Building amp rack
Discussion in 'Audio & Video' started by BrianH4x4, Dec 17, 2020.
  1. Dec 17, 2020 at 5:49 PM
    BrianH4x4
    BrianH4x4 [OP] New Member
    Shelby, North Carolina
    2015 silver sky metallic
    USB plug added for backseat 6 circuit fuse holder added Amp power steps Bed lights Bumper led ( anytime) lights Amp reasearch bed step Focal three way components up front Focal 165 in rear Jl xd200 amp for front stage Jl xd 300 amp for 10 W3 -D4 sub Maestro rr for steering wheel control
    what do you do when your awaiting Covid test results and have no symptoms....... build a amp rack, what else??
  2. Dec 20, 2020 at 1:16 AM
    Riskyguy
    Riskyguy New Member
    Stewart
    2018 Tundra SR5 Crewcab
    What are the 2 units on the bottom?
    Rica25 likes this.
  3. Dec 20, 2020 at 4:35 AM
    BrianH4x4
    Those are passive crossovers for the three way component set.
    Rica25 likes this.
  4. Dec 20, 2020 at 7:44 AM
    Riskyguy
    Riskyguy New Member
    Stewart
    OK. That's better than mounting them in the door. I'll remember that when I do my system in 2021.
    Rica25 likes this.
  5. Dec 20, 2020 at 8:01 AM
    CrashRat
    CrashRat New Member
    Greg
    Vancouver, WA
    2021 Platinum silver sky metallic
    Work in progress
    Looks great, Brian. Where did you build it to go? I'm having a hard time figuring that out by looking at it. I am currently in the process of building my audio system so looking for ideas/suggestions.
    Rica25 and BrianH4x4[OP] like this.
  6. Dec 20, 2020 at 8:09 AM
    Elduder
    Elduder New Member
  7. Dec 20, 2020 at 6:28 PM
    BrianH4x4
    underneath the front passenger seat.
    Boneskull420, Rica25 and cquilichini like this.
  8. Dec 21, 2020 at 5:39 PM
    CrashRat
    CrashRat New Member
    Greg
    Vancouver, WA
    Work in progress
    Gotcha, thanks. that looks really good. It was hard to tell how big the amps were in the other picture.
  9. Dec 27, 2020 at 9:11 AM
    PWMDMD
    PWMDMD New Member
    Worcester, MA
    2020 Tundra Platinum
    Are those redundant fuse blocks? I remember someone making a big deal about the fuses being as close to the battery as possible. Not sure how much of a difference this makes in reality. Looks great!
  10. Dec 27, 2020 at 9:51 AM
    BrianH4x4
    The fuse block you see at the amps hold the fuses for each amp. Jl audios amps are not fused. There is a inline fuse 12” from the battery to protect the 4 AWG wire feeding the amps.
    Rica25 likes this.
  11. Jan 27, 2021 at 12:49 AM
    Psquancher
    Psquancher New Member
    Jeff
    Atlanta area
    2018 Tundra CM 4X4
    aFe intake and dual exhaust. ADD Stealth front bumper with Rigid light Bar and Smittybuilt winch, ADD Stealth rear bumpers and ADD Stealth steps. Bilstein 6112 @2.3” Bilstein 5160s with Toytech shackles at 1.5". Fuel Contra 20x10 -18 with Ridge Grappler 285/65 with custom BMC. Monster system with Infinity Kappa components JL HD750/1 and JL HD600/4 amps JL Stealthbox and Alpine avic8400NEX hu and full Kilmat sound dampening.
    Do you have a template available? That’s nice work!
    Rica25 likes this.
  12. Jan 27, 2021 at 6:40 AM
    Corranhorn4406
    Corranhorn4406 New Member
    Brad
    2015 Black Tundra SR5
    Where did you ground under the passenger seat? Having some noise issues in my system so I'm curious.
    Rica25 likes this.
  13. Jan 27, 2021 at 4:52 PM
    jwatt
    jwatt I heart men
    Jack
    Oregon
    Salsa Red 2007 Tundra DC @91k.
    7" BDS Coilover Suspension Lift/BDS UCAs/XB LED Headlights/Nitto trail Grappler tires on Black Rhyno Armory wheels
    I was reading that fastening grounds under seats, even if you grind any paint off location, isn t the best place to ground, (which is how I was going to do it). It said a chassis ground is better, and reduces potential problems.
    Rica25 likes this.
  14. Jan 28, 2021 at 6:12 PM
    BrianH4x4
    I grounded the amps at the factory ground connection just under the carpet in front of the opening provide for the stock harnesses to run out. Works like a champ, 0 noise.
    Rica25 likes this.
  15. Jan 29, 2021 at 11:05 AM
    801Tundra
    801Tundra New Member
    UTAH
    2019 Crewmax Limited
    Looks good! Is that 1/4" ABS you used?
  16. Jan 29, 2021 at 4:45 PM
    jwatt
    jwatt I heart men
    Jack
    Oregon
    It s odd that some systems respond badly to small things, and others dont. Looking at your wire routing I would nt be suprised if you had noise, but if you don t then that s great. I have to run my rca s away from my power wires. Got to keep em seperated.
  17. Jan 30, 2021 at 5:37 PM
    BrianH4x4
    Yes, sure is.
  18. Mar 8, 2022 at 5:12 PM
    pgilparra
    pgilparra New Member
    Brian. do you recall the measurements of your bracket?
  19. Mar 9, 2022 at 3:32 AM
    BrianH4x4
    Unfortunately I do not. I took the seat out and did some quick measuring. Then transferred those measurements to a piece of cardboard, cut it out and test fitted. Once I had it right I traced it to the abs and cut it out.
