Lift kit installed, so it's time for new tires!
Discussion in 'Wheels & Tires' started by MetalheadCP, Dec 26, 2020.
  1. Dec 26, 2020 at 11:24 AM
    MetalheadCP
    MetalheadCP [OP] New Member
    I installed this 2.5" lift kit on my 2020 TRD Pro -
    https://www.suspensionconnection.com/52080-tundra-trd-pro.html
    Does anyone know how much of a taller/wider tire I can put on the stock 18" BBS93 rims (currently with stock P275/65R18 tires in the pictures)?
    I don't want to trim anything, so 35s are definitely out. Maybe 33s? I want lots of clearance, so more height is not as important as more width (want them to poke out when viewing from front or rear). This is my first time lifting a truck so thanks in advance for any advice!
    Cheers
    -cp
  2. Dec 26, 2020 at 11:27 AM
    MetalheadCP
    BTW Tuff Country, who makes the lift kit I bought, recommends 33" x 12.5" (with no trimming required), but would that size tire fit on the stock rims or require new rims?
  3. Dec 26, 2020 at 11:42 AM
    HighonFirewood
    HighonFirewood Everything can be fixed with a hammer.
    Stage Left. Colorado
    2019 Tundra
    33’s easily. I’m stock without even a pro lift and I have 33.2’s. You can do 34s (295/70) and maybe a 285/75/18 (which is a narrower 35”) depending on the offset of your rims (are Pros 0?)...
  4. Dec 26, 2020 at 11:48 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    295s on 18inch wheels, about 34 inches tall and will work with the stock wheels. They fit better than 35x1250s and will give you the beefy look.
    MetalheadCP[OP] and SC_TRD like this.
  5. Dec 26, 2020 at 11:52 AM
    SC_TRD
    SC_TRD Big BASTRD 4x4 Enthusiast
    Colin
    Round Rock, Tx
    2012 CrewMax & 2008 Sequoia
    295/70r18 is what I also recommend. No trimming should be required. Put them on my sequoia after installing a 3” lift kit and without trimming there is no rub.
    MetalheadCP[OP] likes this.
