2nd Gen Aftermarket Headlight Trouble..
Discussion in '2nd Gen Tundras (2007-2013)' started by 2ndGenKy, Dec 19, 2020.
  1. Dec 19, 2020 at 3:12 PM
    2ndGenKy
    2ndGenKy [OP] New Member
    Ky
    2007 Blue Tundra Limited
    So a week ago I ordered a pair of headlights from Spec-D
    https://specdtuning.com/2007-2013-t...or-headlights-matte-black-housing-clear-lens/
    Today they came in and I tried installing them to my 07 crewmax limited.. The low beam and high beam connection points fit just like the oem ones did, but for whatever reason the connection point for the drl/turn signal was completely different, thus I am currently unable to install these headlights.
    I absolutely do not want to splice any wires or the such, but I'm afraid it's something that I'm gonna have to do. Has anyone ran into this problem before? Is there any sort of adapter I can buy so I don't have to splice anything? If needed I can provide a picture of what the connection point looks like on the aftermarket headlights.
  2. Apr 26, 2024 at 11:47 AM
    JoeGiBear
    JoeGiBear New Member
    Joe
    Colorado Springs, CO
    2014 Platinum Super White
    BDS 4.5 lift, Bilstein 6112 in front, XD Rockstar 2 20s in Terra Graps G2. 2020 Grille
    I just bought some last week, installed last night amd had the same issues. Did you ever get any answers or resolutions?
  3. Apr 26, 2024 at 12:20 PM
    JoeGiBear
    Joe
    Is the SKU number the one underneath the barcode?
  4. Apr 26, 2024 at 12:30 PM
    g6t9ed
    g6t9ed Novice Tundra Modder
    2017 Black CrewMax 1794 4x4
    If your issue is what I think it is, Toyota headlights have a two part connection section. There's the connection where the bulb goes into and that connects into the headlight housing. I could be wrong but try and see if you can locate this adapter and see if this connects to your aftermarket headlight connection:
