Base to TRD wheel question
Discussion in 'Wheels & Tires' started by Warthogdrifter, Dec 7, 2020.
  1. Dec 7, 2020 at 3:52 PM
    Warthogdrifter
    Warthogdrifter [OP] New Member
    PXL_20201127_215050328.jpgJust bought a 2021 base sr5 tundra for reference.
    Firstquestion:
    The factory 255's came with michelin LTX 2's on them that I want to save. They are only 20mm smaller than the worn 275's on the TRD wheel. Will I be okay remounting the factory 255's on the TRD wheel? I don't see why they wouldn't fit. I was just wondering if someone else has done the same thing trying to save money.
    Second question:
    Do I need factory TPMS installed or can I get away with something aftermarket?
  2. Dec 7, 2020 at 4:14 PM
    BIGUGLY
    BIGUGLY I the SheepDog. I have the capacity for Violence.
    Paul
    2018 Limited
    TPMS can be aftermarket.
  3. Dec 7, 2020 at 4:31 PM
    jalam321
    jalam321 New Member
    2018 Tundra CM Platinum 4x4 and Sequoia Platinum 4x4
    Welcome, nice color Tundra.
    1st question: Yes, you can use those tires.
    2nd question: The TPMS sensors from the steel wheel are different than the alloy wheels. But yes it's ok to use aftermarket sensors.
  4. Dec 8, 2020 at 9:06 AM
    DIYDad
    DIYDad New Member
    2020 Tundra 1794
    If I've followed other threads on this forum correctly, SOME aftermarket TPMS sensors are OK, but not ALL aftermarket TPMS are OK. one of the threads had part numbers posted after the OP had problems with tire shop supplied TPMS's.
  5. Dec 8, 2020 at 9:13 AM
    Welcome from NY.
  6. Dec 8, 2020 at 9:25 AM
    manofsteele2003
    manofsteele2003 New Member
    24 Sequoia TRD Pro, 03 Tundra Limited 4WD
    Westcott designs 3"/1" lift 295/70/18 Falken Wildpeak RTs Canvasback cargo liner aFe Tow hooks
    You'll also need new lug nuts for the alloy wheels if they didn't come with them.
    BravoDeltaRomeo likes this.
  7. Dec 8, 2020 at 12:50 PM
    Warthogdrifter
    I have the original lugs for the TRD wheels. I'll look further into the TPMS before I install this weekend. Found a local shop that will transfer the basically new tires from wheel to wheel.
  8. Dec 10, 2020 at 3:26 PM
    tbutler
    tbutler Team Toyota
    2021 Land Cruiser HE - Black
    I was in the same situation - truck came stock with steel wheels and the 255 tire. I purchased a set of the TRD wheels and lugs and had my original tires mounted on the TRD wheels. The tire shop was able to take my TPMS from the steel wheels and mount them in the TRD wheels - I think they have to turn them 180 degrees to get them to fit. America's Tire knew exactly what needed to be done to make them work. I tried to sell or give away my steel wheels, but had no takers. Ended up taking them to a recycling center and cashed them in.
  9. Dec 12, 2020 at 9:53 AM
    Warthogdrifter
    Got it done. Reused the original TPMS. Super happy with the outcome! Thanks for the help everyone!!
    AdamTundra4x4, tbutler, jpink and 3 others like this.
  10. Dec 12, 2020 at 10:36 AM
    MotoTundra
    MotoTundra The Ocho
    Don
    :thumbsup:
  11. Dec 13, 2020 at 8:17 PM
    Cdre
    Cdre New Member
    I used the same wheels. Had them powder coated though and slapped on some eBay TRD center caps.
    Warthogdrifter[OP] likes this.
  12. Dec 13, 2020 at 8:37 PM
    Warthogdrifter
    Looks awesome.
