This person screwed up quiz.
Discussion in 'Off-Topic Discussion' started by Dalandshark, Dec 27, 2020.
  1. Dec 27, 2020 at 9:37 PM
    Dalandshark
    Dalandshark [OP] Infected with 5G
    Northwest
    2007 Tundra SR5 5.7 Longbed
    Eibach Level Lift, DIY SAIS preventer, headers.
    Well, I was going to post in the Superpower thread that I have the uncanny ability to follow behind where other people royally screwed up (not that I don’t make mistakes).... there is a direct vent unit heater mounted below the roof. Can you spot all the problems with this... there are at least 4, more if you get really technical.050FE87A-44EC-40E5-A15F-1EBC3EA36DEC.jpg
  2. Dec 27, 2020 at 10:29 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    1- I’m seeing single wall pipe, not double wall B-vent.
    2 - WTF is up with that cap?
    3 - Roofing screws with rubber gaskets in the pipe / cap. High temp rated?
    4 - That roof boot / flashing with gooped on caulking (is it really latex caulk?) is amazing. We’re not venting a crapper here.
    1lowlife and Dalandshark[OP] like this.
  3. Dec 27, 2020 at 10:36 PM
    RangerBP
    RangerBP SC Expat. Go gamecocks.
    2017 4x4 DC, Silver Sky
    Um. Is that a plunger head? :eek:
  4. Dec 28, 2020 at 3:11 AM
    Hightide
    chadington von banks
    Abalama
    Magic School Bus
    holy crap!
    at least it was in a metal roof... I guess is what they were thinking.:eek:
    not sure what the hell they’re doing with that gray piece of “flashing”.!?.!?.!?.!?
    In their defense, they did use a high temp pipe boot... incorrectly, but it is a high temp boot.
  5. Dec 28, 2020 at 3:48 AM
    timdske
    timdske Another Old Guy
    Fort Worth Texas.
    2019 MGM SR5 4x4 Tundra TSS Offroad
    It appears to have been installed by the shop "Handyman" and not a HVAC tech. Give him an "A" for effort.
    Dalandshark[OP] likes this.
  6. Dec 28, 2020 at 4:03 AM
    trucksareforgirls2
    trucksareforgirls2 New Member
    Northeast USA
    2020 Voodoo Blue TRD Off-Road
    Looks well installed to me... :confused:
  7. Dec 28, 2020 at 4:17 AM
    Omohundro
    Omohundro 2018 Not a Pro
    Jody
    McMinnville TN
    2018 Tundra Platinum
    Bak Revolver, BedRug, Undercover Swingcase, PopLock, Bilstein 5160(rear), Firestone RideRite, TRD rear sway bar, Coachbuilder +2 rear shackles, Andersen 5” aluminum adjustable hitch, TRD dual exhaust, VLEDS interior leds including the footwell kit, TundraTex FRAC mod, VLEDS LPR backup tag mount led, Husky X-Act mats, Color matched cup holder bezel (silver), Ceramic 20% tint all around, 50% Ceramic windshield, Color Matched door handles & mirror caps, The “Stubby” antenna, AMP Research steps, VLEDS 6”step lights, ToyTec/5100 Bilstein coil overs, 700lbs red ToyTec springs (2.75” lift), 20x9 +18 Method 306 custom painted and custom fit center caps, Gorilla spline lugs, Bridgestone Revo 3s 285/60R20, TRD skid plate, RaptorLiner “Red” tow hooks, 19 Pro black LED headlights, VLEDS Triton V6 turns, Rigid SAE D series fog lamps, 19 TRD hood scoop, 2019 TRD Pro grille, Coachbuilder bumper shims, X-Pel protect under mud guards, Opti Coat Ceramic, Opti Coat Sealed. And some snakes and sparklers, because they are my favorite!
    Exactly what I was thinking!
  8. Dec 28, 2020 at 4:33 AM
    glowblue
    glowblue From time to time
    VA
    Looks like a section of plain old HVAC ducting and not proper exhaust piping. Eith way, with no support bracing that thing would bend in half with any decent gust of wind.
  9. Dec 28, 2020 at 4:43 AM
    RollTide82
    RollTide82 New Member
    Michael
    2019 Tundra 4x4
  10. Dec 28, 2020 at 8:40 PM
    Dalandshark
    Northwest
    Good Job. The snow knocked down the original vent, the roof was about a year old and so the roofing company came out and "fixed it", no one checked the work. Fast forward a couple more years and the heater is actually needed. So now it's set up for taking combustion air from nowhere, because that rubber boot is covering over the air intake pipe that is cut at roof level. The gray metal flashing is half of the original flashing that used to fit around the concentric vent (air intake portion) that is no longer there. In it's place is:
    1. Duct pipe - not even single wall vent pipe.
    2. No storm Collar.
    3. Leak at the boot where the "vent" seam enters through it.
    4. Leak at the original screw holes in roof (hard to see in the pic unless you look close)
    5. Screws through the side of the vent - I guess that's ok since it is wrong anyway.
    6. Even if it was single wall vent pipe, it doesn't have 6" clearance to combustibles.
    7. Just looks bad overall.
    8. Should probably get some use as a plunger.
  11. Dec 28, 2020 at 8:50 PM
    Hightide
    Abalama
    Magic School Bus
    Nothing betting than extra water and CO2 in the building.
  12. Dec 28, 2020 at 9:13 PM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Remind me tomorrow to take a picture of the one whoever installed the garage heater in my house put on that one. I still haven't gotten around to fixing it.
    Hightide likes this.
  13. Dec 28, 2020 at 9:42 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Wouldn’t that be an “F” for effort? :D
  14. Dec 28, 2020 at 9:59 PM
    Lightning_Lad
    Lightning_Lad New Member
    Tom
    Orange CA
    2017 Silver Sky Platinum Pro
    Line x Bed liner Trifold Tonneau cover TRD PRO Dual exhaust TRD PRO sway bar TRD PRO air intake TRD PRO suspension TRD PRO LED 2019 Headlight conversion TRD 2020 Wireless charging tray TRD shift knob TRD PRO Grille TRD red anodized dust caps (+25 hp per wheel) Matt black mirror caps and door handles Tesla style Headunit KTJO 4x4 tail gate pop n lock upgrade Driver side grab handle Viper Remote start Viper alarm system 18” Method NV’s 33.5” Toyo R/T ESP Long box underseat storage 3M ceramic tint
    1) Not B vent or double wall vent, it’s gonna get ‘effin’ hot
    2) Storm collar. Lack of.
    3) It’s been screwed.A lot.
    4) Seams and flashing aren’t right. High temp boot or not...
    5) Hard to tell, but it looks like the top of the vent is still below the apex of the roof.
    6) Weird choice of yellow sealant where boot meets flue.
    It takes more effort to eff that up than actually install it right.
