  1. Dec 28, 2020 at 4:18 PM
    TNTundra16
    TNTundra16 YOU BIG DUMMY!
    Cam
    Amish Country, TN
    2016 CM SR5 4x4 SSM
    A few too many looks like :cheers::rofl:
    1lowlife likes this.
  2. Dec 28, 2020 at 4:20 PM
    jefroshm0
    jefroshm0 New Member
    Elk Grove, CA
    2018 Cement Tundra Crew 4x4 SR5
    Installed some Diode Dynamics Pro Pods in the new bumper. Converted factory fog lamp harness to DT connector so they run off the factory switches on the Tundra.
    Just need to replace the Cali with another set of DD and get the light bar installed and I’m done with that project.
  3. Dec 28, 2020 at 4:30 PM
    TundraRV
    TundraRV New Member
    2021 SR5 SX Double Cab
    Made a build thread for it because i've been to busy adding items since the purchase 2 months ago.
    BUILD THREAD HERE
    jpod, GAknight, judsonpreuss and 9 others like this.
  4. Dec 28, 2020 at 4:38 PM
    BRP479
    BRP479 New Member
    Ricky
    Rogers,AR
    TVD decal
  5. Dec 28, 2020 at 4:56 PM
    TNTundra16
    Cam
    Amish Country, TN
    2016 CM SR5 4x4 SSM
    So clean!
    TundraRV[QUOTED] likes this.
  6. Dec 28, 2020 at 5:55 PM
    Steve18
    Steve18 New Member
    Virginia Beach
    2016 Black 4Runner Trail and 2021 Black Tundra TRD Pro
    itstorbs[QUOTED] likes this.
  7. Dec 28, 2020 at 6:54 PM
    TomC843
    TomC843 The wheel weaves as the wheel wills.
    Tom
    Charleston, SC
    16, 4X4, 4U3, Katzkins, Flowmaster, ARE MX, Swing cases, TRD skid plate, Volant CAI....
    If I ever have someone in the back seat (shiver) they will have a handle.
  8. Dec 28, 2020 at 8:44 PM
    49ºNRTH
    49ºNRTH New Member
    2022 Platinum WCP
    Bed lights and colour matched the mirror caps and door handles
    GAknight, montez25, Jcmf52 and 14 others like this.
  9. Dec 29, 2020 at 6:33 AM
    Pangaea
    Pangaea New Member
    BC
    2021 Cement Tundra CM TRD Off Road Premium
    A little center console mod/organization, fabricated out of some scrap aluminum at work. Nice to have all my backroad map books in one place. My seat-back pouches will thank me as well...
    1lowlife, WFD473, GAknight and 22 others like this.
  10. Dec 29, 2020 at 6:42 AM
    2020TundraVooDooBlue
    2020TundraVooDooBlue New Member
    Added remote start for my 2020 SR5 TSS Offroad from Tech12Volts! The only issue was getting to the TPMS wire to patch in the interrupt wire so I could use the FOB to unlock it after it was started.
    Forgot. Added this too...
    Changed it up a bit.
  11. Dec 29, 2020 at 6:59 AM
    @49ºNRTH how difficult was it to add the lights? been thinking about doing that
  12. Dec 29, 2020 at 7:49 AM
    49ºNRTH
    49ºNRTH New Member
    2022 Platinum WCP
    Wasn't terribly difficult, just took a while to route the wire loom from the drivers floor to the rear of the truck and zip tie everything up and out of the way. There are templates for the holes required in the box making that pretty straight forward too
  13. Dec 29, 2020 at 9:03 AM
    mghtyducks93
    mghtyducks93 Bubble Head
    Southern California
    2015 White Double Cab
    Missed taking a picture of the milestone, but this is close enough! Haha over 50,000 miles now0BB516ED-C732-4E11-AA62-38C3D00C750B.jpg
  14. Dec 29, 2020 at 9:09 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    Let us know what you think about it after installing the resonator. I just installed the same system about 2 weeks ago, left the resonator off. Overall it is quieter than I expected. Have not towed with it yet. May eventually install the resonator when I take off the tailpipe to paint it. Would love to hear your thoughts on the system with and without resonator.
  15. Dec 29, 2020 at 10:21 AM
    Rabidllamas
    Rabidllamas New Member
    Phil
    WA
    2019 Cement Crewmax TRD OffRoad
    My build- https://www.tundras.com/threads/rabbidllamas-old-man-build.80802/
    Did the Fyre Flys LED light upgrade. Boy the footwell light is a PITA! That took 15 min by itself. The other lights were easy-peasy.
    BlueRibbon4x4 and RainMan_PNW like this.
  16. Dec 29, 2020 at 10:47 AM
    OnespeedTRD
    OnespeedTRD New Member
    Don
    San Diego
    275/70r18 Cooper AT3 XLT on SCS Ray 10s, Eibach Coilovers, DD 12" Exhaust, AJT Blackout Kit, Truxedo Pro X15, paint match/chrome delete.
    For those on the fence about installing the Helmholtz resonator in the DD exhaust, I’d recommend go ahead and do it. It doesn’t cost anything in terms of power and it doesn’t change the overall sound or tone of the exhaust, all it does is get rid of the resonant sound at cruising/constant RPMs (drone) by matching that tone a 1/2 wavelength out of sequence. Your exhaust will sound the same while driving around and when you really get on it, you just won’t have the resonating drone sound at constant highways speeds. I don’t really see a downside to it. Maybe Kieth from Dirty Deeds can shed more light on it, but I’m pretty sure he tuned that resonator just right for these exhaust systems. A Helmholtz or J-bend resonator is really the only way to guarantee no drone in most exhaust systems.
  17. Dec 29, 2020 at 11:58 AM
    CorsoTundra
    CorsoTundra This is the way
    North GA
    2021 Cement Trail Edition
    Toytec Aluma 3/1.5, Pro headlights, OEM LED fog lights, AJT chrome delete, interior/exterior LEDs, front TRD sway, 18x9 Method Roosts, 285/75/18 Toyo A/T 3, RCI engine skid,
    Rhino rack with Vortex bars
    Then put the AGM battery in this truck thats been sitting in the garage since September from the totaled truck and put the SDHQ terminals on
    GoForthMGM, GAknight, Ltaco17 and 8 others like this.
  18. Dec 29, 2020 at 1:30 PM
    the ER kid
    the ER kid New Member
    2020 Platinum Crewmax
    Santa brought me a new grille, DD fog lights are next....0356F69E-9C2C-45FC-AE9B-5B9CC9D244BE.jpg
  19. Dec 29, 2020 at 2:22 PM
    WILLINH
    WILLINH New Member
    BILL
    NEW HAMPTON, NH
    2019 TUNDRA
    I installed my 10” last week and put the resonator on. No drone at highway or cruising speeds. Really like it and have had many compliments from friends and employees I work with. Gotta love it!! A excellent upgrade over stock.
  20. Dec 29, 2020 at 2:32 PM
    RobertD
    Robert
    DFW, Texas
    Well... was planning to start painting my tow hooks. Vehicle maintenance is new to me, turns out my little ratchet is not enough to lossen the bolts. Tried my impact wrench but no luck and didn't want to damage the bolts. Guess its time to invest in some better tools
  21. Dec 29, 2020 at 2:47 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    The truck is two months old...I turned 4100 miles on it today.
  22. Dec 29, 2020 at 2:51 PM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    Holy crap. You need a Prius AND a Tundra.
    Blue Thunder likes this.
  23. Dec 29, 2020 at 3:00 PM
    RainMan_PNW
    Casey
    Clark County, WA
    Nope...I love to drive my truck, but can't stand being in a Prius.
    Forgot - I also put 32.5 gallons in it today too. ;)
  24. Dec 29, 2020 at 3:06 PM
    BlueRibbon4x4
    Geno
    2015 Blue Ribbon 4x4
    Decided to install a in-cab switch for the on-board compressor. 6B9B0CBC-EE0E-440D-8AF1-F7EDDFB947F7.jpg
  25. Dec 29, 2020 at 3:16 PM
    RainMan_PNW
    Casey
    Clark County, WA
    Where'd that shifter trim come from that replaces the useless tray? I haven't seen that one before...I like it.
  26. Dec 29, 2020 at 3:21 PM
    BlueRibbon4x4
    Geno
    Thanks! I got it off a dude from Facebook. It started like this. Then I fiberglassed it in and painted it. I’ll see if I can pm you a link. 72D8DDBE-49C8-4695-BAD7-73AF50B5C588.jpg
    GAknight, mgm16trdpro, equin and 4 others like this.
  27. Dec 29, 2020 at 3:24 PM
    RainMan_PNW
    Casey
    Clark County, WA
    Got it - that's quite the fiberglass job! Looks great.
    BlueRibbon4x4[QUOTED] likes this.
  28. Dec 29, 2020 at 3:27 PM
    ElNopal
    Willis TX
    19 Cavalry Blue CM
  29. Dec 29, 2020 at 3:28 PM
    BlueRibbon4x4
    Geno
    My man! :thumbsup:
    ElNopal[QUOTED] likes this.
  30. Dec 29, 2020 at 3:28 PM
    BlueRibbon4x4
    Geno
    Thank you sir!
