If you have funny noise coming from your diff check your NEEDLE BEARING!
Discussion in '2nd Gen Tundras (2007-2013)' started by SargeBSA, Dec 24, 2020.
  1. Dec 24, 2020 at 10:00 AM
    SargeBSA
    SargeBSA [OP] Prior Taco Connoisseur
    Snohomish County
    2021 SR5 DC 4WD
    Offgrid Engineering Battery Bracket TRD-Offroad Wheels, LT265 75/r18 General Grabber ATX Tires, 38 Gallon Fuel Tank Swap
    Hello!
    Normally lurking over on Tacomaworld but I need yall's opinion. Coworker bought a 2010 Crewmax with 146000 miles on it, during the test drive he noticed a grinding noise that was indicative of a failing wheel bearing. The dealer he bought from warrantied it and replaced all four but the noise is still there, below is the text message he received IMHO sounds like the dealer no longer wants to do work on the truck and could easily be incorrect back lash on the front diff.
    I've done all the work on my Tacoma including replacing the clutch so I'm no stranger to turning wrenches on Toyota trucks but this one is stumping me. Anyone have a similar experience with this?
    132561360_187203466436550_14925909755791_e90bd054bb03911481bfb162900f9fa558f5eeb4.jpg
  2. Dec 24, 2020 at 12:34 PM
    audiowize
    audiowize New Member
    Paul B.
    2008 Tundra SR-5 4x4 5.7
    You're in my neck of the woods! Who replaced the bearings? (Name the dealer if possible) It's a total PITA to do and if this wasn't a Toyota dealership, it may not have been done at all. NOBODY would just arbitrarily replace all four wheel bearings, so I would call 100% bullshit on that. It sounds like your buddy will have to do his own diagnosis.
    To figure out if it's a wheel bearing, you'd need to back axle on jack stands, all the stability controls off, then you can immobilize one wheel and let the other spin freely in the back to see if the noise goes away with one wheel not moving. The fronts are easier to do, you can usually just lift the wheel off the ground and spin it hard to see if it makes much noise.
    NewImprovedRon likes this.
  3. Dec 24, 2020 at 2:19 PM
    SargeBSA
    Snohomish County
    2021 SR5 DC 4WD
    All four wheel bearings were replaced Monday(12/21) by Toyota of Marysville WA. See screenshot above.
  4. Dec 24, 2020 at 2:22 PM
    audiowize
    Paul B.
    This is extremely fishy. A competent tech would figure out which wheel bearing was making the noise, then replace that one. I don't suppose your coworker asked for the old parts back?
    I would quietly take the car to a different Toyota dealership and have them diagnose what's going wrong. I had Michael's in Bellevue look mine over so I could be 100% certain it was a rear wheel bearing (a Greg's Japanese location said it was just tire vibration, so don't go there!).
    SargeBSA[OP] and Black Wolf like this.
  5. Dec 24, 2020 at 3:06 PM
    SargeBSA
    Snohomish County
    2021 SR5 DC 4WD
    Issue is the dealer he bought the truck from is warranting the truck not Toyota which is why he has it there. Just trying to help out. Really curios if anyone has had noise coming from the diffs of transfer case that mimics a failing wheel bearing? Tried the search function but no results.
  6. Dec 24, 2020 at 3:13 PM
    pickeledpigsfeet
    pickeledpigsfeet New Member
    Sierra Foothills, Ca
    Kings & Icons
    Have him drive straight and switch it to 4hi and see if the noise goes away.
    SargeBSA[OP] likes this.
  7. Dec 24, 2020 at 3:16 PM
    pickeledpigsfeet
    Kings & Icons
    Tundras can have bad drivers side needle bearings just like the tacos. Ecgs sells the bushing and tool. If noise goes away in 4hi then thats where I would start.
  8. Dec 26, 2020 at 9:41 PM
    SargeBSA
    Snohomish County
    2021 SR5 DC 4WD
    Upon further inspection its the needle bearings failing. Thanks for the lackluster help! :crapstorm:
  9. Dec 26, 2020 at 9:44 PM
    audiowize
    Paul B.
    I have the puller down here if you want to borrow it. When I brought that up at the dealership, they said the slop was normal :/
  10. Dec 26, 2020 at 9:46 PM
    SargeBSA
    Snohomish County
    2021 SR5 DC 4WD
    Yep, dealer was useless took me about five minutes under his truck to diagnose it; same problem as my Tacoma.
  11. Dec 26, 2020 at 9:47 PM
    SargeBSA
    Snohomish County
    2021 SR5 DC 4WD
    It did go away which means needle bearing is bad.
  12. Dec 27, 2020 at 8:17 AM
    audiowize
    Paul B.
  13. Dec 27, 2020 at 8:46 AM
    The local Toyota Dealership did the same thing with my 12 CM Tundra. Threw parts at it. First they said it was a wheel bearing. I disagreed with them (I used a 40K dollar IR camera at work, it wasn't hot at all). I had Toyota Care...(so I didn't care). Replaced WB and didn't test drive, said it was good to go. Drove out of parking lot, 1/4 mile down the road and noise was still there. Made another appointment before I arrived home.
    Then the service department offered a sweet deal. 600.00 to swap in the ECGS bushing, not covered by warranty, void my front differential warranty. I laughed and said "thanks, but no thanks."
    They ended up replacing the complete front differential on Toyota's dime for 2400.00 and kept my Toyota Care warranty (still had 40K miles left on it).
  14. Dec 28, 2020 at 3:36 AM
    FWD Tundra
    FWD Tundra New Member
    Washington
    2013 Tundra 4WD Double Cab
  15. Dec 28, 2020 at 8:56 AM
    audiowize
    Paul B.
    It definitely shows a little more wear than it did before, but it's perfectly usable still.
    If I had let the bushing spend the night in the freezer, it would likely look even better.
  16. Dec 28, 2020 at 9:09 PM
    Dalandshark
    Dalandshark Infected with 5G
    Northwest
    2007 Tundra SR5 5.7 Longbed
    Eibach Level LIft
    A tech at a nearby dealer (to the ones mentioned above) said mine was the wheel bearing but wasn't' loud enough to tell which one. I took it back 1,000 miles later (it had gotten louder) and a different tech pointed me at the needle bearing. Saved a lot of money not having to swap transaxle thanks to the help on this forum and EGCS. I had bought a Zurich Warranty with my truck but they were not going to cover it and said it was a "wear item"... so I returned the 'very good' warranty. That was the first and last car warranty I will buy besides a Certified Toyota or New Vehicle warranty. Glad @SargeBSA figured it out.
  17. Dec 28, 2020 at 9:49 PM
    SargeBSA
    Snohomish County
    2021 SR5 DC 4WD
    Edited title for better clarification.
  18. Jan 2, 2021 at 6:04 PM
    08tundraDC
    08tundraDC New Member
    Brent
    2008 tundra, double cab, silver
    Stereo, LED light bar, amber lights
    How many miles are you all at? My 08 has 160k and just now having the needle bearing issue. Should I just replace the needle bearing or have the diff rebuilt? Not sure if anything else would be wore out at this point.
  19. Jan 2, 2021 at 6:18 PM
    Trident
    Trident New Member
    2007 Tundra DC 4X4
    Replace the needle bearing with an ECGS bushing. I did last weekend and I've been listening to mine growl for 70k miles. It's quiet now, I love it. My 2007 has 256k miles.
  20. Jan 2, 2021 at 6:40 PM
    08tundraDC
    Brent
    No worries about shavings tearing up other parts inside there?
  21. Jan 2, 2021 at 6:44 PM
    Trident
    Trident New Member
    2007 Tundra DC 4X4
    If you're talking about the ECGS bushing, no. They've got a fairly long track record with no negatives as far as I've seen. I wanna say ECGS claim 500k mile life expectancy.
  22. Jan 2, 2021 at 6:51 PM
    08tundraDC
    Brent
    No, I was worried that shavings from the old needle bearing might get inside and cause damage.
  23. Jan 2, 2021 at 6:57 PM
    audiowize
    Paul B.
    If anything you could pop out your drain plug and wipe off any metallic residue. I think you'll find metallic powder rather than chunks or shavings.
  24. Jan 2, 2021 at 7:00 PM
    Trident
    Trident New Member
    2007 Tundra DC 4X4
    Ah, sorry I misunderstood. In my case, my needle bearing was immaculate looking when I pulled it. Kinda surprised me bc I've seen them with missing needles, etc. It was definitely faulty bc my truck always sounded like it had mud tires on it coming to a stop. It's now silent at all times.
    At any rate, I don't forsee any damage coming from the faulty needle bearing. I don't think the needles are any match for the hardened gears of that differential even if they did dislodge and fall inside the differential itself. I combo'd my bearing replacement with a front diff fluid change as well.
    Here's my old needle bearing
  25. Jan 2, 2021 at 7:12 PM
    08tundraDC
    Brent
    That was 70k of listening to that?!? Mine started maybe 5k ago. I guess not much to worry about then. It is close to time to change the diff fluid, so this is the perfect time fo me to change the bearing and seal. Any tips on installing the new bearing and seal? I’ve done similar projects, as you know every project has its own little quirks.
  26. Jan 2, 2021 at 7:24 PM
    Trident
    Trident New Member
    2007 Tundra DC 4X4
    Yeah, bought it @ 188k miles in 2017 & just now changed it. I'm not proud of that fact but several factors played in.
    As far as tips go, I was led astray a bit by a write-up on another Tundra site. It had me removing things that didnt need to be removed.
    The axle nut (39mm) and lower ball joint (22mm) bolts along with the brake caliper (17mm) & brake line bracket (12mm)is the only things I removed to accomplish the install. Also unclipped the ABS sensor wiring with a pocket screwdriver. There are plenty of install videos on YouTube for Tacomas, 4Runners, etc. They're very similar to our Tundras.
    Tridom likes this.
  27. Jan 2, 2021 at 7:35 PM
    08tundraDC
    Brent
    Trident, thank you for all the help and advice. That was something I have been looking for the past week or so.
  28. Jan 2, 2021 at 7:48 PM
    Trident
    Trident New Member
    2007 Tundra DC 4X4
    You're very welcome
