  1. Dec 23, 2020 at 3:03 PM
    #8521
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Nuts rusted through? Sounds painful...:sorry::wink:
  2. Dec 23, 2020 at 5:13 PM
    #8522
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    Looks like it. The nuts/bolts are still attached to the underside.
  3. Dec 23, 2020 at 5:23 PM
    #8523
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    At least they're still in the right neighborhood.
    Rica25, TheBeast and Mountun Goat like this.
  4. Dec 23, 2020 at 6:41 PM
    #8524
    mtndds98
    mtndds98 New Member
    2013 Silver Tundra CrewMax
    6" ProComp Stage 1 lift
    Wow!! My pants got tight looking at that picture. Very nice!
    ITFDB, airosey[QUOTED] and Rica25 like this.
  5. Dec 23, 2020 at 6:50 PM
    #8525
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
    1991 White Xtra-cab SR5 4X4 V6 5 speed 148K
    WVI, ecm209, Prostar 190 and 3 others like this.
  6. Dec 23, 2020 at 8:26 PM
    #8526
    Rica25
    Ricardo
    Tulare
    Added the Info button selection to get the mpg since mine is SR5 and only the limited had that option at that time. It was just a swap took less than 2 minutes.
  7. Dec 23, 2020 at 9:15 PM
    #8527
    TheBeast
    TheBeast The Beach
    did that few years back. one of my first mods :)
  8. Dec 23, 2020 at 9:32 PM
    #8528
    Rica25
    Ricardo
    Tulare
    Wish I would have thought about it before
  9. Dec 23, 2020 at 10:21 PM
    #8529
    kparrow
    kparrow New Member
    Kevin
    Nampa, ID
    2008 Tundra DC 4x4 5.7l V8 Blue Streak Metallic
    Goodyear UltraTerrain AT 275/70/r18, Stoptech Cryo Slotted Rotors/Hawk LTS Pads, DECKED, and lots more!
    Indeed! Never made any sense to me. Why spec 2 different t-case types, 2 different 4wd computers, and 2 different length front drive shafts when you could have had only 3 parts for both vehicles? I don’t understand why they “crippled” the Tundra with the tcase it has, when they could have made the driving experience nicer for us too. The reardrive shaft is something crazy small, almost insignificant like 1/8” different in length and so it has to be trimmed. The 4wd computer is plug and play and then you just add the button for lock/unlock. No way the tcase is any less robust than the one in our trucks....the power plant hooked to it is the same. If I had the money to swap it to the AWD t-case I would
  10. Dec 24, 2020 at 6:48 AM
    #8530
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    The upscale vehicles (Sequoia/Land Cruiser) always get more options.
    The difference in regards to the rear driveshaft is due to it being two-piece on all the Tundras with the exception of the RCSB (Sequoia/LC are one-piece as well). On the Double Cab and Crew Max, the span from the TC output to the carrier bearing is fixed, and with the AWD TC being 1.25" inches longer, that segment requires modification. The front driveshaft does not require modification, personal preference. I haven't looked into the cost of doing this lately, but other than labor, the cost is likely less than or equal to the cost of a new set of wheels and tires. :sawzall:
    kanger328, Rica25 and kparrow[QUOTED] like this.
  11. Dec 24, 2020 at 4:43 PM
    #8531
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
    Hooked up a Gen I Hewitt bypass on my truck. I didn't have the problem with the AIP but wanted to install it as insurance. It was very easy overall. The hard and time consuming part was deciding how to hide the unit and route some of the wires.
  12. Dec 24, 2020 at 4:57 PM
    #8532
    vq35721
    vq35721 New Member
    2011 040 SR5
    Too much to list
    Slowly getting there
    84A95C43-8A5E-4638-934E-BBA1F324E091.jpg 2987B14D-48BD-48FF-A781-5ABB921AC436.jpg
  13. Dec 25, 2020 at 2:15 PM
    #8533
    Tundra Fan
    Tundra Fan Got 17's?
    Toby
    Nor Cal (Placer Co.)
    2013 Platinum-SOLD 2022 Sequoia, Celestial Silver Metallic
    Ditched the container I had in the back that held all my miscellaneous shit, and added a Swing case.
  14. Dec 25, 2020 at 4:02 PM
    #8534
    Rica25
    Ricardo
    Tulare
  15. Dec 25, 2020 at 9:54 PM
    #8535
    sensei
    sensei master and teacher of nothing
    trd boosted, trd bbk, fox stage 4, corsa, amp, jl/kenwood
    Merry Christmas to me lol. had my buddies son build a color matched casting rig to go with my truck.
    WVI, Dg191, FundraTRD and 9 others like this.
  16. Dec 26, 2020 at 9:19 AM
    #8536
    Trident
    Trident New Member
    2007 Tundra DC 4X4
    Broke the ABS sensor bolt. Nothing but rust holding that thing together. There may be enough sticking out to grab hold of and extract. Once I get the sensor out....
    Anybody know that bolts size? T5 sensor retainer bolt.
    Edited to add: You don't even need to remove the ABS sensor to do the ECGS bushing install, no matter what some write-ups say :mad:
    worktruckwhite and Rica25 like this.
  17. Dec 26, 2020 at 4:56 PM
    #8537
    vq35721
    vq35721 New Member
    2011 040 SR5
    Too much to list
    neeed !
    TheBeast and Rica25[QUOTED] like this.
  18. Dec 26, 2020 at 5:39 PM
    #8538
    Dg191
    Dg191 New Member
    2007 2 who drive limited tundra
    None
    2007 Tundra Limited, 2 wheeler. So, I’ve done Rims, Tires, Toyo Open Country AT3, 285X55 R20’s, Bilsteins 5100’s, leveling kit, shorty antenna, weather tech Matt’s ( not happy with these, the fit sucks ) console Vault, TRD rear sway bar, ordered my Dirty Deeds exhaust, pining over the AMP electric running boards but now looking at the BeStop electric running boards far, far cheaper. Needing some help deciding on front and rear lights, something plug and play? Thanks
    Prostar 190 and Rica25 like this.
  19. Dec 26, 2020 at 7:04 PM
    #8539
    Trident
    Trident New Member
    2007 Tundra DC 4X4
    F me.....After driving the bushing in I grabbed the axle, threaded on the axle nut to protect the threads while installing it back into the diff. A few whacks with a couple of 4lb devices....no joy. Went to unscrew the nut and now it needs an impact to come off. WTAF? Threads look fine but now I may be in the market for a new CV I guess.
  20. Dec 26, 2020 at 8:03 PM
    #8540
    Graycee II
    Graycee II New Member
    2013 DC Rock Warrior
    Bilstein 6112 front and 5100 rear. BFG 285 75 17
    So this happened today. Icon Rebounds with BFG's. Loving it. Also now have 3 Rock Warrior 17's for sale.
    WVI, TRDblvd, Dalandshark and 12 others like this.
  21. Dec 27, 2020 at 3:34 AM
    #8541
    cygan1008
    cygan1008 New Member
    “RIP” 2013 Tundra TRD Rock Warrior, 2018 TRD SPORT CM 4x4 SUPER WHITE Eibach Pro 2.0 275/65/20 Recon Grapplers
    i’ve been debating swapping out the Rock Warriors for something darker, really partial to the fuel beast in that DARK “bronze” color.
  22. Dec 27, 2020 at 7:17 AM
    #8542
    careyrob
    careyrob In the field
    Carey
    Massachusetts
    2008 Crewmax TRD 4x4 Silver
    LRO 3/1 leveling lift 35x12.50's on 20x9's Hellwig rear sway bar B&M 70264 SuperCooler Transmission Cooler Firestone airbags Daystar cradles Air Lift WirelessONE Compressor System
    What happened to wheel #4? Where are you located?
  23. Dec 27, 2020 at 7:21 AM
    #8543
    I have a limited with the info button but don't want to know my MPG.:anonymous::D
    omgboost, TheBeast and Rica25[QUOTED] like this.
  24. Dec 27, 2020 at 7:23 AM
    #8544
    :popcorn:
    Rica25 likes this.
  25. Dec 27, 2020 at 9:09 AM
    #8545
    careyrob
    Carey
    Massachusetts
    I have an '08 SR5. It's had the Info button since I bought from the original owner.
    Based on his extensive documentation he never added the button. It must have been there when he bought it from the dealer.:notsure:
  26. Dec 27, 2020 at 9:09 AM
    #8546
    Dg191
    Dg191 New Member
    None
    I’m in Ca looking for opinions on front and rear lighting. Some of it looks pretty intimidating. Plug and play isn’t all it’s cracked up to be.
  27. Dec 27, 2020 at 9:11 AM
    #8547
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Toyota can seem pretty random with what they outfit a vehicle with sometimes.
  28. Dec 27, 2020 at 10:21 AM
    #8548
    TheBeast
    TheBeast The Beach
    Morimotos.
    Rica25 likes this.
  29. Dec 27, 2020 at 12:08 PM
    #8549
    kparrow
    kparrow New Member
    Kevin
    Nampa, ID
    Installed the shifter handle my wife got me for Christmas. Still need to figure out something to cover the chrome shaft, but liking it!
    rons23, Rica25, MTRock and 1 other person like this.
  30. Dec 27, 2020 at 12:13 PM
    #8550
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    The idea just occurred to me. Some large diameter heat shrink tubing and hit it with a hair dryer. If it doesn't give you the look you're seeking, you can remove it with that razor blade that's sitting on your map pocket cover that I can see in your picture.
    Rica25 and Stainlesst like this.
