Rack and pinion
Discussion in '1st Gen Tundras (2000-2006)' started by zgurrola21, Dec 15, 2020.
  1. Dec 15, 2020 at 1:35 PM
    zgurrola21
    zgurrola21 [OP] New Member
    Zyan
    2001 Toyota Tundra SR5 TRD OFF-ROAD
    Hey guys I bought a new rack and pinion and when I was installing it i don’t know if this is suppose to sit flat or it’s suppose to be like that in the picture, I didn’t take that part off so I don’t know how it sits, it’s the steering rod to the rack and pinion is what the picture is.
  2. Dec 17, 2020 at 11:26 AM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    Sorry I don't know for sure, but it does seem like it should sit flat.
  3. Dec 17, 2020 at 2:17 PM
    Stuck in the '00s
    Stuck in the '00s Experienced member
    Mikey
    SE Wisconsin
    2004 Phantom Gray DC 4X4 Limited Tundra
    Western plow, custom bed
    The gap on mine is about 8mm.
  4. Dec 17, 2020 at 5:08 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    Do you mean how far down the rack splines the joint should be?
    There should be a 'notch' on the rack input shaft that the pinch bolt should slide through, just make sure the bolt fits into that notch.
    KNABORES likes this.
