Cold start
Discussion in '2.5 Gen Tundras (2014-2021)' started by ealxele, Dec 18, 2020.
  1. Dec 18, 2020 at 11:47 AM
    ealxele
    ealxele [OP] New Member
    Hey guys,
    Just curious how long do you guys let your car/engine run during the initial cold start?
    And also I read it's good to let your car run for at least 15 seconds when it's not a cold start.
    Thank you in advance!
  2. Dec 18, 2020 at 11:53 AM
    Warreng
    Warreng New Member
    -25c cold, at least 5 min. -5c cold, only a minute or so
    Or as long as it takes to clear off the snow and defrost the windshield
  3. Dec 18, 2020 at 11:56 AM
    RyeHog
    RyeHog New Member
    2014 MGM Sr5 Tundra
    I let mine run for maybe a minute while the garage door is opening. When I’m at work and the truck is actually cold I’ll let it idle for 5-10 minutes. That’s when it’s anywhere from 30F and below in winter months.
  4. Dec 18, 2020 at 12:08 PM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    Well in central Texas where we don't see much below 30, if at all, I'd say 15 seconds or more but it's not because I'm waiting or following some advice, I just fire the engine first, then do all the seatbelt, seat adjustments, connect phone, select music, Now I'm Ready!
    BravoDeltaRomeo likes this.
  5. Dec 18, 2020 at 12:12 PM
    Lake.Life24
    Lake.Life24 New Member
    Shawn
    Upstate, NY
    2021 GMC Sierra 3500HD Gasser
    In Upstate, NY I let it warm up until its nice and toasty so I can drive in comfort haha
  6. Dec 18, 2020 at 1:06 PM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    depends on the weather, 5 min or so unless it is hot or cold, then 5-10 min to get the cab comfortable....with remote start
  7. Dec 18, 2020 at 2:50 PM
    ChillTree
    ChillTree New Member
    2019 Tundra Platinum
    TRD Pro Rims
    usually i try to warm it up for a couple mins...anything longer is a waste of gas. we run 0-20 which doesnt require much to start flowing.
