Adding cruise control
Discussion in '2nd Gen Tundras (2007-2013)' started by Awburris77, Dec 9, 2020.
  1. Dec 9, 2020 at 3:45 AM
    Awburris77
    Awburris77 [OP] New Member
    Aaron
    2011 Tundra 4x4
    I bought a 2011 Tundra with the “work truck” package and would like to add cruise control. Does anyone have any advice? Thanks
  2. Dec 9, 2020 at 4:20 AM
    If its even possible, I'm thinking it will be expensive.
  3. Dec 13, 2020 at 11:19 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    LOL Just reminded me of the original Jurasic Park movie. With the kid playing with the night vision and the lawyer.. What is that? They look expensive, put them away. Eitherway
    You will need a cruise control ECU? And you may need to pinout the ECU as well as possibly swapping your throttle body.. cable ones are much easier..... you may need a wiring diagram and a shitload of patience.. It may be prewired, but you may need to do some work...
  4. Dec 13, 2020 at 11:46 PM
    jwatt
    jwatt I heart men
    Jack
    Oregon
    Salsa Red 2007 Tundra DC @91k.
    7" BDS Coilover Suspension Lift/BDS UCAs/XB LED Headlights/Nitto trail Grappler tires on Black Rhyno Armory wheels
    I can t imagine it would be easy if the model didn t come with it. And mighty dangerous if not done by a professional.
  5. Dec 14, 2020 at 7:00 PM
    Half Assed
    Half Assed me ne frego
    Heartland Florida
    10 crewmax, 07 reg cab
    At the very least you need a steering wheel with cruise and a new clockspring. Then probably a trip to the dealer to activate it.
    I would think everything else is built into the drive by wire throttle like most other cars nowadays.
  6. Dec 14, 2020 at 7:34 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    On my ‘06 Tacoma base, I added cruise by installing the cruise switch stalk in the steering wheel, the jumper wire from it to the clockspring, and a clutch pedal switch since it was a 6 spd manual. It was super easy, no programming or parameter changes to the ECU needed.
    The aftermarket kits I found include wiring, so your Tundra may not be prewired like that??
    https://www.thecruisecontrolstore.c...7-2011-automatic-complete-cruise-control-kit/
    What engine / transmission does your 2011 have?
  7. Mar 12, 2021 at 9:53 AM
    Hanzo
    Hanzo New Member
    Any update on this OP?
  8. May 24, 2021 at 5:09 PM
    Awburris77
    Aaron
    2011 Tundra 4x4
    Ok I did it! I added cruise and intermittent wipers and it was super easy. I think I’m going to make a YouTube video on it. The key to it is getting the parts off of a wreck that had these two options from the factory.
  9. Dec 28, 2021 at 2:52 AM
    joseph_womack
    joseph_womack @ 4x4bound
    Joe
    Louisiana
    2007 RCLB, 4WD, 4.7L V8
    Any update on the YouTube video?
