1.25 Shims up front with 5100's and Toytec 1.50 shackles
Discussion in 'Suspension' started by JerseyTundra1260, Mar 22, 2017.
  1. Mar 22, 2017 at 2:18 PM
    JerseyTundra1260
    JerseyTundra1260 [OP] 08 Silver streaking!!!!!
    Marc
    New Jersey
    08 Silver Tundra DC Limited 4x4
    Too many to list.....
    I already have 5100's installed on top setting. If I was to add the Coachbuilder's I am assuming that would leave me with just enough rake correct? Based on the 1.25 Spacers and 1.75 shackles. Also would my ride change much. I would think maybe a little more stiff ride. Maybe tighter in the rear with the beefed up shackles. Any input would be great. :thumbsup:
  2. Mar 22, 2017 at 2:47 PM
    Spvrtan
    Spvrtan Amateur fabricator
    Kris
    San Diego, CA
    Black '14 CM SR5 w/ SC; 40s on 17s; 5.29s
    You don't need his driveline spacers unless you have a 12" lift. Potentially if you had a 7" lift and are a 4x2 but most likely not.
    Bob likes this.
  3. Mar 22, 2017 at 3:19 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    You mean the carrier bearing drop?
  4. Mar 22, 2017 at 3:40 PM
    JerseyTundra1260
    Marc
    New Jersey
    I am sorry.... I had a moment. I meant shims up front with shackles in the back. I'm actually just trying to go up a little bit more. So down the line I can add a taller tire. Keeping a good ride as well. On top of that do not want to break the bank so to speak. Any suggestions for shims and any other way to go along with my 5100's would be great.
  5. Mar 22, 2017 at 4:44 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Ohhh I got you. Yeah the ride will be a bit harsher but not as much as a 3" spacer would make it.
    Shouldn't have a problem with anything in the back, it's the shims on top of the front shocks that would make for a harsher ride.
    Two shims per side is the most I would go if at all.
  6. Mar 22, 2017 at 4:52 PM
    JerseyTundra1260
    Marc
    New Jersey
    Ok cool. I just want to go up 1.25 in front and 1.50 in the back. That should in allow me to go taller later on without killing the ride. Plus I want a little taller stance. Who makes a good shim? Going with the Toytec shackles I think. They are pretty cheap $$$ wise.
    GNTundra likes this.
  7. Mar 22, 2017 at 5:06 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    You don't have the adjustable bilsteins?
    Oh wait I see you have them on top setting already. I think @CaptTyler did that with his at the beginning. He would know about the ride better than I do.
    And coachbuilder makes good shims.
  8. Mar 22, 2017 at 5:14 PM
    JerseyTundra1260
    Marc
    New Jersey
    Great. Thanks
    Law323[QUOTED] likes this.
  9. Mar 22, 2017 at 5:22 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    No problem Marc!
  10. Mar 22, 2017 at 6:06 PM
    Bear
    Bear Fargin' Iceholes
    Bear
    Custer, SD
    2022 GMC Sierra 3500 Dually
    Pulsar Edge V3; MBRP side dump exhaust
    True story!!! I was just going through them. Gotta get that warranty n rebate!! Just sayin'...
    :duel:
  11. Mar 23, 2017 at 5:04 AM
    SOB
    SOB Big Member
    Ohio
    2013 Red Crew Max Platinum
    Here's what @Coachbuilder1 described to me when I asked about a little more lift on 5100s (edited to remove unnecessary details). If I'm understanding your question correctly this should help.
    Shims provide .50"of total lift. Usually one shim will correct the front left corner clean.
    +2" Coachbuilder shackles provide 1.25"of total lift. Hardware and a carrier bearing drop kit included.
    Poly bushing kit will be required to use in the rear leaf spring eyelets.
    When using the 5100s on the top setting you'll see 2.5"of lift up front and would recommend our +2"s with this application. if you want 3" up front you can use 2 shims on the left and 1 on the right to achieve this. You would want to use our +3"s with this application, they provide 1.75"of total lift.
    Law323 likes this.
  12. Mar 23, 2017 at 5:15 AM
    JerseyTundra1260
    Marc
    New Jersey
    Great.... Thanks for the info :thumbsup:
  13. Mar 23, 2017 at 8:31 AM
    PMG
    PMG New Member
    Anyone know the lift if the 5100 is set to middle with a shim up front?
    PMG
    mattyd170 likes this.
  14. Mar 23, 2017 at 9:10 AM
    SOB
    SOB Big Member
    Ohio
    The 5100s give approx 2" on mid and 2.5" on top. Shim from Coachbuilder adds 1/2" each. Not sure about the Toytec shims that @GNTundra mentioned - haven't seen any info on those.
  15. Mar 23, 2017 at 10:36 AM
    Netmonkey
    Netmonkey Don't be a Dumbass
    Georgetown, TX
    from toytecs website:
    http://toyteclifts.3dcartstores.com...ies-Height-Adjustable-Front-Shocks_p_150.html
    (2) 24-232173 - Bilstein 5100 Series Height Adjustable Front Shocks
    • Height adjustable front shocks for 07+ Tundra and 08+ Sequoia
    • Adjustable in 3 positions for lift of .87", 1.57" or 2.28" (Adjustment required before assembly).
    • Uses stock coil springs
    • Priced per pair- Includes (2) of 24-232173 Shocks
  16. Mar 23, 2017 at 11:01 AM
    SOB
    SOB Big Member
    Ohio
    Regarding the .87", 1.57" or 2.28" - per Bilstein's install instructions "Ride heights indicated are typical. Actual ride height is influenced by which factory suspension the vehicle is equipped with and its condition; optional equipment and accessories on your vehicle, and other vehicle modifications such as replacement coil springs, wheel and tire combinations, etc."
    It's my understanding that the Tundra's are closer to 2" and 2.5". I would imagine the installed coils are the biggest factor to the actual height achieved. I do not have mine bought or installed yet so I have no real world experience - just regurgitating what I recall from reading on this forum.
