Tundra for RAM?
Discussion in '2.5 Gen Tundras (2014-2021)' started by ultra1988, Dec 26, 2020.
  1. Dec 28, 2020 at 6:29 AM
    #121
    JLS in WA
    JLS in WA New Member
    2008 White DC Limited 4x4
    Drahthaar Transport Unit
    There isn’t a pickup around that will give you good gas mileage for your commute.
    Cpl_Punishment likes this.
  2. Dec 28, 2020 at 6:44 AM
    #122
    Minarets
    Minarets New Member
    Nashville
    2021 TRD PRO
    The cyber truck is coming.
  3. Dec 28, 2020 at 6:55 AM
    #123
    4WDWalrus
    4WDWalrus New Member
    The Silver Walrus
    TRD shift knob OEM Fender Flares Truxedo Pro X15
    Coming from old cars, the Tundra is very "high tech" to me. There is so much in the menu that have yet to explore. The center dash screen shows more info than I would need to know. It's cool to play around for the first week or so, but really don't add much value. I usually just get in the truck and go.
    I am far from tech challenged and have to say, there is nothing "high tech" about any of the mainstream trucks.
    I think most people have a misconception of "high tech". High tech is innovation that you might not see and not necessary interactive with, but improve upon life. Teslas' are innovative, not just because of the electric motors (because electric motors are not new innocation), but as the whole package. The seemless integration of software and hardware, from its camera security features to autonomous features. I am excited to see the Cybertruck and Rivian.
    High tech is not about adding X amount of blue tooth connections, X amount of USB ports, X amount of cameras, X amount of heated/cooled seats, X amount of LEDs, X amount of recline on seats, X size sun roof, X amount of customizations on screen, X amount of gears, vacuum cleaner, electric generator, refrigerator. Those are just old tech thrown into old platforms.
    There is a reason they are not reliable and gimmicky because they are all afterthought or thrown in and not well integrated.
    True innovation is in the integration. ie., instead of manually cycling through different camera views, vehicle would automate showing of the camera that is most useful during the situation. Same with the terrain selection, it should know that there is snow/sand and adjust accordingly.
  4. Dec 28, 2020 at 7:20 AM
    #124
    Asimov2025
    Asimov2025 Not Sure
    Trent Woods, NC
    2019 TRD 4x4 Sport
    Non-stop mods
    Personally I will take the gauges and radio...I replace my tablets every few years and use an old one on a Rago mount for a "Big Screen" when needed. Building tech into a vehicle only ensures obsolescence. I can buy a tablet for way less than the glitchy/gimmicky in dash stuff.
  5. Dec 28, 2020 at 7:47 AM
    #125
    crewmaxlmt
    crewmaxlmt How dare you!
    scott
    2020 Crewmax Limited
    I would personally take a double overhead cam V8 before a pushrod V8 anyday. also, you can have the "high-tech" cylinder cut-out for a few miles per gallon. I have heard way too many failure stories dating all the way back to the '80's to want one.
  6. Dec 28, 2020 at 7:48 AM
    #126
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Truck manufacturers still use pushrod V8s because they get better fuel economy under load that DOHC.
    BTBAKER likes this.
  7. Dec 28, 2020 at 7:49 AM
    #127
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    Yep!
    Just messing with you. I knew what you meant. You’re definitely at the upper limits. I’m always leaning on the on the lighter side. I try to keep what I’m towing around 60 percent of my rated tow capacity. I know that’s not necessary but it makes me more comfortable. Payload, like mentioned is the issue. With my family in tow, it doesn’t leave much left to play with. I would assume that will be addressed with the redesign. If not, Toyota completely missed the mark.
  8. Dec 28, 2020 at 7:49 AM
    #128
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    I agree with your post other than the inference that Tesla is reliable and not a gimmick.
    19crewmaxTRD and Black Wolf like this.
  9. Dec 28, 2020 at 7:55 AM
    #129
    ......at least it's not a Fiat.
  10. Dec 28, 2020 at 8:34 AM
    #130
    Lovetrucks
    Lovetrucks Member
    2019 Ram Rebel
    If it was they’d sell a lot more . lmao
  11. Dec 28, 2020 at 8:39 AM
    #131
    JLS in WA
    True. I was speaking to existing inventory.
    Black Wolf likes this.
  12. Dec 28, 2020 at 8:43 AM
    #132
    Downytide
    Downytide New Member
    GTA
    Lunar Rock that whines
    I had a 2019 Ram Rebel, had all the options minus air suspension.
    I loved the interior, like many said, its probably best one so far, I would say the new 2021 f150 is still a step below, but the little things drove me nuts, I had zero mechanical issue for the engine, but the cylinder deactivation was getting very very noticeable in one year I owned the truck, you could feel the vibration as if someone kick the truck, the issue of cam wear will probably come up like some had issues with.
    Issues I had:
    - navigation sometimes freeze , one out 3 times I use the GPS it will freeze and requires turn car on and off.
    - reverse auto braking sometimes go nuts, it'll brake for no reason, some had issue with the auto braking for cruise control too.
    - I had issue with the rear locker, it sometimes just won't engage.
    - rear shocks had seeping that I want them replace under warranty, but they claim I use the truck beyond what its meant to do (I use it on trails and house chores).
    For mileage, my Rebel is maybe tiny bit better, if you worry about mileage and want a ram, get one that has the taller ratio, I think 3.25, with those you can hit 20mpg on hwy with none at tires.
    Overall, I liked my Ram, but love the Tundra, Tundra drives likes wrx of 1/2 tons.
    If you want a good commuter that doesn't see much off road use, then yes I can see attraction of the ram 1500, just avoid e torque if you want a hemi.
    Pbed85, WILLINH and Lovetrucks like this.
  13. Dec 28, 2020 at 9:03 AM
    #133
    Lovetrucks
    Lovetrucks Member
    2019 Ram Rebel
    I’ve heard about some of the earlier builds having those issues , some had the whole radio replaced under warranty. I haven’t had any issues with mine but I’ve only had it for just over a year now .
  14. Dec 28, 2020 at 9:05 AM
    #134
    crewmaxlmt
    scott
    True, but only in the lower RPM range. As the RPM's increase, the DOHC's efficiency increases well over the pushrod design. As for the reliability between the two, the DOHC is only less reliable if using a timing belt. The 5.7 uses timing chains, when compared to less components of the pushrod design, create a more reliable valve train.
    I am not trying to argue. I am just trying to make a point that the big three putting so much into added features are selling bells and whistles rather than reliability.
  15. Dec 28, 2020 at 9:19 AM
    #135
    ShreveportTSS
    ShreveportTSS Huh?
    Eric
    Louisiana
    2018 5.7 4x4 Crewmax TSS
    My 3 year old Tundra is worth more than a Ram as soon as the paperwork is signed.
    Cjames17, Patch999, Pbed85 and 6 others like this.
  16. Dec 28, 2020 at 9:36 AM
    #136
    Downytide
    GTA
    Mine was built in June 2019, I believe the modules are still the same until uconnect 5 comes out, I actually had one that was built earlier as demo/loaner while they get the truck ready as it was delayed for no reason, and that truck was a 2018 built, the damn screen just go blank randomly at times.
    Another thing that really ticked me off was they stopped the bilstein remote reservoir rear shocks production, I think around March, so when I had seepage on the rear shocks, they gave me bs excuse saying no replacement shocks are available, which I knew was bs.
    Pbed85 and Lovetrucks[QUOTED] like this.
  17. Dec 28, 2020 at 9:38 AM
    #137
    G10dra
    G10dra Not a New Member
    The dodge you want vs the dodge I want..
    [​IMG][​IMG]
    Otherwise, I'd dodge the whole thing.​
  18. Dec 28, 2020 at 9:54 AM
    #138
    don3032
    don3032 New Member
    don
    2021 Tundra Limited Crewmax Nightshade
    debadged, diamondback, window tint, dirty deeds exhaust.
    The Cummins with the AISIN is prob the best drivetrain combo you can get other than 6 speed manual maybe. I looked for a few months for that combo before I Got my tindra and came down to not needing anything that large to tow anymore, even though my 2500 5.9 2wd averaged over 20 mpg.
  19. Dec 28, 2020 at 11:34 AM
    #139
    ultra1988
    ultra1988 [OP] New Member
    2019 tundra
    This isn’t a complaining about poor mileage post. That being said. My dads Silverado gets 16mpg average 100% city driving. I get 10mpg with some mixed highway. Do the math over 30,000 miles. I’m excited about the new tundra. I’m hoping there’s a lot of desire for the old V8 and my truck goes up in value for trade in.
  20. Dec 28, 2020 at 11:38 AM
    #140
    truckmax
    truckmax New Member
    Max
    Corona, CA
    2016 SR5 TRD CM 4x4
    LED lights,Rear sway,tint,cover,liner,cat protector,skid,running boards,mats,pedal commander,tint, and $$$ etc etc.
    Yup,you will make it up "ultra1988" with reliability, smiles, and $$$ at trade-in, has worked for me and many others I know.
  21. Dec 28, 2020 at 11:49 AM
    #141
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Borrow your dad's truck for a week, drive it on your commute exactly the same way you drive your Tundra and then tell us what mileage you get. Too many variables for an accurate comparison otherwise.
    Hoff, truckmax, jtwags and 1 other person like this.
  22. Dec 28, 2020 at 11:50 AM
    #142
    ultra1988
    2019 tundra
    I owned my Silverado for 4 years and after I lemon lawed it I got 95% of my original purchase price back. Living in California has its perks, well that may be the only one...
    Airn890 likes this.
  23. Dec 28, 2020 at 11:51 AM
    #143
    FWC
    FWC New Member
    Frank
    Upstate NY
    2019 Tundra Black Platinum
    At the end of the day there is only so much "tech" you can use at one time. My '19 Platinum is the most comfortable truck I have ever owned, do I wish it had a better sound system yes, can't really argue with the mpg I get 15-16 running around over 18 on the highway. Besides reliability, the 2 most important things are the comfort level of the seat and the ride quality, mine has it in spades and will most likely run forever. I will stick with my Tundra.
    Hoff, tttrdpro, Black Wolf and 2 others like this.
  24. Dec 28, 2020 at 11:51 AM
    #144
    ultra1988
    2019 tundra
    I used his truck to tow my boat 600 miles last summer and got 4mpg better than my tundra gets on the same trip at the same speed. But it is 2wd.
  25. Dec 28, 2020 at 11:52 AM
    #145
    JLS in WA
    That's kind of an important variable.
  26. Dec 28, 2020 at 12:01 PM
    #146
    bsktball55
    bsktball55 New Member
    Missouri
    16 Tundra TRD Pro
    Bakflip MX4 Toneau cover Esp storage Audio system (Helix speakers, JL audio amp and sub) Front windows and windshield tinted LED interior and bed lights
    My brother in law and I both have 2016 trucks. Mine is a Tundra TRD Pro and his is a Ram sport. I paid 45 for mine and KBB says it is still worth around 40. He paid around 38 for his and KBB says it is worth 20-24. Mine still looks new when it's clean, his clear coat is peeling. His has been in the shop a couple of times and mine hasn't. I've never actually ridden in his truck to see the difference in ride, but unless you really just want some fancy tech, you are down grading as far as truck function is concerned.
  27. Dec 28, 2020 at 12:03 PM
    #147
    ultra1988
    2019 tundra
    I would be curious to see mpg of a 2wd tundra that was lowered and had 31” tires.
  28. Dec 28, 2020 at 12:04 PM
    #148
    Asimov2025
    Asimov2025 Not Sure
    Trent Woods, NC
    2019 TRD 4x4 Sport
    Non-stop mods
    A four year lemon law?
    Cpl_Punishment and Black Wolf like this.
  29. Dec 28, 2020 at 12:11 PM
    #149
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
    1991 White Xtra-cab SR5 4X4 V6 5 speed 148K
    I'd be happy with either one.
  30. Dec 28, 2020 at 12:11 PM
    #150
    ultra1988
    2019 tundra
    No it starts from the first time you took your vehicle in for repair. For me it was leaf springs at 500 miles. Then took it in two more times until they finally admitted it wasn’t normal and replaced them. So when I hired the lemon law attorney at 35,000 miles because of oil consumption, he got it lemon lawed at 500 miles. Some states don’t even have lemon law. California is 100% on the buyers side.
    truckmax likes this.
