6112 Setting for slight rake?
Discussion in 'Suspension' started by Buckmark1, Mar 30, 2019.
  1. Mar 30, 2019 at 11:58 AM
    Buckmark1
    Buckmark1 [OP] New Member
    2019 Cement SR5 CM - TSS Off Road 4x4
    Narrowing down my lift choices. Given I’m 99% highway I’m thinking 6112s up front and just 5100s in rear. Not planning to lift rear so trying to determine right height for front so I still have just a slight rake.....1.3 or 1.9?
    Have 19 CM 4x4.
    Other choice was the Falcon Leveling System but about $600 more than the above. Thanks for input on 6112s. Big decisions need expert advice!
  2. Mar 30, 2019 at 12:06 PM
    Faht Nocker
    Faht Nocker Platinum Member
    Woody
    Milky Way
    2016 Super Fast White Platinum 4x4 Faux PRO Tundra
  3. Mar 30, 2019 at 12:55 PM
    Spitfire
    Spitfire New Member
    Long Island
    2018 Cement Limited Trd off road
    1.3
    AZBoatHauler likes this.
  4. Mar 30, 2019 at 1:12 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    If you’re doing nothing to the rear, then 1.3”. 1.9”/1” gave me exactly 1” of rake.
  5. Mar 30, 2019 at 2:18 PM
    timsp8
    NY
    1.9” will give rake if you measure but look level or even nose high.
  6. Mar 30, 2019 at 7:25 PM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    Just add a coachbuilder #3 shackle then put the front at 1.9”. Would be like stock but almost 2” higher all around. Ok technically 1.9” front and 1.75” rear.
  7. Mar 30, 2019 at 8:01 PM
    Tundramoney
    Tundramoney Old school
    Earth
    1.3” for sure!
  8. Apr 1, 2019 at 3:03 AM
    justfortun
    justfortun New Member
    James
    Boston
    2016 SR5
    I’m at 1.3 and the ride is awesome. I just regret it took my 19 years of tundra ownership to upgrade suspension. At 1.3 I have a tad rake and looks perfect. It’s a double cab, not a crew, and I’m not sure how that plays into the rake math. Tires are KO2 275/70r18 Bought a shim but didn’t use it. I don’t think I’m low by more than an eighth of an inch and my shocks arrived before my shin and I didn’t have the patience! 521E9B29-93A1-4E1E-9B6D-92C3E8D88F08.jpg
    Not a great photo, but this the before I added the 6112s - wheel is slightly cocked and the light was different AAB868AE-C5E2-457A-BC84-159C3D6CC70E.jpg
    If you want to build them, here’s how I did it
    https://www.tundras.com/threads/dont-be-very-afraid-to-build-bilstein-6112.35488/#post-893799
    Blkdmax likes this.
  9. Dec 14, 2020 at 9:26 PM
    Bluesttape
    Bluesttape New Member
    Jesse
    2021 Grey Platinum
    I’d like to see this exact set up.
  10. Dec 14, 2020 at 9:40 PM
    AZBoatHauler
    So.Arizona
    This is close. 1.9” 1 CB shim drivers side and +2 CB shackle with 275 70 18 tires.
    Casper3 and Bluesttape[QUOTED] like this.
  11. Dec 14, 2020 at 9:43 PM
    Kanobi13
    Kanobi13 New Member
    316KS_Runner and Casper3 like this.
  12. Dec 15, 2020 at 12:47 PM
    Casper3
    Casper3 New Member
    Jay
    CT/OH
    2017 Super White 5.7 SR5 TRD off road
    1.9 setting with a driverside shim and CB+3 in rear with 295/70r18's20201215_051915.jpg
    Florida Man 82 and 316KS_Runner like this.
  13. Dec 23, 2020 at 9:27 PM
    Mill72
    Mill72 New Member
    California
    2021 Tundra DC 4x4 TRD
    Did any of those that set at 1.9” install diff drop?
  14. Dec 23, 2020 at 9:34 PM
    Kanobi13
    Kanobi13 New Member
    What you have to do to get the 295 to fit? I rub on bumper with 275.
  15. Dec 24, 2020 at 3:27 AM
    Casper3
    Casper3 New Member
    Jay
    CT/OH
    I didn't
  16. Dec 24, 2020 at 3:36 AM
    Casper3
    Casper3 New Member
    Jay
    CT/OH
    Just trimmed a little bit of the wheel well liner and skid plate, I'm running SCS Ray 10's with a +25 offset which helps with clearance.
