Wheel selection vote! Vote here and change my life!
Discussion in 'Wheels & Tires' started by Zero One Actual, Dec 28, 2020.
Method or KMC
Poll closed Jan 11, 2021.
  1. Method 313
    55.4%
  2. KMC Trek
    44.6%
  1. Dec 28, 2020 at 9:53 AM
    Zero One Actual
    Zero One Actual [OP] Member among Members
    Crisis needs expert resolution:
    I currently have 18” Method 315 (plus 18 offset) wheels with Toyo 285/75R18 MTs. (Cement truck with gold wheels pictured) Total weight per wheel/tire is 106lbs. I just upgraded to the C4 Overland bumper and I have Bilstein 6112s on top setting and Total Chaos UCAs and a CMC done by @BashFab giving me room for 37 inch tires.
    Doing research on 37’s I discovered the following.
    Cooper AT3 XLT 37x12.50 is 68lbs a tire.
    KMC 17in KM545 Trek wheel (photos below) is 27lbs with a +18 offset. Total weight (wheel and tire combined) is 95lbs or 11lbs lighter than current setup but with 37’s.
    Method 313 17in wheel is 24lbs with a +25 offset. Total weight is 92lbs or 14lbs lighter than current setup but with 37’s.
    Price difference between the KMC and Method is about $320 more per set of four for the Methods. The Methods are 3 pounds lighter per wheel/tire combo than the KMC setup.
    Both are available in 5x150 bolt pattern in black.
    Any opinions/advice? For some reason the KMC design is a little more appealing to me personally. The Method is a bit more of a standard truck design but both are acceptable.
    Thank you for reading this novel and voting. *I also posted this in the dirty sevens thread as well.
  2. Dec 28, 2020 at 9:58 AM
    Stewie
    Stewie New Member
    2016 Crew Max
    My vote is to get whatever floats your boat in a 17” rim.
    before I went with 17” rims I priced tires for the 18” rims that I had. 37” tires are cheaper for 17” rims for some reason.
  3. Dec 28, 2020 at 9:58 AM
    Yoder18
    Yoder18 Veteran underwater basket weaver
    Mitch
    Front range Colorado
    18 tundra trd off-road
    •Toytec Radflo 3” with 1.5 shackles •+25mm icon rebound wheels matte black. •Prox15 tonneau/Softtopper •315/70r17 ridge grapplers •Wheelers front bumper stops •Spray in bed liner •Vleds floorwell leds front and back and interior led kit •Boss front bumper spacer •First choice fabrication welded sliders •8” ss dirty deeds exhaust •Tech12volts remote start with carlink •Vleds front turn signals leds •AFE pro dry s air filter •Baja xl sport amber fogs •Victory 4x4 strike bumper w hoop •Ajt designs chrome delete for vent rings and cup holder/gear shifter (black) •Wet okole seat covers •Husky floor liners •RCI skid plate and transmission skid •Jomax SpEed sensor guards •Rear diff breather location mod
    Hadn’t seen the KMC but those look dam good! I wouldn’t mind the weight difference and on 37’s those will look badass!
  4. Dec 28, 2020 at 10:08 AM
    Zero One Actual
    I agree. Just seeing what people think of both and the weight savings and price difference. I already have gold 18's, so I am not scared of floating my boat. Hahaha.
    @Squatting Pigeon is the one who turned me on to the KMC 17 inch wheels for our trucks in the 5x150 bolt pattern.
    Hightide and Squatting Pigeon like this.
  5. Dec 28, 2020 at 11:07 AM
    Zero One Actual
    Well great. Its a tie so far.
    Tundra2 likes this.
  6. Dec 28, 2020 at 11:22 AM
    I like them both but opted for the Methods. Might be easier to spiff up when needed. Maybe.
  7. Dec 28, 2020 at 11:40 AM
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
    ...As I vote method :anonymous:
  8. Dec 28, 2020 at 11:52 AM
    RobertD
    Robert
    DFW, Texas
    Would you go bronze for the KMC wheel? Or are you looking at black for both brands?
  9. Dec 28, 2020 at 12:13 PM
    Bronzeback
    Bronzeback New Member
    There’s a dude on here with a code he shares for 20% off methods if that helps the decision making process.
    Tundra2 and Zero One Actual[OP] like this.
  10. Dec 28, 2020 at 12:22 PM
    Squatting Pigeon
    Holden
    North Texas
    @Zero One Actual The code is:
    PNWTUNDRA2020
  11. Dec 28, 2020 at 12:24 PM
    Bronzeback
    nice
    Zero One Actual[OP] likes this.
  12. Dec 28, 2020 at 12:25 PM
    Zero One Actual
    I contacted KMC and they have no information or idea if they will make the bronze or grey in 5x150 bolt patterns. They also stated the Trek in 5x150 is two to three months out from shipping from overseas.
  13. Dec 28, 2020 at 12:41 PM
    Gunship Guy
    Gunship Guy New Member
    Rick
    Always go with your first choice. Analysis paralysis is a PTA. If the wheels are rated even in appearance, I VOTE FOR METHOD. Unsprung weight, but that's just me.
  14. Dec 28, 2020 at 12:41 PM
    Dceclipse
    Dceclipse New Member
    NORCAL
    I do like the KMC
  15. Dec 28, 2020 at 12:54 PM
    Zero One Actual
    I don’t have a first choice yet hence me asking the Tundra public. I do agree with you on the savings of 14 pounds per wheel well though for sure. Gun ready?
  16. Dec 28, 2020 at 12:54 PM
    Zero One Actual
    I agree.
  17. Dec 28, 2020 at 1:01 PM
    Squatting Pigeon
    Holden
    North Texas
    Such a close race!
  18. Dec 28, 2020 at 2:10 PM
    Zero One Actual
    This is just giving me more forum anxiety.
  19. Dec 28, 2020 at 2:12 PM
    Zero One Actual
    Thank you for that.
    There is a site called expertvoice.com. See if you qualify to sign up for it under any of their requirements. GOVX is also similar but expertvoice has much better selection of stuff in my opinion. Anyways, really awesome discounts on all sorts of great companies like Method and others.
    Bronzeback[QUOTED] likes this.
  20. Dec 28, 2020 at 2:21 PM
    Squatting Pigeon
    Holden
    North Texas
  21. Dec 28, 2020 at 2:26 PM
    Zero One Actual
    Black Wolf likes this.
  22. Dec 28, 2020 at 2:28 PM
    Squatting Pigeon
    Holden
    North Texas
    panicman and Hightide like this.
  23. Dec 28, 2020 at 2:34 PM
    Zero One Actual
  24. Dec 28, 2020 at 2:38 PM
    Squatting Pigeon
    Holden
    North Texas
    :humble:
  25. Dec 28, 2020 at 2:59 PM
    RobertD
    Robert
    DFW, Texas
    There's a reason he a mod :rofl:
  26. Dec 28, 2020 at 3:01 PM
    Squatting Pigeon
    Holden
    North Texas
    I thought it was the bribe money?
    panicman, landphil and Black Wolf like this.
  27. Dec 28, 2020 at 3:43 PM
    RobertD
    Robert
    DFW, Texas
    I didn't elaborate for a reason :anonymous:
    There's a reason my broke ass isn't a mod lol
  28. Dec 28, 2020 at 3:54 PM
    ....as usual?? :boink::anonymous:
  29. Dec 28, 2020 at 3:57 PM
    Squatting Pigeon
    Holden
    North Texas
    :spy:
  30. Dec 28, 2020 at 3:57 PM
    Squatting Pigeon
    Holden
    North Texas
    You heard the man :wink:
    landphil and Black Wolf[QUOTED] like this.
