM
    Cfincke
    San Antonio
    I got Nitro 5.29 gears and Auburn LSD from BossOffroad during their 2019 black friday sale. I recall it being around $1500 for parts, install was $1k. Nitro prices have gone up twice since I bought my gears and I would look into the Powertrax GripPro LSD now. Matt and MCM fab can get you the grip pro
  23. Dec 31, 2020 at 9:52 AM
    Hightide
    chadington von banks
    Abalama
    Magic School Bus
    BossOffroad Black Friday 2020 deal -
    Nitro 5.29
    1625.00 shipped
    You will probably find the largest discount in the gears.
    The Powertrax is a new item so most don’t have much wiggle room on those.
    porkitt and rodl12[OP] like this.
  24. Dec 31, 2020 at 10:58 AM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    I don't think the posted speed limit is 75 anywhere on the 101... but your secret is safe with us :fistbump:
  25. Dec 31, 2020 at 4:07 PM
    Downytide
    Downytide New Member
    GTA
    Lunar Rock that whines
    Decision decisions, long tube first or gears first........
    pvn.beluga and Hightide like this.
  26. Dec 31, 2020 at 4:10 PM
    Hightide
    Abalama
    Magic School Bus
    I vote gears.
    More bang for your buck.
    Elduder and Zero One Actual like this.
  27. Dec 31, 2020 at 4:14 PM
    Samoan Thor
    Samoan Thor God is technically an alien
    Limited 2014 crewmax 4X4
    Kings F&R, no sway bars
    Go back to stock tire size, I love the power plus the fuel mileage is great, not the best but better than everyones that's lifted or has bigger tires. Also research about gear whine, some people have reported after regearing that there's a whine that can be heard while driving.
  28. Dec 31, 2020 at 4:57 PM
    Zero One Actual
    You can hear checking accounts? Woah.
  29. Dec 31, 2020 at 6:08 PM
    Downytide
    GTA
    performance too? I know changing diffs will have quicker acceleration just not sure how much it'll improve in this case, I have this unhealthy obsession of trying to hit 13"s before forced induction.
    I tow sub 7k lbs and Ontario is as flat as it gets, so not too concern with towing.
  30. Dec 31, 2020 at 6:21 PM
    Hightide
    Abalama
    Magic School Bus
    There’s a post in one of these multitude of threads on gearing that shows a video of a number of tundras on a dry lakebed racing from a dead start.
    1. 4.88s
    2. 5.29s
    3. Supercharged
    4. Headers with 4.88s
    All on 35s
    The guy with 5.29s smoked them all.
    I like fast too!
