Blue smoke out of the exhaust.
Discussion in '2nd Gen Tundras (2007-2013)' started by Vince, Dec 26, 2020.
  1. Dec 26, 2020 at 6:50 PM
    Vince
    Vince [OP] New Member
    Vincent
    Terre du lac, Missouri
    2011 White DBL cab 5.7
    K&N intake, Air bags
    250000 miles noticed puff of blue smoke out of the exhaust must be valves having build up on it, or are they toast. Any way to flush the engine to clear it up.
  2. Dec 26, 2020 at 7:23 PM
    Bucks04
    Bucks04 New Member
    2013 TRD Tundra
    Working on it
    Sounds like just valve seal , or could be just a little blow by on oil ring. at 250,000 wouldn't even worry. as long as it's only small amount at start up. Doesn't sound like burnt valves or anything major if just a puff of smoke. Just keep eye on oil level to see if burning a lot of oil. Not sure about all the sensors on these things , but it could even be a vacuum leak sucking in a little oil . Maybe switch to high mileage oil.
  3. Dec 26, 2020 at 7:31 PM
    Vince
    Vincent
    Thank you, kind of what I thought also.
  4. Dec 26, 2020 at 7:38 PM
    audiowize
    audiowize New Member
    Paul B.
    2008 Tundra SR-5 4x4 5.7
    I don't suppose you're on your original PCV valve? I'd spend the $5-10 that a new one costs and just throw the old one away. That might completely clear up your problem.
  5. Dec 26, 2020 at 7:54 PM
    myktundra
    myktundra New Member
    2011 Tundra DC TRD SAP
    I noticed mine did this a bit this morning, hadn't driven it in a couple weeks, just moved it out of the way a couple times. A little smokey and smelly but it cleared right up after a bit. I'll check the oil tomorrow but I suspect she just doesn't like sitting around for a while not being driven.
  6. Dec 27, 2020 at 6:14 AM
    Vince
    Vincent
    I replaced it few months ago.
  7. Dec 27, 2020 at 6:15 AM
    Vince
    Vincent
    That could be it too been on vacation here for the holidays and have not driven her for a few weeks.
  8. Dec 27, 2020 at 8:15 AM
    audiowize
    Paul B.
    I am a big fan of AT205 reseal, and you could try adding 75mL to your oil. This is a very gentle rubber reconditioner, and it might be just what you need to soften up your valve stem seals just a little bit. If you find that this resolves your issue, you can experiment with adding a bit less with your next oil change.
    Having just come from owning a Dodge Ram, I used a LOT of AT205.
    Rex Kramer likes this.
