Need back up!
Discussion in 'Audio & Video' started by War_Wagon312, Dec 17, 2020.
  1. Dec 17, 2020 at 5:44 AM
    War_Wagon312
    War_Wagon312 [OP] Puddle Dodger
    Rich
    2025 sequoia MGM TRD PRO
    Stock horse
    Just ordered the attached items. I have never installed a radio before so I’m excited to tackle it. Any pointers you guys have would be greatly appreciated. Anyone know if I have to run any separate wires? Like power wire or anything like that? I have also heard there is a parking brake bypass? Any info on that would be awesome.
    MTRock likes this.
  2. Dec 17, 2020 at 5:49 AM
    glowblue
    glowblue From time to time
    VA
    Make sure to flash current firmware on the Maestro, install is straight forward. The Maestro can only be flashed when disconnected from power, you can’t flash it while it’s installed. One tip - when trying to stuff all the new wiring harnesses and maestro back into the dash, it helped me to open the center speaker grille on the front dash to help pull wires through.
  3. Dec 17, 2020 at 6:05 AM
    War_Wagon312
    Rich
    Stock horse
    Thank you sir greatly appreciated. So end of the day I hook the harness from the deck to the maestro after flashing the maestro and it’s plug and play?. You know anything about the parking brake bypass. Looks like some may cut the green wire and ground it on the back of the unit?
    619Tundra likes this.
  4. Dec 17, 2020 at 6:11 AM
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    Brake bypass, easy way.
    https://youtu.be/LYb6A943gHo
    You can also tie the green brake line to your harness' black ground wire.
    Make sure you connect up the power antenna lead or you wont get any am/fm reception.
    619Tundra and War_Wagon312[OP] like this.
  5. Dec 17, 2020 at 6:15 AM
    War_Wagon312
    Rich
    Stock horse
    Thank you very much. The power antenna lead is a plug into the maestro or a separate wire you gotta run?
  6. Dec 17, 2020 at 6:18 AM
    BrandonL812
    Brandon
    Antenna lead connects to the maestro. So basically the blue or blue/white lead on the Kenwood harness will be labeled as ant.cont.... or something along that line. Tie that wire to the maestro harness which also have similar labelling. This is to turn on the power to the antenna so it can get reception.
    War_Wagon312[OP] likes this.
  7. Dec 17, 2020 at 6:20 AM
    War_Wagon312
    Rich
    Stock horse
    Aye sir! Thank you! First one. 34 year’s old and have never installed one hahaha.
    BrandonL812[QUOTED] likes this.
  8. Dec 17, 2020 at 6:23 AM
    BrandonL812
    Brandon
    It's isn't as bad as one think. The maestro instructions guide is very helpful. You cant mess up. Color for color. Dont get intimidated by all the wires. This is a good way to learn bout your truck.
    Make sure you unhook the Negative battery cable BEFORE starting any electrical work. It'll save you the headache of having blown fuse or shorts.
  9. Dec 17, 2020 at 6:26 AM
    War_Wagon312
    Rich
    Stock horse
    Thank you. I definitely would NOT have done that. That would have been a self correcting mistake haha.
  10. Dec 17, 2020 at 6:27 AM
    BrandonL812
    Brandon
    Need to make a correction. I see you have the metra antenna adapter. Notice that blue wire on that adapter? That wire need to either tie in with the maestro or the Kenwood. Both places will provide power to that wire.
    Watch this tundra install vide
    https://youtu.be/GhiMy1GPayE
  11. Dec 17, 2020 at 6:31 AM
    War_Wagon312
    Rich
    Stock horse
    So here he says he doesn’t have to use a bunch of wires like the speaker wires. I still need to use those because I’m running stock speakers right?
  12. Dec 17, 2020 at 6:37 AM
    BrandonL812
    Brandon
    If you have the jbl system with the factory amp. You wont use any of the speakers wires. You only need the white and grey rcas. Because the factory amp have the built-in dsp. It takes in 2 channels and spread them out to all the others.. that's why he said if you have factory JBL you will not need the other speaker wires.
    If you dont have jbl then you would cut the white and grey rcas and connect them to your kenwood harness color for color for the speakers.
  13. Dec 17, 2020 at 6:43 AM
    War_Wagon312
    Rich
    Stock horse
    I don’t think I have the jbl. I have a 16 trd pro. So every wire on the kenwood harness including the 8 speaker wires will be connected to something? Or just cut the rca and connect those?
  14. Dec 17, 2020 at 6:47 AM
    War_Wagon312
    Rich
    Stock horse
    Disregard I see what you are saying.
    BrandonL812 likes this.
  15. Dec 17, 2020 at 6:59 AM
    BrandonL812
    Brandon
    You can tell if you have jbl by looking at your door's speaker grill. It will have the JBL logo on the grill.
    Once you cut the rcas (2), you will have 2 white, 2 grey, 2 purple, 2 green on the maestro. That's your 8 wires for the speakers.
    On your kenwood, it will have the exact samething, same color.
    So you will just match them up, solder, and heat shrink. Or connect them per your preference. Solder will be the best connection.
    Have you download the maestro instructions guide yet?
    You can do so here and give it a read over before starting.
    https://maestro.idatalink.com/searc...6&vehicle_model_id=325&vehicle_audio_id=13713
    I put in your car info with amplified Non-jbl. But you need to confirm that first. Look under the passenger side seat, see if there is an amp there.
  16. Dec 17, 2020 at 7:09 AM
    War_Wagon312
    Rich
    Stock horse
    So those rca are going to get cut, capped and put to the side then I’m matching colors. I’m definitely going to solder and heat shrink. I have downloaded anything yet the unit should be here Saturday. I will give that a once over now so I can save some time during install. Did you wrap all the wires in electrical tape to neaten them up or did you use that other fabric tape?.
  17. Dec 17, 2020 at 7:15 AM
    BrandonL812
    Brandon
    Do NOT wrap them up in electrical tape. During summer heat, it will get sticky and gooey.. if you can, get some Tesa tape. Otherwise, use small zip-ties will also work. The tesa tape wil be much cleaner look. Just like the youtube vid. They only use tesa fabric tape.
    Yes, cut the rcas (white and grey) back bout 2in.. leave yourself extra wire so if you have to go back and re-join the rcas, you have room to do so.
  18. Dec 17, 2020 at 7:19 AM
    War_Wagon312
    Rich
    Stock horse
    That’s it Tesa tape! Going to grab some now.
  19. Dec 17, 2020 at 12:02 PM
    jwatt
    jwatt I heart men
    Jack
    Oregon
    Salsa Red 2007 Tundra DC @91k.
    7" BDS Coilover Suspension Lift/BDS UCAs/XB LED Headlights/Nitto trail Grappler tires on Black Rhyno Armory wheels
    Thats a lot for a head unit. I guess Im cheap. I paid just over $500.00 for my Excellon. It s no 1057 though.
  20. Dec 17, 2020 at 12:07 PM
    MTRock
    MTRock 1889
    Montana
    2024 Tacoma TRD Off Road
    Katzkin Leather seats, JRI shocks, Rival aluminum skids, 285/70/17 outpost nat, Berger catch can, icon rear +.5 springs, gator trifold bed cover, Perry parts bump stops, switchback turn signals,
    Call Cruthfield and get the “ ReadyHarness” makes it mostly plug and play! Saves tons of time
  21. Dec 17, 2020 at 12:09 PM
    War_Wagon312
    Rich
    Stock horse
    That’s where I got this whole setup. I wish they had that in the parts needed for install section. I bought everything in that category :(
  22. Dec 17, 2020 at 12:09 PM
    War_Wagon312
    Rich
    Stock horse
    Ya it was a toss up and I said screw it. I’m doing it.
  23. Dec 17, 2020 at 12:23 PM
    BrandonL812
    Brandon
    I, personally, like to piece the harnesses together. Therapeutic for me, seeing how things come together.
  24. Dec 17, 2020 at 12:42 PM
    War_Wagon312
    Rich
    Stock horse
    If everything turns on after I’m done I’m going to be extremely satisfied and feel accomplished.
  25. Dec 17, 2020 at 1:15 PM
    BrandonL812
    Brandon
    It will. Just follow the instructions provided by maestro and you will be fine.
  26. Dec 17, 2020 at 5:11 PM
    War_Wagon312
    Rich
    Stock horse
    Aye sir.
  27. Dec 18, 2020 at 6:26 AM
    619Tundra
    619Tundra New Member
    San Diego, Caifornia
    2017 Black Tundra Double Cab SR5
  28. Dec 18, 2020 at 11:43 AM
    War_Wagon312
    Rich
    Stock horse
    619Tundra[QUOTED] likes this.
  29. Dec 18, 2020 at 9:11 PM
    619Tundra
    I plan on finishing up the sub box and mounting speakers. I'll take pics to post later.
  30. Dec 21, 2020 at 3:48 PM
    War_Wagon312
    Rich
    Stock horse
    So everything works but. The usb cable they sent me won’t plug into the back of the usb that’s already there and I forgot to hook the mic up :(. Ran out of daylight I’ll pull it back out and hook that up and possible hook the hdmi up as well. All odb stuff works.
    619Tundra and BrandonL812 like this.
