2006 4.7l engine comparability ( help please)
Discussion in '1st Gen Tundras (2000-2006)' started by Ramsey12, Dec 12, 2020.
  1. Dec 12, 2020 at 1:19 PM
    Ramsey12
    Ramsey12 [OP] New Member
    Kirk
    2006 Toyota Sequoia
    Hello Everyone,
    I recently bought a really nice Toyota sequoia with 208,000 miles on it. I purchased in through an auction. It sold cheap because of "engine problems" my assumption was timing which turned out to be ok and in time. Next assumption was coil packs, also fine. I did replace all spark plugs as well. After taking compression readings on all cylinders I have no compression on the passenger side back cylinder, the rest are between 120 and 140. My assumption is that something catastrophic has occurred in the back passenger side cylinder. This has prompted be to look for engine replacement options. The newer 4.7l motor ( which this rig has) is significantly more expensive and much harder to find than the older non VVT-i. Is it possible to use a non VVT-i in a newer VVT-i era rig? If so what would be needed to make the switch? If not possible, how challenging is a rebuild on a 4.7l? I have some experience and have friends with much more experience.
    YardBird likes this.
  2. Dec 12, 2020 at 1:26 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    going non vvt-i may take you back to the mid 90's.. with the 1UZ... You can try to expand your search to the 07-12? Tundras since they also carried the 4.7 until it was replaced by the 4.6l. You can possibly look up the 4.6 for a suitable replacement as I'm sure will bolt up, but you may need a digital dash to swap in, which may be more costly. For a rebuild option you may need to get an estimate first and weigh your options as to what's more financially suitable for you.
  3. Dec 12, 2020 at 1:27 PM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
    I hope someone can help with your issue.
  4. Dec 12, 2020 at 1:44 PM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Borescope the cylinder for damage first. If the cylinder looks good inside, pull the cam cover for inspection. You might get lucky.
    Welcome from the Texas Hill Country.
    blackdemon_tt likes this.
  5. Dec 12, 2020 at 2:20 PM
    weadjust
    weadjust New Member
    Tupelo, MS
    2006 Tundra Limited DC
    I searched car-part.com for my southeast region and there are 3 pages of VVT-i engines with various mileages and prices. They do seem to be pretty proud of the lower mileage engines price wise.
  6. Dec 12, 2020 at 3:12 PM
    blackdemon_tt
    I'd go with @JohnLakeman inspect first, and would swap if its absolutely necessary as you can run into the same issue with the new engine plus the extra labor for the swap and electrical.
  7. Dec 12, 2020 at 4:25 PM
    Ramsey12
    Kirk
    2006 Toyota Sequoia
    They are very proud of the variable valve motors, the non VVT-i are much cheaper and easier to come by but it I just dont know if I can make it work. I did take the valve covers off hoping for something obvious but that looked fine. I will try the bore scope and see if I can see what things look like. Has anyone rebuilt the 4.7l motor and have any suggestions on if it is worth it? $2500 for a used motor with 193000 miles is hard to swallow.
  8. Dec 12, 2020 at 4:25 PM
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
    Following suit here, I would pull the valve cover and take a closer look before throwing in the towel on the engine. Is it possible you're having a VVTi problem? Any codes being shown?
  9. Dec 12, 2020 at 9:35 PM
    Ramsey12
    Kirk
    2006 Toyota Sequoia
    Codes: Multiple misfires on cylinders 2-7
  10. Dec 13, 2020 at 1:00 AM
    zgurrola21
    zgurrola21 New Member
    Zyan
    2001 Toyota Tundra SR5 TRD OFF-ROAD
    I got this code as well and it was just a shot Intake manifold gasket. What are the symptoms, does it start, does it run?
  11. Dec 13, 2020 at 1:01 AM
    zgurrola21
    Zyan
    View my first thread if possible, people told me to do a compression test but it was just the gasket that was shot, just maybe, that could be your issue if you’re lucky
  12. Dec 13, 2020 at 1:02 AM
    zgurrola21
    Zyan
    If it does turn over and able to drive it but has rough idle, pour some water, not to much maybe like some drops near the gasket of the intake manifold is placed and hear if the idle changes
  13. Dec 13, 2020 at 6:33 AM
    N84434
    Milwaukee WI.
    2001 Limited TRD
    You can also do this with propane. When the propane gets drawn into the leaky gasket spot, the RPMs rise slightly..
  14. Dec 13, 2020 at 7:08 AM
    As to your original question, no, you can't swap in the older 2000-2004 non-VVTI into your Sequoia easily. Computers will all be different, ECU and TCU, and the older non-VVTI was never mated to the 5 speed transmission in the Tundra. Would be lots of headache I would imagine. Best bet is to pull and tear down the engine for a rebuild or find a replacement. If the numbers don't look good financially to do so, you may want to consider selling and looking for another Sequoia. Every time my son talks about motor swapping his car, I'm like sell it, and buy a car with the motor you want. Unless you enjoy all that trouble, some do. They're called Masochists. And they're bad at math.
    619Tundra and FrenchToasty like this.
  15. Dec 14, 2020 at 7:33 PM
    Ramsey12
    Kirk
    2006 Toyota Sequoia
    It does run, and drive, just rough idle. The intake manifold gasket will be my next check.
    Knabores, thanks for the info, that it what I am realizing about the nonvvti motors. I think I am just gonna have to break down and rebuild or buy a motor if I cant get anything else figured out.
