Key Fob fell into a black hole.
Discussion in '2.5 Gen Tundras (2014-2021)' started by The Californian, Dec 18, 2020.
  1. Dec 18, 2020 at 6:56 AM
    The Californian
    The Californian [OP] Good Vibes Only
    Eric
    2020 Super White Tundra TRD Pro Crewmax
    What a wonderful start to my morning.
    I was loading some stuff into the bed of my truck this morning and had set my key fob on top of my diamondback cover. I needed to open the diamondback, and after lifting it heard the fob sliding - but didn’t think much of it until I realized it had slid all the way forward and dropped down into the gap between the cab, and the bed. I looked there and saw it stuck sideways so I tried to knock it out, but only ended up loosening it to drop all the way down into somewhere between there, and the ground - but it did not go all the way to the ground. I looked around with a flashlight, couldn’t see anything. So I grabbed my backup, and ripped around the block a couple of times hoping it would fall out - but no such luck.
    I had to leave for work, so I just took off after no success. I don’t exactly know what it looks like under the bed to know if it could possibly be stuck somewhere secure, but my drive to work today was about 30 minutes on the highway.
    Anyone know if there’s a chance it’s still stuck there somewhere? If so how would I get it? It’s not close enough to be recognized by the truck to open doors or start it.
    If it’s likely gone, what’s my best option at getting a replacement? I still have the physical key that goes into it, as I had separated them to unlock the tailgate.
    Darkness likes this.
  2. Dec 18, 2020 at 7:04 AM
    AZTundra
    Paul
    Phoenix, AZ
    Any pictures of the area it fell into?
    The Californian[OP] likes this.
  3. Dec 18, 2020 at 7:14 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    Darkness and The Californian[OP] like this.
  4. Dec 18, 2020 at 7:15 AM
    GravityGear
    Aurora, CO
    I say f that noise. It could be a 5 minute job with a mirror and flexible reaching grabber thing, or a 50 hour job removing the bed, gas tank, cab, whatever. Just grab a new one and never do whatever you did again.
    https://www.remotesremotes.com/Default.asp
    Tundra2 likes this.
  5. Dec 18, 2020 at 7:20 AM
    Bammer
    Monroe, CT
    Best of luck with the search !
  6. Dec 18, 2020 at 7:48 AM
    widetrax
    widetrax New Member
    lester williams
    Meridian Ms
    2021 1794 tundra
    What is the next step? I have also lost a remote, and need a new one. Buy one and then go to the dealer to get it programmed? Can a locksmith do this also? [ for a 2021 1794 ]
  7. Dec 18, 2020 at 7:49 AM
    GravityGear
    Aurora, CO
  8. Dec 18, 2020 at 7:52 AM
    pv355
    pv355 New Member
    Peter
    2018 CM SR5 5.7L 4x4 in Gray
    Installed: Katzskins Seats Alpine Amp + JBL GTO609c Kicker 43TCWRT102 in passive radiator box TRD Rear sway bar Power tailgate lock VLAND TRD Pro Style LED Headlights Puddle lights Illuminated ignition ring Waiting on install: Wishlist: Vented/heated seats Rear seat storage Chrome delete Parking sensors
    There's not too many spots it could have landed on. Top of the gas tank? Or gas tank heat shield?
    I had a local locksmith cut and program a key for me. I think it was around $100 for a 2018 style key.
  9. Dec 18, 2020 at 7:53 AM
    The Californian
    Eric
    Fell in where my finger is pointing.
    AZTundra[QUOTED] likes this.
  10. Dec 18, 2020 at 7:55 AM
    MentalBill
    MentalBill Mental in every state.
    Oahu
    2015 Tundra Limited and 2018 Honda Civic
  11. Dec 18, 2020 at 7:59 AM
    GravityGear
    Aurora, CO
    Sure I suppose. I mean, you're giving the valet your keys. If you inadvertently give them your master key and they go have it cloned along with your remote, it would be the same thing.
    You would need to have possession of the vehicle to use it as it goes into your obd2 port.
  12. Dec 18, 2020 at 8:01 AM
    pv355
    pv355 New Member
    Peter
    That's right around where the gas tank is.
  13. Dec 18, 2020 at 8:03 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Have you gotten up underneath and tried to look around?
  14. Dec 18, 2020 at 8:04 AM
    AZTundra
    Paul
    Phoenix, AZ
    Can't imagine there are too many places it could have landed down there. Agree that an extendable mirror tool might help assist in locating it.
  15. Dec 18, 2020 at 8:06 AM
    DIYDad
    DIYDad New Member
    2020 Tundra 1794
    New tool time... a cheap video borescope would cost less than a new key. some have a hook attachment so you can grab what the camera sees...
    and if that's a push-to start truck, you may need to retrieve that key anyway to prevent any random passerby from driving off with your truck!
  16. Dec 18, 2020 at 8:24 AM
    The Californian
    Eric
    Thankfully, wherever it landed it's not close enough to be used to unlock, or start the truck. Just ordered a borescope with a grabber for same day delivery.
    Mater and AZTundra like this.
  17. Dec 18, 2020 at 8:27 AM
    timsp8
    NY
    Sure it didn’t fall on the ground? Did you check your driveway and the road leaving your house? It might have rattled loose and fallen all the way down.
  18. Dec 18, 2020 at 8:47 AM
    danz75
    danz75 New Member
    Everett, WA
    18' Cement SR5
    OEM LED headlights, Rigid SAE foglights, Go Rhino RB10 running boards, ARE Classic CX
    Its possible that it either landed on top of the gas tank or is wedged between the gas tank and the heat shield. Heat shield is attached to gas tank by a few small bolts. Its not much effort to start there first.
  19. Dec 18, 2020 at 8:55 AM
    pv355
    pv355 New Member
    Peter
    You should be able to just reach you hand in there if you're laying on the ground under the truck.
  20. Dec 18, 2020 at 10:40 AM
    The Californian
    Eric
    You can do it through the dealership, or through a locksmith - either will work as long as the locksmith has the tools for it. The best price I found in the fob alone was through Toyota of Cool Springs for $120.
    It was still dark outside when it happened, got a chance to look at it when I got home and my wife was able to grab it. Crisis averted.
    Totally didn’t think of that.
    That’s precisely where it ended up, my wife was able to slide her hand in there and grab it.
    Once the sun was up and there was some light I was able to see it, my wife was able to slide her hand in there and grab it.
    Wynnded, AZTundra, Mater and 4 others like this.
  21. Dec 18, 2020 at 10:59 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Lucked out for you!
  22. Dec 18, 2020 at 11:09 AM
    Mater
    Mater New Member
    SD
    2016 MGM Platinum
    If borescope doesn’t work here’s the proper order of operations:
    1) buy all new skids (including gas tank) and look for key while installing.
    2) since you’re already working around the gas tank might as well loosen the strap and jiggle it to see if the key falls out. While the strap is loose install some rock sliders.
    3) if 1 and 2 fail, upgrade to the Lexus credit card sized wallet key, have it programmed to your truck and be happy with purchases in 1,2 and 3.
  23. Dec 18, 2020 at 11:33 AM
    MentalBill
    Oahu
    Saw Gone in 60 seconds to many times.
    Happy ending to this story.
  24. Dec 18, 2020 at 11:37 AM
    The Californian
    Eric
    Wait, is #3 a real option? I’d love to swap my fob out for a card sized key.
  25. Dec 18, 2020 at 11:51 AM
    Mater
    Mater New Member
    SD
    2016 MGM Platinum
