Secret Santa 2020 'What Did Santa Bring You??' Thread
Discussion in 'Off-Topic Discussion' started by Secret Santa, Nov 18, 2020.
  1. Dec 24, 2020 at 8:17 PM
    #301
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Someone please let me know where to get these stitched leather door handle inserts.....:thumbsup:
    My felt inserts fly out of the door when I blow the dust off with compressed air..:eek2:
  2. Dec 24, 2020 at 8:18 PM
    #302
    Mater
    Mater New Member
    SD
    2016 MGM Platinum
  3. Dec 24, 2020 at 8:37 PM
    #303
    1lowlife
    DADA
    2014 MGM DC SR5
    TaquitoBandito and Mater[QUOTED] like this.
  4. Dec 24, 2020 at 11:34 PM
    #304
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
  5. Dec 25, 2020 at 2:00 AM
    #305
    Zero One Actual
    All this leather “sling” and static shock. I’m starting to worry about my fellow forum members.
    Merry Christmas everyone!!
  6. Dec 25, 2020 at 7:10 AM
    #306
    abomb60
    abomb60 Maker of things
    Massachusetts
    2018 Tundra 1794 MGM
    The stitched inserts were a special custom order for Santa as they take so much time make (over 2 hours of hand stitching for a set of 4) and probably will only be made as special gifts and not a normal orderable item. This is actually set 2 of 2 and the only other stitched set is in my truck. Normally they look the same just without the stitching. When my laser is back up and running this spring I'll be making these again as well as the keychains.
    They're made of 2mm leather plus another 3mm birch backing so I'm pretty sure no static shock will go through. Didn't realize that's a function of the OEM ones.
  7. Dec 25, 2020 at 7:23 AM
    #307
    Bravohook
    Bravohook New Member
    Addame
    NY
    2007 RCSB
    Cool Things
    According to FedEx my secret santa is still enroute with my RB20's.......
    Blue Thunder likes this.
  8. Dec 25, 2020 at 9:01 AM
    #308
    Jbehredt
    Jbehredt Burgeoning member
    Westminster, CO
    2020 TRD Pro DC White
    That’s easy to do when you setting expectations so low. Estimating domestic delivery times in weeks rather than days.....
  9. Dec 25, 2020 at 9:46 AM
    #309
    TaquitoBandito
    Joel (AKA Bif)
    There are three packages in limbo with the USPS that I don't recognize - me thinks one may be from my SS. Regardless, I wanted to thank @Secret Santa and all of the Tundras.com moderators and peeps. I've always appreciated the site but this year especially. Tundras.com was my 2020 Panic Room - a place I went to escape politics and read some really funny shit. So many of you have so much diverse knowledge and the rest of us are so good at bullshitting... I don't know, it's just been a good mix and a nice escape. Again, Merry Christmas to you all and thank you for making a shitty year tolerable.
  10. Dec 25, 2020 at 9:50 AM
    #310
    Blue Thunder
    Washington
    Well said...I couldn't agree more. Tundras is definitely an escape for me too.
  11. Dec 25, 2020 at 11:05 AM
    #311
    SC_TRD
    SC_TRD Big BASTRD 4x4 Enthusiast
    Colin
    Round Rock, Tx
    2012 CrewMax & 2008 Sequoia
    Thanks for the shirt Santa! Definitely already part of my preferred wardrobe, and making its Christmas Day Debut!
  12. Dec 25, 2020 at 4:14 PM
    #312
    nishibot
    nishibot Just2havnfun
    Perris, CA.
    2017 Tundra CM 4x4 TRD Off Road MGM
    Got a FRAC harness from my Secret Santa!
    Thank you "Santa"
    Also a huge thank you to all the other "Santa's"
  13. Dec 25, 2020 at 4:59 PM
    #313
    easleycrawler
    Travis
    Easley, South Carolina
    17 Tundra SR5 DC Black 5.7
    How many have not received the gifts yet? I bet usps has messed a few deliveries this year.
  14. Dec 25, 2020 at 5:09 PM
    #314
    TaquitoBandito
    Joel (AKA Bif)
    None for me but I have two coming from Stamps (due on the 28th) and one from DHL that was supposed to be here on the 24th but it got passed off to USPS and looks like it got sent to and lost in a town about 60 miles from here. Nobody sends me shit so I'm thinking at least one of the three is from my Secretest of Santas.
    4x4_Angel, JMB, RainMan_PNW and 3 others like this.
  15. Dec 25, 2020 at 5:18 PM
    #315
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    I didn't realize I had a special edition one. I'm starting to think I needs to keep them inside to avoid messing them up! I liked them before, but now even more bbn knowing they're VERY limited edition versions!:thumbsup::cheers:
  16. Dec 25, 2020 at 8:08 PM
    #316
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Only joined late in the year, but it was perfect timing. Couldn’t agree more. Looking forward to getting to partake in the SS next year.
  17. Dec 25, 2020 at 9:20 PM
    #317
    1lowlife
    DADA
    2014 MGM DC SR5
    Who actually touches that part?
    I only 'touch' them when they blow out of place while cleaning or if I remove them to take the door panel off.
    I must have the stitched ones..
    They look great...
  18. Dec 26, 2020 at 7:29 AM
    #318
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Static shock when exiting a vehicle occurs when the humidity is very low, usually in freezing air temps (at least in the South where humidity is usually much higher). It depends on several factors including seat materials and door handle materials. If you have built up a static charge from contact and rubbing the seat during your trip, when you step out onto the ground and touch the vehicle, it can equalize the voltage, generating a static shock. Touching a wool-like material, such as the OEM door handle inserts, has the effect of reducing the accumulated charge on your body, decreasing the likelihood of a static shock.
    Static shock is why you're not supposed to get into your vehicle while filling up with gas. The spark from the static shock when you get out is enough to ignite gas fumes if they have accumulated around your door.
    TaquitoBandito likes this.
  19. Dec 26, 2020 at 11:23 AM
    #319
    1lowlife
    DADA
    2014 MGM DC SR5
    Thanks for the static electricity lesson, Einstein..:eek2:
    My point was in the 6 years I've owned my 2014, I've never touched that piece of wool getting in or out of the truck..:thumbsup:
  20. Dec 26, 2020 at 2:59 PM
    #320
    TaquitoBandito
    Joel (AKA Bif)
    Thank you Secret Santa!! I got a really awesome t-shirt in the mail today.
    I'll be wearing it a lot - I love it. And, @4x4_Angel, it's so much better than a throat punch ;)
    Thank you again - I really appreciate it.
  21. Dec 27, 2020 at 6:02 AM
    #321
    4x4_Angel
    Bree
    Funky Town, Texas
    2014 SR5 CM Silver Sky
    :rofl::rofl:well some things are better than a throat punch:D
  22. Dec 27, 2020 at 6:08 AM
    #322
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
    Hmmmm I’m gonna have to try this.
    I usually grab ahold of the metal door post to ground me to the truck until both feet are on the ground.
  23. Dec 27, 2020 at 6:11 AM
    #323
    4x4_Angel
    Bree
    Funky Town, Texas
  24. Dec 27, 2020 at 7:58 AM
    #324
    RLHULK
    RLHULK Too many gamma rays in all that BBQ smoke.
    Rich
    2022 Silverado LT.
    Still rolling stock baby....
    My tundra has been shocking the top of my bald head lately when I enter or exit the truck.
    Starting to think it does not like me anymore.
  25. Dec 27, 2020 at 7:59 AM
    #325
    Squatting Pigeon
    Holden
    North Texas
  26. Dec 28, 2020 at 3:51 PM
    #326
    P-Factor
    P-Factor New Member
    2018 Tundra Limited Double Cab
    TRD Sway Bar, TRD Exhaust, TRD Cold Air Intake
    Many Thanks, Zero One Actual!!!
    Item made it home! :hattip:Very cool!
  27. Dec 28, 2020 at 4:01 PM
    #327
    TaquitoBandito
    Joel (AKA Bif)
    I just received a card saying I have another gift coming from my Secret Santa - thank you so much! I wore my "I'm Ugly" shirt yesterday. Love it.
  28. Dec 28, 2020 at 4:07 PM
    #328
    Zero One Actual
    I was not your secret Santa either! Muhahahahahaha.
  29. Dec 28, 2020 at 4:15 PM
    #329
    P-Factor
    P-Factor New Member
    Not sure what I'm missing here but Thanks anyway.
  30. Dec 28, 2020 at 4:17 PM
    #330
    Squatting Pigeon
    Holden
    North Texas
    Me thinks he may have been a Santa by proxy :monocle:
