Knock sensor code
Discussion in '2.5 Gen Tundras (2014-2021)' started by dhdubey88, Dec 15, 2020.
  1. Dec 15, 2020 at 5:26 PM
    dhdubey88
    dhdubey88 [OP] New Member
    Roseville
    2017 SR5 crew max
    Flowmaster 40 series muffler Headache rack/tonneau cover Bilstein 6112 at top notch Bilstein 5160 Coachbuilder +2 shackle Rear diff breather relocate Coachbuilder bumper shims Lower control arm skid trim Oedro bolt on sliders Raceline injector 18” wheels 35x12.5x18 toyo RT
    On Sunday I was out driving my truck when my traction control got stuck in the off position with my check engine light on. Stopped by autozone to get the code read and it was saying a knock sensor was bad. I have 38000 on my truck.
    dis some research and found that rats like to get under the intake manifold and eat the knock sensor wiring harness.
    Before pulling my intake manifold up I picked up the wiring harness from local Toyota shop. Unbolted the intake manifold to find one of the knock sensor connectors totally disconnected due to those rat bastards.
    after a hell of a time due to the large clamp holding the wires to the rear of the intake manifold my buddy and I were able to get the knock sensor wiring harness replaced.9E95A81F-982A-4948-BD1F-048D48DE1B47.jpg
  2. Dec 15, 2020 at 6:02 PM
    dhdubey88
    Roseville
    2017 SR5 crew max
    I didn’t find much on the 3rd gen with this issue but did find 2nd gens with the issue. I believe it’s the same part number but for my 2017 tundra 5.7 it was
    Part number 822190C020
    (Knock sensor wiring harness)
    If anyone has rat tracks or any signs of rats in the engine bay I recommend addressing the rats as soon as possible to avoid this issue.
  3. Dec 15, 2020 at 6:18 PM
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Toyota soy based wires are delicious! :hungry:
    ColoradoTJ likes this.
  4. Dec 15, 2020 at 6:37 PM
    dhdubey88
    Roseville
    2017 SR5 crew max
    Best year! Haha
  5. Dec 15, 2020 at 6:37 PM
    dhdubey88
    Roseville
    2017 SR5 crew max
    Damn vegan rats
  6. Dec 15, 2020 at 7:01 PM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    I thought they only had those in California.
  7. Dec 15, 2020 at 7:51 PM
    dhdubey88
    Roseville
    2017 SR5 crew max
    Well... I do live in California. They are probably commifornians
    Ruggybuggy[QUOTED] likes this.
  8. Dec 22, 2020 at 8:04 PM
    13tundradude
    13tundradude New Member
    LOS ANGELES
    2012 TUNDRA
    2013 4.6 ENGINE AND TRANS. COUPLED WITH A 5.7 REAR END LSD
    Both of my sensors are out, considering the bits of plastic bags and candy wrapers I had to blow out of the rat den/intake manifold I am pretty sure they remodeled after years of squatting. mines a 2nd gen
  9. Dec 23, 2020 at 7:22 AM
    dhdubey88
    Roseville
    2017 SR5 crew max
    bummer! gotta do a demo on the remodel
    13tundradude[QUOTED] likes this.
  10. Dec 23, 2020 at 10:06 PM
    13tundradude
    LOS ANGELES
    2012 TUNDRA
    I had vegans too.
  11. Dec 24, 2020 at 12:06 AM
    dhdubey88
    Roseville
    2017 SR5 crew max
    Dang!
  12. Dec 24, 2020 at 11:41 PM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    A couple of times a year I pull of the engine cover and give it a good pressure wash.
  13. Dec 25, 2020 at 11:22 AM
    13tundradude
    LOS ANGELES
    2012 TUNDRA
    if I pressure wash under the hood with my belt driven pressure washer I will wish I had rats under the hood afterwards.
    Any pressurized water over 3000 psi might break connectors and even cut wires if you get close enough.
    shoot my 15 degree spray nozzle puts dents on sheet metal.
    i just finished scraping and wiping dirt and filth with rag and microfiber. I’m ready to start putting everything back together, hoo raaa.
  14. Dec 25, 2020 at 11:25 AM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Use a "normal" type pressure washer like the ones found at the car wash. :thumbsup:
  15. Dec 25, 2020 at 1:41 PM
    13tundradude
    LOS ANGELES
    2012 TUNDRA
    I call those side arms
  16. Dec 25, 2020 at 5:41 PM
    preacher35
    preacher35 RIGHTEOUS MEMBER
    2018 MGM Platinum Crewmax 4x4
    After Hurricane Harvey completely flooded my little town (my street became an island, apparently), and two of these little bastards got into my garage and wreaked havoc on my wife's Infiniti. So, I got a RAT ZAPPER from Home Depot. I loaded it with some peanut butter and placed it along side a wall in the garage. Within 48 hours, the little bastards were stir fried!!! Oh, and it's fun too! It was very cathartic to walk out into the garage in the morning and see that tail sticking out of the Rat Zapper.
    Not my video, but it gives you the general idea.
    Ruggybuggy likes this.
  17. Dec 27, 2020 at 5:51 AM
    dhdubey88
    Roseville
    2017 SR5 crew max
    I live in an old home, built 1912. And it seems like the same rats are still alive from then because they are so damn hard to get. I have pest control that puts bait boxes and traps, but their traps didn’t work for crap. They would trip them then eat the prize. I even had one eat two pumpkins last year! The second one I was hoping he would eat because it was full of coolant. He did eat it and didn’t die! Borrowed a buddies rat zapper, didn’t work. Traps only work at my house if they are camouflaged With the normal debris that is in the area.
    I did just purchase some peppermint spray to periodically spray my engine bay to hopefully keep the rats out. I will update as time goes with the peppermint spray.
  18. Dec 27, 2020 at 7:01 AM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Try rat poison. Just be careful of it's placement if you have pets.
