Brake light on dash stays on
Discussion in '2nd Gen Tundras (2007-2013)' started by 605John, Dec 27, 2020.
  1. Dec 27, 2020 at 10:15 AM
    605John
    605John [OP] New Member
    2013 Crewmax
    I searched the site and couldn’t find any other threads about this. I have a 2013. About a month ago the emergency brake light on the dash started to come on intermittently. I checked to make sure that the pedal was fully returned. It is. The problem kept getting worse and now whenever the key is on, the light is on. Everything seems to be working correctly. Does anybody have any ideas what I should be checking and/or replacing?
  2. Dec 27, 2020 at 10:17 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Check the brake fluid level.
  3. Dec 27, 2020 at 10:19 AM
    TheBeast
    TheBeast The Beach
    do you have access to a code reader ? if there is a light there should be a code
  4. Dec 27, 2020 at 11:53 AM
    605John
    2013 Crewmax
    You’re the man! That’s exactly what it was. I didn’t realize that the same light is the warning for low brake fluid and e-brake engaged. Thank you!
    Wynnded[QUOTED] likes this.
  5. Dec 27, 2020 at 11:54 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Multi-tasking lights!
  6. Dec 27, 2020 at 11:55 AM
    605John
    2013 Crewmax
    You made a good suggestion. Unfortunately the code reader I have access to didn’t reveal anything. However, another poster suggested low brake fluid and that was right.
    TheBeast[QUOTED] likes this.
  7. Dec 27, 2020 at 12:01 PM
    I check under hood fluid levels every weekend. Takes maybe 2 minutes....
  8. Dec 27, 2020 at 12:02 PM
    TheBeast
    TheBeast The Beach
    easy fix ;)
  9. Dec 27, 2020 at 12:33 PM
    605John
    2013 Crewmax
    2 minutes every weekend is 104 minutes a year. I’ve had my truck for 8 years so that would be 832 minutes. I spent 1 minute fiddling with the parking brake, 5 minutes posting the question and 5 minutes reading the responses and replying to them. I guess that puts me 821 minutes ahead.
    Sorry, just messing with you. You’re advice is spot on, but it sounded so much like my dad that I had to rebel a little. I hope you take it in the spirit intended.
    Black Wolf[QUOTED] and TheBeast like this.
  10. Dec 27, 2020 at 12:47 PM
    Positive outcomes are always good..:thumbsup:
  11. Dec 27, 2020 at 4:36 PM
    audiowize
    audiowize New Member
    Paul B.
    2008 Tundra SR-5 4x4 5.7
    It would likely be wise to check the condition of your brake pads sometime in the near future. When you fluid gets low enough to turn the light on, often that's due to the pistons in the caliper being pushed way out (from worn pads).
  12. Dec 28, 2020 at 3:15 AM
    FWD Tundra
    FWD Tundra New Member
    Washington
    2013 Tundra 4WD Double Cab
    Ditto on the brake pads worn.
  13. Dec 28, 2020 at 7:02 AM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Ditto on the brake pads as well... I would be cautious if you do your own brakes as topping it off, while pushing the pistons back in place can cause the tank to overfill and bathe all your components in the general area with brake fluid...
