Horrible noise after alignment
Discussion in '2.5 Gen Tundras (2014-2021)' started by Jra8, Dec 5, 2020.
  1. Dec 5, 2020 at 8:18 PM
    Jra8
    Jra8 [OP] New Member
    Tampa Fl
    2018 Inferno
    So. Had this JBA uppers installed the other day. And of course, an alignment was done. On my way home, the truck drive straight, but steering wheel was off to the right by a hair. But since my tire wear is not even, I can live with it for now. Now for the bad. When I went to make a u turn, I heard a terrible knocking sound, and also felt it on the steering wheel. Every time lock the wheel to either side, it makes the same terrible noise, and it didn't do that before. I have bilstein 6112 with a 3" lift up front for about a year. Just now added the UCA s. Has anyone had a similar experience? I'm going back to the shop Monday. Hopefully it's an easy fix.
  2. Dec 5, 2020 at 8:21 PM
    JLS in WA
    JLS in WA New Member
    2008 White DC Limited 4x4
    Drahthaar Transport Unit
    Rubbing on your skid plate?
  3. Dec 5, 2020 at 8:24 PM
    Jra8
    Tampa Fl
    2018 Inferno
    No. Skid plate already trimmed. All the rubbing issues were taken care of a year ago when I did the lift. All I did now was upper control arm upgrade.
  4. Dec 5, 2020 at 8:30 PM
    JLS in WA
    Have you had someone turn the wheels to lock while you're under there?
  5. Dec 5, 2020 at 8:34 PM
    Jra8
    Tampa Fl
    2018 Inferno
    No. Just me turning, then getting out of the truck to see. I feel like waking up my kids now to go check it with me under the truck. LoL.
  6. Dec 5, 2020 at 8:40 PM
    RollTide82
    RollTide82 New Member
    Michael
    2019 Tundra 4x4
    Tires rubbing front bumper
  7. Dec 5, 2020 at 8:45 PM
    Jra8
    Tampa Fl
    2018 Inferno
    Not the front bumper. It's more of a metal on metal knock sound. My tires are not huge. 295/75/18.
  8. Dec 6, 2020 at 7:20 AM
    RollTide82
    Michael
    2019 Tundra 4x4
    Any luck?
  9. Dec 6, 2020 at 9:44 AM
    ItsNickROFL
    ItsNickROFL New Member
    2020 SR5 Tundra CrewMax
    Intake, exhaust, interior
    A 35 is a large tire for this trucks. Probably hitting your BMC now that you’re in good alligntment.
  10. Dec 7, 2020 at 7:25 PM
    Jra8
    Tampa Fl
    2018 Inferno
    So, yesterday, I must have done 50 turns each way, no more noise. Still went to the shop this morning, they checked everything, the entire front end. And everything checked out fine. Still noise free today. So, time will tell. Thank you guys for your input.
  11. Dec 7, 2020 at 7:39 PM
    glowblue
    glowblue From time to time
    VA
    This happened to me and at first I couldn’t find it but it was the OEM skid plate. Other things to check if it comes back are the steering stops on lower ball joint and LCA bushings binding.
    Jra8[OP] likes this.
  12. Dec 8, 2020 at 4:24 AM
    Jra8
    Tampa Fl
    2018 Inferno
    Skid plate was trimmed a year ago. I will keep the other stuff in mind in the future. Thanks
  13. Dec 16, 2020 at 12:43 PM
    Jra8
    Tampa Fl
    2018 Inferno
    Noise is back, every now and then, and I think I found the problem.
  14. Dec 16, 2020 at 3:26 PM
    glowblue
    VA
    If it happens at full lock which I think is what your symptom is then grease the steering stops! Cheap and easy fix :thumbsup:
  15. Dec 16, 2020 at 4:29 PM
    Jra8
    Tampa Fl
    2018 Inferno
    Yeah. That's my next step!
  16. Dec 18, 2020 at 7:09 PM
    WSJ
    WSJ New Member
    W
    Phoenix AZ
    19 Platinum 5.7 4WD Crewmax
    BAd noise? Take out the Mariah Carey Christmas CD.
