Disable Door Beep
Discussion in '2.5 Gen Tundras (2014-2021)' started by Genuine Cooling Systems, Dec 21, 2020.
  1. Dec 21, 2020 at 5:05 AM
    Genuine Cooling Systems [OP] New Member Vendor
    Anyone know how to disable the door beep/charm?
  2. Dec 21, 2020 at 6:13 AM
    Wolfie410
    Wolfie410 New Member
    2019 Toyota Tundra crewmax limited
    Have you checked the options on the touchscreen, maybe under vehicle settings? I know there are some options there (door locks and drls), but not sure if the door chime is one of them.
  3. Dec 21, 2020 at 6:18 AM
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
    If it’s not in the headunit vehicle settings screen, the dealer should be able to do it with their Techstream software
  4. Dec 21, 2020 at 6:18 AM
    tttrdpro
    tttrdpro Former Naval Person
    SWGA
    2024 GMC 2500 AT4
    In progress…
  5. Dec 21, 2020 at 6:31 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    On my older truck (2011) there wasn't an option to turn the door chime off, even with Techstream. Buuuut, the volume and chime rate each have three options. What I did is set the rate and volume to their slowest/lowest settings. From my perspective this was the least annoying while still reminding me where the key is, and the radio doesn't need to be very loud to mask the sound.
  6. Dec 21, 2020 at 6:51 AM
    Have you done this with the carista? Techstream doesn't have this option. I know when I had my Tacoma the only way people disabled it is by pinning the drivers door actuator closed.
  7. Dec 21, 2020 at 7:06 AM
    tttrdpro
    SWGA
    2024 GMC 2500 AT4
    In progress…
    Let me double check after I get off work (7 PM). I thought it was an option but I may be thinking about something else. I’ll let you know.
  8. Dec 21, 2020 at 7:31 AM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Read through the “customizations” section of the user manual (section 8). It lists what can be changed and whether it can be done in the head unit or using techstream. My understanding is that carista can do many of the things techstream can (aside from programming key transponders and fobs).
  9. Dec 21, 2020 at 7:34 AM
    Kanobi13
    Kanobi13 New Member
    Take the front seat out and put it on the roof works like a charm
  10. Dec 21, 2020 at 8:18 AM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Pro suspension, sways
    Dealership can do it in 5 minutes
    I had a list of all things I wanted shut off before I took delivery. They did it for free and said I could change it back at anytime, no charge.
    Edit.
    I might be wrong here, but I had my seatbelt chime shutoff and not the open door chime. Unknown if it is indeed possible to shut that one off.
  11. Dec 21, 2020 at 1:23 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    The seatbelt chime (but not the dash indicator) can be muted completely, both driver and passenger.
    rockmup and Toyotoholic[QUOTED] like this.
  12. Dec 21, 2020 at 1:40 PM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Yes and that is what I did, and was thinking the OP was looking for. But then I realized, the open door chime, not the seatbelt chime, is what he was actually looking for and then edited my oops. Lol
    Wynnded[QUOTED] likes this.
  13. Dec 21, 2020 at 1:42 PM
    rockmup
    rockmup New Member
    Todd
    Greenwell Springs LA.
    Kings, 5:29's, E-lockers on 37's
    Correct, I did that in Carista as well as the headlight chime
  14. Dec 21, 2020 at 1:44 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Huh, see I didn't know that the headlamp chime (didn't even recall that there was one) could be muted.
  15. Dec 21, 2020 at 1:44 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    free99, jam a screwdriver handle between the door striker and that rubber sensor, just remember to take it off... Its not fancy, and you don't need to spend 4 hours at the dealer for it...
  16. Dec 21, 2020 at 1:47 PM
    So there is no option to mute it through software. If not, ill take apart the sensor and trick it into thinking its always closed.
  17. Dec 21, 2020 at 1:49 PM
    I disabled the seat belts chimes through techstream. I just don't think it is possible with the door chime. It's annoying that I have to remove the key from the ignition completely so it doesn't go off.
    Toyotoholic[QUOTED] likes this.
  18. Dec 21, 2020 at 1:49 PM
    blackdemon_tt
    yeah, unplug it from the back, problem solved. Gotta remove some trim to get to it...
  19. Dec 21, 2020 at 1:49 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    That may keep your interior lights from turning on when you open the door. Test before buttoning it up...
  20. Dec 21, 2020 at 1:57 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Depending on when it is annoying you the most, this may help.
    When you come to a stop, put the truck in Park, then take your foot off the brake, and ONLY THEN turn the truck off. When you open the door, no chime. For some reason, if you have your foot on the brake when you shut the truck off, it will chime.
  21. Dec 21, 2020 at 2:01 PM
    You are correct. Another way to disable the sensor it to use thin napoleon washers on the screw. This blocks the sensor from being grounded and it won't function. I'm now thinking of unplugging the alarm behind the dash.
    blackdemon_tt[QUOTED] likes this.
